head lights
06-11-2006, 11:04
head lights
My 1988 FC 35 has excellent bright lites but the lows are like candles.
There are lots of Hi Tech replacements avaialble. BUT what is the
correct beam #. This a 4 light rectanglar system. Something like a 6054
or?? All mine have on them is "2A1" Approx. 4 1/4 by 6.5
Bruce 1988 FC35
06-11-2006, 13:23
head lights
You may want to consider the headlight relay modification in
the 'Files' section, I did this on my 82 FC and it was like night and
day.
Scott Forman
82 FC35RB
Memphis
candles.
6054
> Bruce 1988 FC35
06-12-2006, 04:01
head lights
Bruce,
I upgraded my headlight system. What a difference! As Scott suggests you
may want to do the same. I can provide you with a detail set of
instructions, part numbers, etc. Send me a private email, or respond
this email, so I have your email address and I'll send you a copy of
what I have. Before the upgrade the low beams were basically useless as
far as seeing the road.
> day.
> Scott Forman
> 82 FC35RB
> Memphis
> , "birdshill123"
> candles.
> 6054
> > Bruce 1988 FC35
06-12-2006, 11:34
head lights
Curt would this apply to my rig (94). I think my low beams could use some
improvement. My high beams are great.
On 12/06/06, Curt Sprenger wrote:
> Bruce,
> > day.
> > Scott Forman
> > 82 FC35RB
> > Memphis
> > , "birdshill123"
> > candles.
> > 6054
> > > Bruce 1988 FC35
Rob, Sue & Merlin Robinson
94 WLWB
06-12-2006, 13:06
head lights
Curt,
Could send me a copy as well.
Thanx
rhhayden@...
Sent: Monday, June 12, 2006 9:01 AM
Subject: Re: [WanderlodgeForum] Re: head lights
Bruce,
> day.
> Scott Forman
> 82 FC35RB
> Memphis
> --- In
> , "birdshill123"
> candles.
> 6054
> > Bruce 1988 FC35
06-12-2006, 13:39
head lights
Check the ground be for you get to carried away.
David T 89 fc 35 Wi
> Bruce 1988 FC35
06-12-2006, 17:00
head lights
Rob, Curt built a relay setup for the tail lights on my 94pt that
made a huge difference in the rear. One thing he found was the pin
connectors that plug into the Volvo lights are easy to mix up and
infact were mixed up on my bus. When Curt fixed the mixup prior to
the new relays in the rear, the headlights got brighter. The mixup
also caused all the lights to dim when the turnsignal and brakes were
used at the same time. . Bob Gradowski pointed out that the connector
for the wire loom at the lift door gets loose and disconnects also.
94pt Romoland Ca
use some
> > Bruce,
suggests you
respond
of
useless as
06-12-2006, 17:59
head lights
Hi Greg, ya I know Curt has a few tricks up his sleeve. One of these days
I'm going to sneak down south into his neck of the woods and ambush him with
some Modello Especial (sp). Did I say 'ambush'? I meant bribe. Ya bribe,
that's the right word
> Gregory O'Connor
> 94pt Romoland Ca
> "Rob Robinson"
> use some
> > > Bruce,
> suggests you
> respond
> of
> useless as
94 WLWB
06-13-2006, 01:16
head lights
Curt ,
Please send me a copy also.
Howard Truitt
truitt44@...
Sent: Monday, June 12, 2006 9:06 PM
Curt,
Thanx
rhhayden@...
Bruce,
> day.
> Scott Forman
> 82 FC35RB
> Memphis
> --- In
> , "birdshill123"
> candles.
> 6054
> > Bruce 1988 FC35
06-19-2006, 04:28
head lights
Curt, If you don't mind, I would appreciate a copy also.
Thanks,
Alex Smith
82FC35
Tallahassee
replytoalex@...
Richard Hayden wrote:
Curt,
Thanx
rhhayden@...
Bruce,
> day.
> Scott Forman
> 82 FC35RB
> Memphis
> --- In
> , "birdshill123"
> candles.
> 6054
> > Bruce 1988 FC35
Sneak preview the all-new Yahoo.com. It's not radically different. Just
radically better.
