Battery Charger
10-01-2007, 05:12
Battery Charger
Alvie I've had good luck with twin IOTA 55amp. You need a single IQ4 smart
charger for dual chargers. Do not try to use two chargers each with their own smart charger. This will cause them to conflict. You need the single IQ4 to regulate both IOTAs. You should be able to get both IOTAs and the IQ4 for between $300 and $350. If you want top-of-the line then I would go with Xantrex equipment On 01/10/2007, whynotam > > I went out to the coach yesterday to check the fridge and noticed the > gas alarm was beeping. Long story short, the battery charger had gone > south and thus the house bateries were down to almost zip. Any > suggestions on what charger to buy? I have 8 deep cycle 12 volt house > batteries as well as the standard 3 starting batteries. Thanks for your > assistance. > > Alvie Miller > Arthur IL > 1993 WLWB 40' > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
10-01-2007, 05:18
Battery Charger
> > Alvie I've had good luck with twin IOTA 55amp. You need a single IQ4 smart > charger for dual chargers. Do not try to use two chargers each with their > own smart charger. This will cause them to conflict. You need the single IQ4 > to regulate both IOTAs. You should be able to get both IOTAs and the IQ4 for > between $300 and $350. If you want top-of-the line then I would go with > Xantrex equipment > > On 01/10/2007, whynotam > > > > I went out to the coach yesterday to check the fridge and noticed the > > gas alarm was beeping. Long story short, the battery charger had gone > > south and thus the house bateries were down to almost zip. Any > > suggestions on what charger to buy? I have 8 deep cycle 12 volt house > > batteries as well as the standard 3 starting batteries. Thanks for your > > assistance. > > > > Alvie Miller > > Arthur IL > > 1993 WLWB 40' > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > Rob, Will both chargers fit in the compartment where the present one is? The 3000 Watt inverter is also in that compartment. Do both chargers come on at the same time? Is the Xantrex quite a bit more money? Thanks again. Alvie Miller Arthur IL 1993 WLWB 40' |
10-01-2007, 05:51
Battery Charger
Alvie my IOTAs are located in the same bay as the BBQ and tool box so I
can't speak to their placement in the battery compartment. I seem to recall that others have put them there but not sure. If you go with Xantrex you could use two Tru-charge 40s and that will likely cost close to $800 for two of them. On 01/10/2007, whynotam > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > Alvie I've had good luck with twin IOTA 55amp. You need a single > IQ4 smart > > charger for dual chargers. Do not try to use two chargers each with > their > > own smart charger. This will cause them to conflict. You need the > single IQ4 > > to regulate both IOTAs. You should be able to get both IOTAs and > the IQ4 for > > between $300 and $350. If you want top-of-the line then I would go > with > > Xantrex equipment > > > > On 01/10/2007, whynotam > > > > > > I went out to the coach yesterday to check the fridge and > noticed the > > > gas alarm was beeping. Long story short, the battery charger had > gone > > > south and thus the house bateries were down to almost zip. Any > > > suggestions on what charger to buy? I have 8 deep cycle 12 volt > house > > > batteries as well as the standard 3 starting batteries. Thanks > for your > > > assistance. > > > > > > Alvie Miller > > > Arthur IL > > > 1993 WLWB 40' > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > Rob, > > Will both chargers fit in the compartment where the present one is? > The 3000 Watt inverter is also in that compartment. Do both chargers > come on at the same time? Is the Xantrex quite a bit more money? > Thanks again. > > Alvie Miller > Arthur IL > 1993 WLWB 40' > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
10-01-2007, 06:33
Battery Charger
I've heard good reports about the Xantrex 40+ three-stage charger. See:
<http://www.xantrex.com/web/id/69/p/1/pt/7/product.asp> Or, you may want to upgrade both your charger and inverter with a new inverter-charger. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Oct 1, 2007, at 9:35 AM, whynotam wrote: > I went out to the coach yesterday to check the fridge and noticed the > gas alarm was beeping. Long story short, the battery charger had gone > south and thus the house bateries were down to almost zip. Any > suggestions on what charger to buy? I have 8 deep cycle 12 volt house > batteries as well as the standard 3 starting batteries. Thanks for > your > assistance. [Non-text portions of this message have been removed] |
10-01-2007, 06:36
Battery Charger
Xantrex 40+ is $355 at Amazon.com
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Oct 1, 2007, at 10:18 AM, whynotam wrote: > --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > >> >> Alvie I've had good luck with twin IOTA 55amp. You need a single > IQ4 smart >> charger for dual chargers. Do not try to use two chargers each with > their >> own smart charger. This will cause them to conflict. You need the > single IQ4 >> to regulate both IOTAs. You should be able to get both IOTAs and > the IQ4 for >> between $300 and $350. If you want top-of-the line then I would go > with >> Xantrex equipment >> >> On 01/10/2007, whynotam >>> >>> I went out to the coach yesterday to check the fridge and > noticed the >>> gas alarm was beeping. Long story short, the battery charger had > gone >>> south and thus the house bateries were down to almost zip. Any >>> suggestions on what charger to buy? I have 8 deep cycle 12 volt > house >>> batteries as well as the standard 3 starting batteries. Thanks > for your >>> assistance. >>> >>> Alvie Miller >>> Arthur IL >>> 1993 WLWB 40' >>> >>> >>> >> >> >> >> -- >> Rob, Sue & Merlin Robinson >> 94 WLWB >> >> >> [Non-text portions of this message have been removed] >> > > Rob, > > Will both chargers fit in the compartment where the present one is? > The 3000 Watt inverter is also in that compartment. Do both chargers > come on at the same time? Is the Xantrex quite a bit more money? > Thanks again. > > Alvie Miller > Arthur IL > 1993 WLWB 40' > > [Non-text portions of this message have been removed] |
10-01-2007, 06:45
Battery Charger
Alvie, Pete's suggestion for an upgrade to an inverter/charger combination
is certainly worth considering. If you could get anything for your existing inverter it would make the $$$ numbers better. On 01/10/2007, Pete Masterson > > I've heard good reports about the Xantrex 40+ three-stage charger. See: > <http://www.xantrex.com/web/id/69/p/1/pt/7/product.asp> > > Or, you may want to upgrade both your charger and inverter with a new > inverter-charger. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > On Oct 1, 2007, at 9:35 AM, whynotam wrote: > > > I went out to the coach yesterday to check the fridge and noticed the > > gas alarm was beeping. Long story short, the battery charger had gone > > south and thus the house bateries were down to almost zip. Any > > suggestions on what charger to buy? I have 8 deep cycle 12 volt house > > batteries as well as the standard 3 starting batteries. Thanks for > > your > > assistance. > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
10-01-2007, 07:12
Battery Charger
I will check to see what model inverter I have tonight after work to
see if it might have some resale value. Would installation instructions that come with a new unit be adequate for an electrically challenged person to do the install? Also I am not quite clear on why two chargers are required instead of just one like I have now. Is it for redundancy? Alvie Miller Arthur IL 1993 WLWB 40' --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Alvie, Pete's suggestion for an upgrade to an inverter/charger combination > is certainly worth considering. If you could get anything for your existing > inverter it would make the $$$ numbers better. > > On 01/10/2007, Pete Masterson > > > > I've heard good reports about the Xantrex 40+ three-stage charger. See: > > <http://www.xantrex.com/web/id/69/p/1/pt/7/product.asp> > > > > Or, you may want to upgrade both your charger and inverter with a new > > inverter-charger. > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > El Sobrante CA > > aeonix1@... > > > > On Oct 1, 2007, at 9:35 AM, whynotam wrote: > > > > > I went out to the coach yesterday to check the fridge and noticed the > > > gas alarm was beeping. Long story short, the battery charger had gone > > > south and thus the house bateries were down to almost zip. Any > > > suggestions on what charger to buy? I have 8 deep cycle 12 volt house > > > batteries as well as the standard 3 starting batteries. Thanks for > > > your > > > assistance. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
10-01-2007, 07:18
Battery Charger
First off you might want to contact Curt Sprenger as I believe he has done
some of this work. I believe you need two chargers to reduce the time it takes to put a charge into 8 batteries. I have eight 6V golf carts for the house and the more chargers the better. It isn't redundancy like the two water pumps On 01/10/2007, whynotam > > I will check to see what model inverter I have tonight after work to > see if it might have some resale value. Would installation > instructions that come with a new unit be adequate for an > electrically challenged person to do the install? Also I am not quite > clear on why two chargers are required instead of just one like I > have now. Is it for redundancy? > > Alvie Miller > Arthur IL > 1993 WLWB 40' > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > Alvie, Pete's suggestion for an upgrade to an inverter/charger > combination > > is certainly worth considering. If you could get anything for your > existing > > inverter it would make the $$$ numbers better. > > > > On 01/10/2007, Pete Masterson > > > > > > I've heard good reports about the Xantrex 40+ three-stage > charger. See: > > > <http://www.xantrex.com/web/id/69/p/1/pt/7/product.asp> > > > > > > Or, you may want to upgrade both your charger and inverter with a > new > > > inverter-charger. > > > > > > Pete Masterson > > > '95 Blue Bird Wanderlodge WBDA 42 > > > El Sobrante CA > > > aeonix1@... > > > > > > On Oct 1, 2007, at 9:35 AM, whynotam wrote: > > > > > > > I went out to the coach yesterday to check the fridge and > noticed the > > > > gas alarm was beeping. Long story short, the battery charger > had gone > > > > south and thus the house bateries were down to almost zip. Any > > > > suggestions on what charger to buy? I have 8 deep cycle 12 volt > house > > > > batteries as well as the standard 3 starting batteries. Thanks > for > > > > your > > > > assistance. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
10-01-2007, 07:26
Battery Charger
Curt,
Help. Thanks, Alvie Miller Arthur IL 93 WLWB 40' --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > First off you might want to contact Curt Sprenger as I believe he has done > some of this work. I believe you need two chargers to reduce the time it > takes to put a charge into 8 batteries. I have eight 6V golf carts for the > house and the more chargers the better. It isn't redundancy like the two > water pumps > > On 01/10/2007, whynotam > > > > I will check to see what model inverter I have tonight after work to > > see if it might have some resale value. Would installation > > instructions that come with a new unit be adequate for an > > electrically challenged person to do the install? Also I am not quite > > clear on why two chargers are required instead of just one like I > > have now. Is it for redundancy? > > > > Alvie Miller > > Arthur IL > > 1993 WLWB 40' > > > > --- In WanderlodgeForum@yahoogroups.com > > "Rob Robinson" > > > > > > > > Alvie, Pete's suggestion for an upgrade to an inverter/charger > > combination > > > is certainly worth considering. If you could get anything for your > > existing > > > inverter it would make the $$$ numbers better. > > > > > > On 01/10/2007, Pete Masterson > > > > > > > > I've heard good reports about the Xantrex 40+ three-stage > > charger. See: > > > > <http://www.xantrex.com/web/id/69/p/1/pt/7/product.asp> > > > > > > > > Or, you may want to upgrade both your charger and inverter with a > > new > > > > inverter-charger. > > > > > > > > Pete Masterson > > > > '95 Blue Bird Wanderlodge WBDA 42 > > > > El Sobrante CA > > > > aeonix1@ > > > > > > > > On Oct 1, 2007, at 9:35 AM, whynotam wrote: > > > > > > > > > I went out to the coach yesterday to check the fridge and > > noticed the > > > > > gas alarm was beeping. Long story short, the battery charger > > had gone > > > > > south and thus the house bateries were down to almost zip. Any > > > > > suggestions on what charger to buy? I have 8 deep cycle 12 volt > > house > > > > > batteries as well as the standard 3 starting batteries. Thanks > > for > > > > > your > > > > > assistance. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Rob, Sue & Merlin Robinson > > > 94 WLWB > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
10-01-2007, 08:16
Battery Charger
Alvie you could also talk to Greg OConnor who I believe has recently put in
L16 batteries (floor polisher, electric forklift batteries) and a new Xanatrex system. Greg and Curt are pretty knowledgeable guys On 01/10/2007, whynotam > > Curt, > > Help. > > Thanks, > Alvie Miller > Arthur IL > 93 WLWB 40' > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > First off you might want to contact Curt Sprenger as I believe he > has done > > some of this work. I believe you need two chargers to reduce the > time it > > takes to put a charge into 8 batteries. I have eight 6V golf carts > for the > > house and the more chargers the better. It isn't redundancy like > the two > > water pumps > > > > On 01/10/2007, whynotam > > > > > > I will check to see what model inverter I have tonight after > work to > > > see if it might have some resale value. Would installation > > > instructions that come with a new unit be adequate for an > > > electrically challenged person to do the install? Also I am not > quite > > > clear on why two chargers are required instead of just one like I > > > have now. Is it for redundancy? > > > > > > Alvie Miller > > > Arthur IL > > > 1993 WLWB 40' > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > "Rob Robinson" > > > > > > > > > > > Alvie, Pete's suggestion for an upgrade to an inverter/charger > > > combination > > > > is certainly worth considering. If you could get anything for > your > > > existing > > > > inverter it would make the $$$ numbers better. > > > > > > > > On 01/10/2007, Pete Masterson > > > > > > > > > > I've heard good reports about the Xantrex 40+ three-stage > > > charger. See: > > > > > <http://www.xantrex.com/web/id/69/p/1/pt/7/product.asp> > > > > > > > > > > Or, you may want to upgrade both your charger and inverter > with a > > > new > > > > > inverter-charger. > > > > > > > > > > Pete Masterson > > > > > '95 Blue Bird Wanderlodge WBDA 42 > > > > > El Sobrante CA > > > > > aeonix1@ > > > > > > > > > > On Oct 1, 2007, at 9:35 AM, whynotam wrote: > > > > > > > > > > > I went out to the coach yesterday to check the fridge and > > > noticed the > > > > > > gas alarm was beeping. Long story short, the battery charger > > > had gone > > > > > > south and thus the house bateries were down to almost zip. > Any > > > > > > suggestions on what charger to buy? I have 8 deep cycle 12 > volt > > > house > > > > > > batteries as well as the standard 3 starting batteries. > Thanks > > > for > > > > > > your > > > > > > assistance. > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Rob, Sue & Merlin Robinson > > > > 94 WLWB > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
