1988 FC35 fuel filters and Racor location
06-18-2006, 12:02
I am putting together a list of oil and fuel filters to keep as spares
for my Bird. I found all the part #,s for the Cat and the Onan. BUT I also found some old tech bulletin about using the 1P2299 as a primary filter. Apparently the micron rating has changed on this filter. Left me confused! As for the racor: My Bird is sitting rather low right now and I do not want to disturb the neighbors by starting the engine to air it up. Dumb question: Where is that racor located? I am assuming it is somewhere along the drivers side frame rail? Which model Racor is on my coach? My manual says it uses a a Racor 2040SM filter. I found a small fuel filter in a box marked NAPA 3166. I cannot cross this filter to any Cat or Onan #'s. It is a drop in cartridge and very small. Any ideas? Could be from the previous owners tractor?? Bruce 1988 FC35 |
06-18-2006, 12:40
Bruce
That 3166 fuel filter is common on medium size tractors and most likely fit anywhere on your Blue Bird. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WB41 |
06-18-2006, 13:06
Not sure about the 88 but look next to the propane tank. Do you know what the
racor looks like? Dan 85FCRB35 Jackson, MS ----- Original Message ----- From: birdshill123 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, June 18, 2006 7:02 PM Subject: [WanderlodgeForum] 1988 FC35 fuel filters and Racor location I am putting together a list of oil and fuel filters to keep as spares for my Bird. I found all the part #,s for the Cat and the Onan. BUT I also found some old tech bulletin about using the 1P2299 as a primary filter. Apparently the micron rating has changed on this filter. Left me confused! As for the racor: My Bird is sitting rather low right now and I do not want to disturb the neighbors by starting the engine to air it up. Dumb question: Where is that racor located? I am assuming it is somewhere along the drivers side frame rail? Which model Racor is on my coach? My manual says it uses a a Racor 2040SM filter. I found a small fuel filter in a box marked NAPA 3166. I cannot cross this filter to any Cat or Onan #'s. It is a drop in cartridge and very small. Any ideas? Could be from the previous owners tractor?? Bruce 1988 FC35 [Non-text portions of this message have been removed] |
06-18-2006, 13:22
Yes I know what it looks like. Thank you I found it beside the propane
tanks behind a panel. Not too easy to service. Thanks again. Still need some more info on which Racor filter to get . Bruce 1988 FC35 |
06-18-2006, 13:45
Bruce,
That 3166 is a drop in fuel filter for a Perkins engine and should be used on your generator if you have that engine on it. The Racor 2040SM is a 2 micron fuel filter and is what Blue Bird used on many of their coaches. You will probably also have a filter on the Cat engine. Not sure what that number is. Chet Geist (just back from the wedding) 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of birdshill123 Sent: Sunday, June 18, 2006 7:03 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] 1988 FC35 fuel filters and Racor location I am putting together a list of oil and fuel filters to keep as spares for my Bird. I found all the part #,s for the Cat and the Onan. BUT I also found some old tech bulletin about using the 1P2299 as a primary filter. Apparently the micron rating has changed on this filter. Left me confused! As for the racor: My Bird is sitting rather low right now and I do not want to disturb the neighbors by starting the engine to air it up. Dumb question: Where is that racor located? I am assuming it is somewhere along the drivers side frame rail? Which model Racor is on my coach? My manual says it uses a a Racor 2040SM filter. I found a small fuel filter in a box marked NAPA 3166. I cannot cross this filter to any Cat or Onan #'s. It is a drop in cartridge and very small. Any ideas? Could be from the previous owners tractor?? Bruce 1988 FC35 [Non-text portions of this message have been removed] |
06-18-2006, 14:20
Bruce,
I think the Napa 3166 is a spin on filter, It may be in the wrong box, It may also fit the Onan, (if it is a spin on filter). But I use a NAPA 3392 spin on filter for the Onan, it has a drain at the bottom for dirt & water. If the filter you have is a corrigated cartridge it may fit the power steering fluid canister. Or possibly the ZF trans, this is an expensive wire mesh cartridge. The Racor 2040SM is a Brown 2 micron, I use the 2040TM Blue 10 micron, The 2040 PM is Red 30 micron. I use a Cat, 2 micron 1R-0750 on the 3208. All these numbers cross to NAPA, sometimes you get an original Racor filter, sometimes Wix, by ordering the same number from NAPA. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > I am putting together a list of oil and fuel filters to keep as spares > for my Bird. I found all the part #,s for the Cat and the Onan. BUT I > also found some old tech bulletin about using the 1P2299 as a primary > filter. Apparently the micron rating has changed on this filter. Left > me confused! As for the racor: My Bird is sitting rather low right now > and I do not want to disturb the neighbors by starting the engine to > air it up. Dumb question: Where is that racor located? I am assuming it > is somewhere along the drivers side frame rail? Which model Racor is on > my coach? My manual says it uses a a Racor 2040SM filter. I found a > small fuel filter in a box marked NAPA 3166. I cannot cross this filter > to any Cat or Onan #'s. It is a drop in cartridge and very small. Any > ideas? Could be from the previous owners tractor?? > > Bruce 1988 FC35 > |
06-18-2006, 14:46
Bill: Here is that engineering bulletin I found:
Bruce 1988 FC35 Newer Caterpillar engines equipped with electronic fuel injection systems previously using the BF7525 now use the Baldwin BF7633 (Caterpillar 1R0750), while the older Caterpillar engines with mechanical fuel injection systems still use the Baldwin BF970 (Caterpillar 1P2299). The BF7525 provided a direct replacement for the Caterpillar 1R0740 fuel filter. The 1R0740 was considered an upgrade to the Caterpillar 1P2299 fuel filter because it provided longer service life. Baldwin Filters met the performance of the 1R0740 by designing the BF7525 with the capacity to provide 20% longer service life than the BF970. However, the design of the BF970 fuel filter eventually evolved to match the service life of the BF7525. The current BF970 and BF7525 utilize the same filtering element, providing equal filtration efficiency and filter service life. With the performance of these two filters being equal, the logical choice is to obsolete one of the part numbers to save on inventory and manufacturing costs. Caterpillar's introduction of the 1R0750 provided a high efficiency fuel filter that is now used in place of the 1R0740 on Caterpillar engines equipped with electronic fuel injection systems. Please refer to Engineering Bulletin 98-2 for more information regarding the high efficiency fuel filters. Since the 1P2299 is still used on Caterpillar engines with mechanical fuel injection systems, there was no need to continue the 1R0740 fuel filter. Therefore, Caterpillar discontinued the 1R0740. In response to Caterpillar's action, Baldwin Filters chose to obsolete the BF7525 and continue the BF970. This also allows us to consolidate two identical part numbers into one and remain consistent with Caterpillar's recommendations. Please make note of this change in your current Baldwin Filters Application Guide and look for these changes in your future orders of Baldwin filters. Performance Testing: Fuel (SAE J905) Efficiency % Capacity (g) BF970 90.56 13.2 1P2299 86.39 4.3 Caterpillar Fuel Filter Replacements Caterpillar 1P2299 = Baldwin BF970 Caterpillar 1R0740* = Baldwin BF7525* Caterpillar 1R0750 = Baldwin BF7633 *= Obsolete |
