cb and radio antenna
06-20-2006, 05:35
My 1988 FC35 originally had 2 factory roof antennas mounted to
brackets on the goat rail. I have the right hand side antenna but the left has only the bracket and the base. It looks like the right hand might be the radio and the left side for the CB. Is that correct? How do you access the CB radio . I removed the Wandersound dash and I can see the wiring from the handset going to a connector. But it seems like the connector goes somewhere under the dash? HELP Thanks: Bruce 1988 FC35 |
06-21-2006, 04:53
Bruce,
I am not 100% certain, But I think the CB is behind the passenger side kick panel. This panel was diffecult to remove the first time I accessed it. I removed the air vent loovers to grip and pull. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > My 1988 FC35 originally had 2 factory roof antennas mounted to > brackets on the goat rail. I have the right hand side antenna but the > left has only the bracket and the base. It looks like the right hand > might be the radio and the left side for the CB. Is that correct? How > do you access the CB radio . I removed the Wandersound dash and I can > see the wiring from the handset going to a connector. But it seems > like the connector goes somewhere under the dash? HELP > > Thanks: Bruce 1988 FC35 > |
06-21-2006, 05:31
Thanks Bill: Do you know which of the antennas is CB and which is radio?
Bruce 88 FC35 |
06-21-2006, 10:03
Sorry Bruce,
No help here, Our old radio/sterio and CB are still working, Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Thanks Bill: Do you know which of the antennas is CB and which is radio? > > Bruce 88 FC35 > |
