re-doing battery compartment & Cables
04-15-2005, 13:08
Well, after all the comment's I might have to reconsider my method's.
I have used the solder connection in the past and it always seemed to work good. I used it on my 84pt and it seemed to work very well for a number of years. I always heated both the wire and the fitting before inserting the cable into the hot solder. used heat shrink on the cable and it always seemed to be ok. I wonder what the difference in resistance is in copper direct verses the solder direct? Now I have to give this lot's of thought. I have the old charger's out and all the trays sandblasted , now Iam ready to do the epoxy paint. Thanks for the input and I welcome any more suggestions. I really like doing the solder connections, But? Thanks...Bob 93pt Illinois.... |
04-15-2005, 13:15
Bob there should be places where you live that will either let you borrow
or rent a large pair of crimpers to put the cable ends on. Advance Auto here has a pair and I am sure NAPA does also. Crimping the terminals like this and then putting heavy wall heat shrink on them will give you the lowest resistance terminations. When the crimp is completed you will not be able to either remove or loosen the cables within the terminal. This crimp virtually forms a solid mass within the terminals mating the cable to the terminal end. Believe me it works and is the method used by power companies etc. Tom 1982 FC35 Vernon Center, NY In the beautiful Mohawk Valley At 01:08 AM 4/16/2005 +0000, you wrote: >Well, after all the comment's I might have to reconsider my method's. >I have used the solder connection in the past and it always seemed to >work good. I used it on my 84pt and it seemed to work very well for a >number of years. I always heated both the wire and the fitting before >inserting the cable into the hot solder. used heat shrink on the cable >and it always seemed to be ok. I wonder what the difference in >resistance is in copper direct verses the solder direct? Now I have to >give this lot's of thought. I have the old charger's out and all the >trays sandblasted , now Iam ready to do the epoxy paint. Thanks for the >input and I welcome any more suggestions. I really like doing the >solder |
04-15-2005, 14:06
--- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`"
> > Well, after all the comment's I might have to reconsider my method's. > I have used the solder connection in the past and it always seemed to > work good. I used it on my 84pt and it seemed to work very well for a > number of years. I always heated both the wire and the fitting before > inserting the cable into the hot solder. used heat shrink on the cable > and it always seemed to be ok. I wonder what the difference in > resistance is in copper direct verses the solder direct? Now I have to > give this lot's of thought. I have the old charger's out and all the > trays sandblasted , now Iam ready to do the epoxy paint. Thanks for the > input and I welcome any more suggestions. I really like doing the > solder connections, But? Thanks...Bob 93pt Illinois.... Bob, you gonna put epoxy primer under that? Sid Clark in Dallas-91WBSA40 |
04-15-2005, 14:12
--- In WanderlodgeForum@yahoogroups.com, "Sid Clark"
<sidclark99@y...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > > > > Well, after all the comment's I might have to reconsider my > method's. > > I have used the solder connection in the past and it always seemed to > > work good. I used it on my 84pt and it seemed to work very well for a > > number of years. I always heated both the wire and the fitting before > > inserting the cable into the hot solder. used heat shrink on the > cable > > and it always seemed to be ok. I wonder what the difference in > > resistance is in copper direct verses the solder direct? Now I h : Sid Iam not familiar with the epoxy primer. What I"ve used in the past is just the two part paint that come's in a box and you mix the two together for use on appliances etc. Tell me about the primer. I've got the tray's down to bare metal. Thanks Bob 93pt Illinois > to > > give this lot's of thought. I have the old charger's out and all the > > trays sandblasted , now Iam ready to do the epoxy paint. Thanks for > the > > input and I welcome any more suggestions. I really like doing the > > solder connections, But? Thanks...Bob 93pt Illinois.... > > Bob, you gonna put epoxy primer under that? > Sid Clark in Dallas-91WBSA40 |
04-16-2005, 05:04
Hi Bob,
FWIW, the training I got years ago was the best thing to do was to first have a good mechanical connection and then a good solder connection. I will say that I soldered all of the cables on my converted coach and never had a failure but I had two failures of the Bird which had "factory" swaged connectors. I would prefer to swage the connection and then add solder. That give the best of both worlds. I have had too many failures with swaged connections both electrical and hydraulic to trust them very much... George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Bob & Carol Howald` wrote: > > Well, after all the comment's I might have to reconsider my method's. > I have used the solder connection in the past and it always seemed to > work good. I used it on my 84pt and it seemed to work very well for a > number of years. I always heated both the wire and the fitting before > inserting the cable into the hot solder. used heat shrink on the cable > and it always seemed to be ok. I wonder what the difference in > resistance is in copper direct verses the solder direct? Now I have to > give this lot's of thought. I have the old charger's out and all the > trays sandblasted , now Iam ready to do the epoxy paint. Thanks for the > input and I welcome any more suggestions. I really like doing the > solder connections, But? Thanks...Bob 93pt Illinois.... > > > > > > > > Yahoo! Groups Links > > > > > > > > > > |
04-16-2005, 06:51
> > --- In WanderlodgeForum@yahoogroups.com, "Sid Clark" > <sidclark99@y...> wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > > > > > > > Well, after all the comment's I might have to reconsider my > > method's. > > > I have used the solder connection in the past and it always > seemed to > > > work good. I used it on my 84pt and it seemed to work very well > for a > > > number of years. I always heated both the wire and the fitting > before > > > inserting the cable into the hot solder. used heat shrink on the > > cable > > > and it always seemed to be ok. I wonder what the difference in > > > resistance is in copper direct verses the solder direct? Now I h > > > > > > > : > Sid Iam not familiar with the epoxy primer. What I"ve used in the > past is just the two part paint that come's in a box and you mix the > two together for use on appliances etc. Tell me about the primer. > I've got the tray's down to bare metal. Thanks Bob 93pt Illinois > > to > > > give this lot's of thought. I have the old charger's out and all > the > > > trays sandblasted , now Iam ready to do the epoxy paint. Thanks > for > > the > > > input and I welcome any more suggestions. I really like doing the > > > solder connections, But? Thanks...Bob 93pt Illinois.... > > > > Bob, you gonna put epoxy primer under that? > > Sid Clark in Dallas-91WBSA40 Bob, I'm not sure what type of epoxy paint you are using. Read the label and see if they recommend a primer. If not, Dupont Imron would be a good choice. Available at auto paint supply stores. It is the same primer used under the finish coat on our coaches. Two part epoxy also. Sandblasting the battery boxes is a lot of work and you want to be sure you are putting the most durable paint on it you can find. You don't want to have to do it a second time. That is one of the harshest enviornments there is for paint. About the only thing worse would be to add salt water. Sid Clark in Dallas-91WBSA40 |
04-16-2005, 10:23
I think I'd like to see it painted and then a truck-bed-liner paint
like "rhino liner" or equivalent. Seems that abrasion of the paint is the first breach. I'm not sure what the acid resistance is of these products. - Jeff Miller http://www.wanderlodge.net |
