Bird won't start
06-19-2006, 13:30
Bird won't start
Been working on my recently purchased bird all weekend doing odd jobs.
Each time I am there I start it up and drive around the field and such. Saturday I took my first drive on a regular paved road. All went well and she drove great. Even better on a 4 lane highway. Came back and turned her off, all fine, little latter started up fine. Came by today and started right up. Came back a few hours later and installed new air filter and would not start. Just cranks over but will not start. Seems like it is not getting fuel??? I even tried a little starting fluid and it would catch for a few seconds but not stay running. For the past month she has always just kicked right over without a hitch... Any suggestions??? Thanks, Chris Reed 83 FC35 SB Plant City,FL |
06-19-2006, 14:55
Bird won't start
Isn't the fuel solinoid right there by the air filter? Maybe a wire came loose.
Dan 1981 FCRB33 Jackson, MS ----- Original Message ----- From: Chris To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 8:30 PM Subject: [WanderlodgeForum] Bird won't start Been working on my recently purchased bird all weekend doing odd jobs. Each time I am there I start it up and drive around the field and such. Saturday I took my first drive on a regular paved road. All went well and she drove great. Even better on a 4 lane highway. Came back and turned her off, all fine, little latter started up fine. Came by today and started right up. Came back a few hours later and installed new air filter and would not start. Just cranks over but will not start. Seems like it is not getting fuel??? I even tried a little starting fluid and it would catch for a few seconds but not stay running. For the past month she has always just kicked right over without a hitch... Any suggestions??? Thanks, Chris Reed 83 FC35 SB Plant City,FL [Non-text portions of this message have been removed] |
06-19-2006, 22:32
Bird won't start
If its 3208 you may have knocked the wiring to the fuel solenoid off. when you
turn the key on you should here the solenoid click. its a verticle mounted solenoid that sets on top of the fuel assembly. you can remove the solenoid and pull up on the fuel lever inside the service assembly if it cranks thats your prolem just push back down to shut it off. the solenoid is always hot when the key is on. re brake 1983 fc-35 sb " sage coach "sy -------------- Original message from "Chris" -------------- Been working on my recently purchased bird all weekend doing odd jobs. Each time I am there I start it up and drive around the field and such. Saturday I took my first drive on a regular paved road. All went well and she drove great. Even better on a 4 lane highway. Came back and turned her off, all fine, little latter started up fine. Came by today and started right up. Came back a few hours later and installed new air filter and would not start. Just cranks over but will not start. Seems like it is not getting fuel??? I even tried a little starting fluid and it would catch for a few seconds but not stay running. For the past month she has always just kicked right over without a hitch... Any suggestions??? Thanks, Chris Reed 83 FC35 SB Plant City,FL [Non-text portions of this message have been removed] |
06-20-2006, 03:02
Bird won't start
Open the "T" handle drain on the front then use the
priming fump, fuel then it's the shut off, no fuel, then it's a broken line of clogged filter. If the pump handle springs back, clogged filter. You can put one hand on the solenoid, the other on the key, turn Ign on-off and feel a slight vibration, hummm like. Contrary to what has been said about the fuel shut off lever, I think down is off, up is on. You can remove the two screws, then with a screwdriver or rod depress the lever. Could be stuck down. I am possibly wrong on this but either way the lever has to go up and down. Fuel is shut-off to stop a diesel engine, nothing else. Bob Greenville, SC > > -------------- Original message from "Chris" ----------- > > > Been working on my recently purchased bird all weekend doing odd jobs. > Each time I am there I start it up and drive around the field and such. > Saturday I took my first drive on a regular paved road. All went well > and she drove great. Even better on a 4 lane highway. Came back and > turned her off, all fine, little latter started up fine. Came by today > and started right up. Came back a few hours later and installed new air > filter and would not start. Just cranks over but will not start. Seems > like it is not getting fuel??? I even tried a little starting fluid and > it would catch for a few seconds but not stay running. For the past > month she has always just kicked right over without a hitch... > Any suggestions??? > Thanks, > Chris Reed > 83 FC35 SB > Plant City,FL > > > > > [Non-text portions of this message have been removed] > |
06-20-2006, 03:34
Bird won't start
check the two wires to the fuel shutoff solenoid. If you bumped them during
air filter change, may have broken one. dandarst86fc35rbhuntleyil. >From: "one_dusty_hoot" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Bird won't start >Date: Tue, 20 Jun 2006 15:02:06 -0000 > >Open the "T" handle drain on the front then use the >priming fump, fuel then it's the shut off, no fuel, >then it's a broken line of clogged filter. If the >pump handle springs back, clogged filter. You can >put one hand on the solenoid, the other on the key, >turn Ign on-off and feel a slight vibration, hummm >like. Contrary to what has been said about the fuel >shut off lever, I think down is off, up is on. You >can remove the two screws, then with a screwdriver >or rod depress the lever. Could be stuck down. I am >possibly wrong on this but either way the lever has >to go up and down. Fuel is shut-off to stop a diesel >engine, nothing else. > >Bob Greenville, SC > > > > -------------- Original message from "Chris" >----------- > > > > > > Been working on my recently purchased bird all weekend doing odd >jobs. > > Each time I am there I start it up and drive around the field and >such. > > Saturday I took my first drive on a regular paved road. All went >well > > and she drove great. Even better on a 4 lane highway. Came back >and > > turned her off, all fine, little latter started up fine. Came by >today > > and started right up. Came back a few hours later and installed >new air > > filter and would not start. Just cranks over but will not start. >Seems > > like it is not getting fuel??? I even tried a little starting >fluid and > > it would catch for a few seconds but not stay running. For the >past > > month she has always just kicked right over without a hitch... > > Any suggestions??? > > Thanks, > > Chris Reed > > 83 FC35 SB > > Plant City,FL > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > |
