what to do???
06-18-2006, 15:14
what to do???
I have a 6v92 put in the year of 2000 before I brought the 1984 1/2
PT40. It has less then 20 thousend miles. My problem is I have a
small leak of antifreeze in the oil. I took it in to a truck place
that repairs DD and they drop the pan and checked oil cooler and
liners for leaks, check water pump, put hose into water and bubbles
showed. Can not find the leak. Now they want BIG BIG bucks to replace
the head gaskets. Need input to know what to do or fine a dd mechanic
for help.
Joe 1984 1/2 PT40
06-18-2006, 15:17
what to do???
Joe,
What is your location?
> for help.
> Joe 1984 1/2 PT40
06-19-2006, 02:47
what to do???
we are located in South Bend Indiana
06-19-2006, 15:22
what to do???
If it is a small leak it might be worth a try to use some stop leak that you put
in the antifreeze. The products have improved and some new cars come with it
already installed. Check with Bennie and see what he thinks.
Dan
1981 FCRB 33
jackson, ms
Sent: Monday, June 19, 2006 9:47 AM
Subject: Re: [WanderlodgeForum] what to do???
