Ground Clearance
07-02-2006, 17:26
Ground Clearance
Hi, I am a wanabee. I haven't been able to find the ground clearance
for the Wanderlodges. I live 0.7 miles up a winding dirt road that has good traction, but has a couple of tight turns and a couple of spots that have the potential for high siding. Definitely don't want that to happen!!! I have been looking at the PT-40s and the FC-35s. Wheel base info would be helpful also. Thanks. |
07-03-2006, 12:08
Ground Clearance
Can't give you exact numbers but the generator is low on the FC35. Less than 10
inches I think. On the other side you have the dump valves as the lowest point. Kerry --- In WanderlodgeForum@yahoogroups.com, "what1not" > > Hi, I am a wanabee. I haven't been able to find the ground clearance > for the Wanderlodges. I live 0.7 miles up a winding dirt road that > has good traction, but has a couple of tight turns and a couple of > spots that have the potential for high siding. Definitely don't want > that to happen!!! I have been looking at the PT-40s and the FC-35s. > Wheel base info would be helpful also. > > Thanks. > |
