Steering box leak
06-22-2006, 01:12
Steering box leak
Hi all,
I had my two rear height adjustment valves replaced this morning. After
loading and unloading the air several times, the coach was level. Drove it back
to the camp ground and upon back into the space, it wants to lean to the left
side again. The left hand valve does not have any adjustment to it, either
on the rod or the valve arm itself. On the right one, there is an adjustment
on the arm, where the nut goes through adjusts it a little bit. Odd isn't
it that one valve would be adjustable and the other isn't.
On the way back from the garage all of a sudden the coach started to steer
really hard. I pulled over first chance and the steering box appears to be
leaking power steering fluid. Whereas I was only 4 miles from the camp ground
I filled the reservoir with psf and it drove okay, but is noticeably leaking.
When the engine cools down and the outside temperature, I will see if I can
see where the box is leaking or if it is a hose or hose connection.
Anyone's thought on this are appreciated, however, I think another trip to the
garage is in the very near future.
Hot and humid in SC, cannot wait to leave which is going to be soon.
Tom Meservey, USN (Ret)
'81FC33' Naval Weapons Station, Goose Creek, SC
06-22-2006, 05:21
Steering box leak
The fluid might have gotten on the P/S belt and pulleys and may be
slipping now. I had a similar issue when I left off the oil filler
cap for the Cat once (doh).
Tim Hannink
Winter Park, FL
1981 FC-33SB
--- In WanderlodgeForum@yahoogroups.com, tommy240842@... wrote:
> Hi all,
morning. After
Drove it back
to the left
it, either
an adjustment
Odd isn't
to steer
appears to be
the camp ground
noticeably leaking.
see if I can
connection.
another trip to the
soon.
06-22-2006, 10:10
Steering box leak
Hi Tom,
Tom Warner helped me through a PS problem recently. High steering
effort, chattering, squealing. I thought all the worst stuff (pump,
box, etc...) He urged a calm approach starting with the simple stuff -
- loose belt. He said "get a $20 Krikit (type I) belt tension meter,
and set the tension to 70 to 90 lbs." I built a tensioning device
using two small pieces of wood with a rough radius shape to seat on
the pulleys, as Tom suggested. I used a few inches of 1/4 20 stock
and a couple of nuts and washers to spread the blocks - worked like a
charm. Cost about $1. With the Krikit in hand I set the tension with
the belt tensioner device to desired tension + 35lbs, when the
tensioner was removed it was exactly where I wanted it to be. I then
re-tightened the bolts (3ea 5/8")
There's still a fluid leak somewhere, but so far, it sure steers
nice! (thanks Tom Warner!)
Good luck,
Danny
78 FC33
San Jose, CA
--- In WanderlodgeForum@yahoogroups.com, "Tim Hannink"
> Tim Hannink
> Winter Park, FL
> 1981 FC-33SB
> --- In WanderlodgeForum@yahoogroups.com, tommy240842@ wrote:
> > Hi all,
> morning. After
level.
> Drove it back
lean
> to the left
> it, either
> an adjustment
> Odd isn't
started
> to steer
> appears to be
> the camp ground
> noticeably leaking.
> see if I can
> connection.
> another trip to the
> soon.
