Paint codes and names
06-17-2006, 05:01
I am trying to find the names of the paint codes for my unit(1988
FC35). I have Blue Bird Paint chart but it does not go past 1986. The paint codes in the unit all start with "LF-HS Nxxxx" What does the prefix LF-HS mean? I did find a similar code in the BB chart and my silver is Indian Silver Metallic. My other colours are a light pink and a Plum. I looked online but could not find a Dupont chart. The colours are LF-HS N8075U, LF-HS N8894U and LF-HS N8893 Thanks: Bruce 1988 FC35 |
06-17-2006, 05:46
n8075u silver effect
n8894u light ash rose effect n8893 dark ash rose effect Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > I am trying to find the names of the paint codes for my unit(1988 > FC35). I have Blue Bird Paint chart but it does not go past 1986. The > paint codes in the unit all start with "LF-HS Nxxxx" What does the > prefix LF-HS mean? I did find a similar code in the BB chart and my > silver is Indian Silver Metallic. My other colours are a light pink and > a Plum. I looked online but could not find a Dupont chart. The colours > are LF-HS N8075U, LF-HS N8894U and LF-HS N8893 > > Thanks: > > Bruce 1988 FC35 > |
06-17-2006, 05:49
forgot to add they are probably urethanes
--- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > n8075u silver effect > n8894u light ash rose effect > n8893 dark ash rose effect > > Stephen 77fc35 > > > --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > > > > I am trying to find the names of the paint codes for my unit(1988 > > FC35). I have Blue Bird Paint chart but it does not go past 1986. The > > paint codes in the unit all start with "LF-HS Nxxxx" What does the > > prefix LF-HS mean? I did find a similar code in the BB chart and my > > silver is Indian Silver Metallic. My other colours are a light pink and > > a Plum. I looked online but could not find a Dupont chart. The colours > > are LF-HS N8075U, LF-HS N8894U and LF-HS N8893 > > > > Thanks: > > > > Bruce 1988 FC35 > > > |
06-17-2006, 06:18
Bruce after great effort I finally gave up trying to make sence of the paint
codes stamped on the metal plate above my windshield. I had taken them to several suppliers and none of them could make rhyme or reason out of them. Finally a friend of Randy's who works at an autobody supplier came out to Randy's and shot the colours using a 'paint camera'. Worked great and now I have small cans of touch up paint. On 17/06/06, birdshill123 > > I am trying to find the names of the paint codes for my unit(1988 > FC35). I have Blue Bird Paint chart but it does not go past 1986. The > paint codes in the unit all start with "LF-HS Nxxxx" What does the > prefix LF-HS mean? I did find a similar code in the BB chart and my > silver is Indian Silver Metallic. My other colours are a light pink and > a Plum. I looked online but could not find a Dupont chart. The colours > are LF-HS N8075U, LF-HS N8894U and LF-HS N8893 > > Thanks: > > Bruce 1988 FC35 > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
06-17-2006, 06:50
Thank you for that info Stephen. Being as you are in the paint
industry I should have asked you in the first place. Canadians are just so darn smart! Bruce 1988 FC35 |
