Battery Charger
10-01-2007, 08:33
Post: #21
Battery Charger
Thanks Rob,
Alvie
> Alvie you could also talk to Greg OConnor who I believe has
recently put in
> L16 batteries (floor polisher, electric forklift batteries) and a
new
> Xanatrex system. Greg and Curt are pretty knowledgeable guys
> On 01/10/2007, whynotam wrote:
> > Curt,
> > Help.
> > Thanks,
> > Alvie Miller
> > Arthur IL
> > 93 WLWB 40'
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Rob Robinson"
> > wrote:
> > > First off you might want to contact Curt Sprenger as I believe
he
> > has done
> > > some of this work. I believe you need two chargers to reduce the
> > time it
> > > takes to put a charge into 8 batteries. I have eight 6V golf
carts
> > for the
> > > house and the more chargers the better. It isn't redundancy like
> > the two
> > > water pumps
> > > > I will check to see what model inverter I have tonight after
> > work to
> > > > see if it might have some resale value. Would installation
> > > > instructions that come with a new unit be adequate for an
> > > > electrically challenged person to do the install? Also I am
not
> > quite
> > > > clear on why two chargers are required instead of just one
like I
> > > > have now. Is it for redundancy?
> > > > Alvie Miller
> > > > Arthur IL
> > > > 1993 WLWB 40'
> > > > 40yahoogroups.com>,
> > > > "Rob Robinson"
> > > > wrote:
> > > > > Alvie, Pete's suggestion for an upgrade to an
inverter/charger
> > > > combination
> > > > > is certainly worth considering. If you could get anything
for
> > your
> > > > existing
> > > > > inverter it would make the $$$ numbers better.
> > > > > On 01/10/2007, Pete Masterson wrote:
> > > > > > I've heard good reports about the Xantrex 40+ three-stage
> > > > charger. See:
> > > > > > <http://www.xantrex.com/web/id/69/p/1/pt/7/product.asp>
> > > > > > Or, you may want to upgrade both your charger and inverter
> > with a
> > > > new
> > > > > > inverter-charger.
> > > > > > Pete Masterson
> > > > > > '95 Blue Bird Wanderlodge WBDA 42
> > > > > > El Sobrante CA
> > > > > > aeonix1@
> > > > > > On Oct 1, 2007, at 9:35 AM, whynotam wrote:
> > > > > > > I went out to the coach yesterday to check the fridge
> > > > noticed the
> > > > > > > gas alarm was beeping. Long story short, the battery
charger
> > > > had gone
> > > > > > > south and thus the house bateries were down to almost
zip.
> > Any
> > > > > > > suggestions on what charger to buy? I have 8 deep cycle
12
> > volt
> > > > house
> > > > > > > batteries as well as the standard 3 starting batteries.
> > Thanks
> > > > for
> > > > > > > your
> > > > > > > assistance.
> > > > > > [Non-text portions of this message have been removed]
> > > > > Rob, Sue & Merlin Robinson
> > > > > 94 WLWB
> > > 94 WLWB
> 94 WLWB
10-01-2007, 08:44
Post: #22
Battery Charger
Alvie,
I haven't been following this thread other than I recall a posting saying
your charging system went south.Give me some details and I'll try to take a
look at the options you can take. What charging system is in the coach now?
How many? What capacitie(s)? Were you happy with what's there now up until
the failure? How many batteries did the failed unit(s) charge? Batteries 6
or 12 volt?
On 10/1/07, whynotam wrote:
> Curt,
> Help.
> Thanks,
> Alvie Miller
> Arthur IL
> 93 WLWB 40'
> "Rob Robinson"
> > First off you might want to contact Curt Sprenger as I believe he
> has done
> time it
> > takes to put a charge into 8 batteries. I have eight 6V golf carts
> for the
> the two
> > water pumps
> work to
> > > electrically challenged person to do the install? Also I am not
> quite
> > > clear on why two chargers are required instead of just one like I
> > > Alvie Miller
> > > Arthur IL
> > > 1993 WLWB 40'
> > > --- In
> > 40yahoogroups.com>,
> > > "Rob Robinson"
> > > wrote:
> > > > Alvie, Pete's suggestion for an upgrade to an inverter/charger
> > > combination
> > > > is certainly worth considering. If you could get anything for
> your
> > > existing
> > > charger. See:
> with a
> > > new
> > > > > inverter-charger.
> > > > > Pete Masterson
> > > > > El Sobrante CA
> > > > > aeonix1@
> > > > > > I went out to the coach yesterday to check the fridge and
> > > noticed the
> > > > > > gas alarm was beeping. Long story short, the battery charger
> > > had gone
> > > > > > south and thus the house bateries were down to almost zip.
> Any
> > > > > > suggestions on what charger to buy? I have 8 deep cycle 12
> volt
> > > house
> Thanks
> > > for
> > > > > > your
> > > > > > assistance.
> > > > 94 WLWB
> > 94 WLWB
Curt Sprenger
Anaheim Hills, CA
10-01-2007, 09:25
Post: #23
Battery Charger
There was a single charger and I am not sure of the capacity but will
look it up tonight and let you know.
"I went out to the coach yesterday to check the fridge and noticed the
gas alarm was beeping. Long story short, the battery charger had gone
south and thus the house bateries were down to almost zip. Any
suggestions on what charger to buy? I have 8 deep cycle 12 volt house
batteries as well as the standard 3 starting batteries."
Alvie Miller
93 WLWB 40'
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
> Alvie,
saying
to take a
coach now?
up until
Batteries 6
> or 12 volt?
> > Curt,
> > Help.
> > Thanks,
> > Alvie Miller
> > Arthur IL
> > 93 WLWB 40'
> > "Rob Robinson"
he
> > has done
> > time it
carts
> > for the
> > the two
> > > water pumps
> > work to
not
> > quite
like I
> > > > Alvie Miller
> > > > Arthur IL
> > > > 1993 WLWB 40'
> > > > 40yahoogroups.com>,
> > > > "Rob Robinson"
inverter/charger
> > > > combination
for
> > your
> > > > existing
> > > > charger. See:
> > with a
> > > > new
> > > > > > inverter-charger.
> > > > > > Pete Masterson
> > > > > > El Sobrante CA
> > > > > > aeonix1@
> > > > noticed the
charger
> > > > had gone
zip.
> > Any
12
> > volt
> > > > house
> > Thanks
> > > > for
> > > > > > > your
> > > > > > > assistance.
> > > > > 94 WLWB
> > > 94 WLWB
> Curt Sprenger
> Anaheim Hills, CA
10-01-2007, 09:38
Post: #24
Battery Charger
Generally, it's better to split the batteries into 2 "banks" for
charging efficiency.
El Sobrante CA
aeonix1@...
On Oct 1, 2007, at 12:12 PM, whynotam wrote:
> I will check to see what model inverter I have tonight after work to
> electrically challenged person to do the install? Also I am not quite
10-01-2007, 14:37
Post: #25
Battery Charger
My '92 had twin IOTA 45-AMP chargers from the factory.
I am about to rip both my IOTA's out and Inverter and replace with a
single Xantrex Inverter/Charger. I came to the conclusion that for
the price of two chargers, it was the best option. Plus I get the
latest Inverter technology with it.
Be aware the BB inverter circuit is setup a little differently than
other coachs I have owned. You can see a thread on the other Yahoo
Wanderlodge forum that discusses the BB Inverter electrical system
setup.
Michael Brundridge
'92 WB40
Georgetown, TX
--- In WanderlodgeForum@yahoogroups.com, "whynotam"
will
gone
house
> Alvie Miller
> 93 WLWB 40'
> > Alvie,
posting
> saying
try
> to take a
> coach now?
now
> up until
> Batteries 6
> > or 12 volt?
> > > Curt,
> > > Help.
> > > Thanks,
> > > Alvie Miller
> > > Arthur IL
> > > 93 WLWB 40'
> > > --- In WanderlodgeForum@yahoogroups.com > 40yahoogroups.com>,
> > > "Rob Robinson"
believe
> he
> > > has done
> > > time it
> carts
> > > for the
like
> > > the two
> > > > water pumps
after
> > > work to
am
> not
> > > quite
> like I
> > > > > Alvie Miller
> > > > > Arthur IL
> > > > > 1993 WLWB 40'
> > > > > > 40yahoogroups.com>,
> > > > > "Rob Robinson"
> inverter/charger
> > > > > combination
anything
> for
> > > your
> > > > > existing
stage
> > > > > charger. See:
inverter
> > > with a
> > > > > new
> > > > > > > inverter-charger.
> > > > > > > Pete Masterson
> > > > > > > El Sobrante CA
> > > > > > > aeonix1@
fridge
> and
> > > > > noticed the
> charger
> > > > > had gone
almost
> zip.
> > > Any
cycle
> 12
> > > volt
> > > > > house
batteries.
> > > Thanks
> > > > > for
> > > > > > > > your
> > > > > > > > assistance.
> > > > > > 94 WLWB
> > > > 94 WLWB
> > Curt Sprenger
> > Anaheim Hills, CA
10-02-2007, 02:23
Post: #26
Battery Charger
The current charger that has failed is a WFCO model WF-8875 which is
a 75 Amp unit and the inverter is a Heart EMS 2800 Model HD2800-12.
Alvie Miller
Arthur IL
93 WLWB 40'
a
Yahoo
> setup.
> Michael Brundridge
> '92 WB40
> Georgetown, TX
> will
noticed
> the
> gone
> house
> > Alvie Miller
> > 93 WLWB 40'
> > wrote:
> > > Alvie,
> posting
> > saying
> try
> > to take a
> > coach now?
> now
> > up until
> > Batteries 6
> > > or 12 volt?
> > > > Curt,
> > > > Help.
> > > > Thanks,
> > > > Alvie Miller
> > > > Arthur IL
> > > > 93 WLWB 40'
> > > > --- In WanderlodgeForum@yahoogroups.com > > 40yahoogroups.com>,
> > > > "Rob Robinson"
> believe
> > he
> > > > has done
reduce
> the
> > > > time it
golf
> > carts
> > > > for the
> like
> > > > the two
> > > > > water pumps
> after
> > > > work to
> am
> > not
> > > > quite
one
> > like I
> > > > > > Alvie Miller
> > > > > > Arthur IL
> > > > > > 1993 WLWB 40'
> > > > > > > > 40yahoogroups.com>,
> > > > > > "Rob Robinson"
> > inverter/charger
> > > > > > combination
> anything
> > for
> > > > your
> > > > > > existing
> stage
> > > > > > charger. See:
> inverter
> > > > with a
> > > > > > new
> > > > > > > > inverter-charger.
> > > > > > > > Pete Masterson
> > > > > > > > El Sobrante CA
> > > > > > > > aeonix1@
> fridge
> > and
> > > > > > noticed the
battery
> > charger
> > > > > > had gone
> almost
> > zip.
> > > > Any
> cycle
> > 12
> > > > volt
> > > > > > house
> batteries.
> > > > Thanks
> > > > > > for
> > > > > > > > > your
> > > > > > > > > assistance.
> > > > > > > 94 WLWB
> > > > > 94 WLWB
> > > Curt Sprenger
> > > Anaheim Hills, CA
10-02-2007, 05:22
Post: #27
Battery Charger
Alvie,
If the inverter is working I would not replace it.
Check out "Hot Deals" from Progressive Dynamics.
http://www.progressivedyn.com/hotdeals.html
Unit PD9280R is an 80 amp converter/charger and costs $213.00. The hot
deals are reconditioned units. Actually I think they are new. I bought
two of their reconditioned units a couple years ago to replace the two
original battery boilers. They are still doing their job today.
Progressive has a good reputation in the industry.
> Alvie Miller
> Arthur IL
> 93 WLWB 40'
> a
> Yahoo
> > setup.
> > Michael Brundridge
> > '92 WB40
> > Georgetown, TX
> > will
> noticed
> > the
> > gone
> > house
> > > Alvie Miller
> > > 93 WLWB 40'
> > > wrote:
> > > > Alvie,
> > posting
> > > saying
> > try
> > > to take a
> the
> > > coach now?
> > now
> > > up until
> > > Batteries 6
> > > > or 12 volt?
> > > > > Curt,
> > > > > Help.
> > > > > Thanks,
> > > > > Alvie Miller
> > > > > Arthur IL
> > > > > 93 WLWB 40'
> > > > > --- In WanderlodgeForum@yahoogroups.com > > > 40yahoogroups.com>,
> > > > > "Rob Robinson"
> > believe
> > > he
> > > > > has done
> reduce
> > the
> > > > > time it
> golf
> > > carts
> > > > > for the
> > like
> > > > > the two
> > > > > > water pumps
> > after
> > > > > work to
> > am
> > > not
> > > > > quite
> one
> > > like I
> > > > > > > Alvie Miller
> > > > > > > Arthur IL
> > > > > > > 1993 WLWB 40'
> > > > > > > > > > 40yahoogroups.com>,
> > > > > > > "Rob Robinson"
> > > inverter/charger
> > > > > > > combination
> > anything
> > > for
> > > > > your
> > > > > > > existing
> > stage
> > > > > > > charger. See:
> > inverter
> > > > > with a
> > > > > > > new
> > > > > > > > > inverter-charger.
> > > > > > > > > Pete Masterson
> > > > > > > > > El Sobrante CA
> > > > > > > > > aeonix1@
> > fridge
> > > and
> > > > > > > noticed the
> battery
> > > charger
> > > > > > > had gone
> > almost
> > > zip.
> > > > > Any
> > cycle
> > > 12
> > > > > volt
> > > > > > > house
> > batteries.
> > > > > Thanks
> > > > > > > for
> > > > > > > > > > your
> > > > > > > > > > assistance.
> > > > > > > > 94 WLWB
> > > > > > 94 WLWB
> > > > Curt Sprenger
> > > > Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
10-03-2007, 17:24
Post: #28
Battery Charger
Alvie, you have the same set up I do. the heart inverter has a
battery charger built into it and the PO (previous owner) added two
Truecharge 40amp chargers. the Truecharge units claim they deliver 80
amps of value because of the way the unit delivers it. but who knows
what the truth is. If the converter ( batteryCharger) burnt out in
the heart inverter and your PO installed the WFco unit, maybe there
is an issue with circuitry or somthing that has now failed two
units. My two retrofit Truecharge units are located in the third bay
back from the entry door. it looks as it took some effort to install
them there, I assumed it was placed there to keep it away from the
engine heat which is close to the inverter/converter location????????
After replacing 12 interstate 12v batteries in two years I removed
all 8 house batteries , removed the upper tray and modified the box
and lower tray to house 6 L16 batteries. I think two or four l16
would do as the runtime to recharge a battery is directly
proportional to the amount of use. I can run on the 6 batteries for
3 days then recharge with 6 hours of genset charging. or I could run
on 2 batteries for one day with two hours of genset charging. The
main advantage of having 6 batteries is if I run the genset 2 hours
every day the batteries dont cycle through a spent recharge.
(Batteries have a limited number of depleted recharge cycles.)
I would look for the reason the wfco converter and or heart
converter failed prior to installing another . The failed
converter/charge must be a result of some issue???? I often wanted
to look into a post that claimed that their detroit alt got hot when
the shore power charger was on????? I wonder if the Converter/charger
gets hot when the detroit is pumping amps????????? It seems to me
that RV's have a higher than normal engine altinator failure and 110
batterycharger failure.
GregoryO'Connor
94ptRomolandCa
is
> Alvie Miller
> Arthur IL
> 93 WLWB 40'
with
> a
for
than
> Yahoo
system
> > setup.
> > Michael Brundridge
> > '92 WB40
> > Georgetown, TX
but
> > will
> noticed
> > the
had
> > gone
> > house
> > > Alvie Miller
> > > 93 WLWB 40'
> > > wrote:
> > > > Alvie,
> > posting
> > > saying
> > try
> > > to take a
> the
> > > coach now?
> > now
> > > up until
charge?
> > > Batteries 6
> > > > or 12 volt?
> > > > > Curt,
> > > > > Help.
> > > > > Thanks,
> > > > > Alvie Miller
> > > > > Arthur IL
> > > > > 93 WLWB 40'
> > > > > "Rob Robinson"
> > believe
> > > he
> > > > > has done
> reduce
> > the
> > > > > time it
> golf
> > > carts
> > > > > for the
redundancy
> > like
> > > > > the two
> > > > > > water pumps
> > after
> > > > > work to
installation
an
I
> > am
> > > not
> > > > > quite
> one
> > > like I
> > > > > > > Alvie Miller
> > > > > > > Arthur IL
> > > > > > > 1993 WLWB 40'
> > > > > > > --- In
> > > > > > > > > > 40yahoogroups.com>,
> > > > > > > "Rob Robinson"
> > > inverter/charger
> > > > > > > combination
> > anything
> > > for
> > > > > your
> > > > > > > existing
> > stage
> > > > > > > charger. See:
> > inverter
> > > > > with a
> > > > > > > new
> > > > > > > > > inverter-charger.
> > > > > > > > > Pete Masterson
> > > > > > > > > El Sobrante CA
> > > > > > > > > aeonix1@
> > fridge
> > > and
> > > > > > > noticed the
> battery
> > > charger
> > > > > > > had gone
> > almost
> > > zip.
> > > > > Any
> > cycle
> > > 12
> > > > > volt
> > > > > > > house
> > batteries.
> > > > > Thanks
> > > > > > > for
> > > > > > > > > > your
> > > > > > > > > > assistance.
removed]
> > > > > > > > 94 WLWB
> > > > > > 94 WLWB
> > > > Curt Sprenger
> > > > Anaheim Hills, CA
10-04-2007, 03:13
Post: #29
Battery Charger
Greg,
Thanks for the response. I in fact do not know whether the Heart
battery charger works or not as the WFCO converter/charger was
installed at the time I purchased the coach. Is there a simple way to
determine whether the Heart charger does in fact work? The inverter
part of it seems to be fine. I hope to have time this evening to pull
the WFCO and the Heart from the compartment above the battery trays
to see if I can figure it out but if you have any suggestions that
might simplify the task I would sure appreciate them.
Thanks,
Alvie Miller
93 WLWB 40'
Arthur IL
80
knows
bay
install
location????????
for
run
when
Converter/charger
110
> GregoryO'Connor
> 94ptRomolandCa
> is
12.
> > Alvie Miller
> > Arthur IL
> > 93 WLWB 40'
> with
> > a
> for
> than
> > Yahoo
> system
> > > setup.
> > > Michael Brundridge
> > > '92 WB40
> > > Georgetown, TX
> but
> > > will
> > noticed
> > > the
> had
> > > gone
volt
> > > house
> > > > Alvie Miller
> > > > 93 WLWB 40'
> > > > wrote:
> > > > > Alvie,
> > > posting
> > > > saying
I'll
> > > try
> > > > to take a
in
> > the
> > > > coach now?
there
> > > now
> > > > up until
> charge?
> > > > Batteries 6
> > > > > or 12 volt?
> > > > > > Curt,
> > > > > > Help.
> > > > > > Thanks,
> > > > > > Alvie Miller
> > > > > > Arthur IL
> > > > > > 93 WLWB 40'
> > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > 40yahoogroups.com>,
> > > > > > "Rob Robinson"
> > > believe
> > > > he
> > > > > > has done
> > reduce
> > > the
> > > > > > time it
> > golf
> > > > carts
> > > > > > for the
> redundancy
> > > like
> > > > > > the two
> > > > > > > water pumps
tonight
> > > after
> > > > > > work to
> installation
for
> an
Also
> I
> > > am
> > > > not
> > > > > > quite
just
> > one
> > > > like I
> > > > > > > > Alvie Miller
> > > > > > > > Arthur IL
> > > > > > > > 1993 WLWB 40'
> > > > > > > > --- In
> > > > > > > > > > > > 40yahoogroups.com>,
> > > > > > > > "Rob Robinson"
> > > > inverter/charger
> > > > > > > > combination
> > > anything
> > > > for
> > > > > > your
> > > > > > > > existing
three-
> > > stage
> > > > > > > > charger. See:
> > > inverter
> > > > > > with a
> > > > > > > > new
> > > > > > > > > > inverter-charger.
> > > > > > > > > > Pete Masterson
> > > > > > > > > > El Sobrante CA
> > > > > > > > > > aeonix1@
> > > fridge
> > > > and
> > > > > > > > noticed the
> > battery
> > > > charger
> > > > > > > > had gone
> > > almost
> > > > zip.
> > > > > > Any
deep
> > > cycle
> > > > 12
> > > > > > volt
> > > > > > > > house
> > > batteries.
> > > > > > Thanks
> > > > > > > > for
> > > > > > > > > > > your
> > > > > > > > > > > assistance.
> removed]
> > > > > > > > > 94 WLWB
removed]
> > > > > > > 94 WLWB
> > > > > Curt Sprenger
> > > > > Anaheim Hills, CA
