How Much Coolant to Drain???
07-05-2006, 11:10
You know you've drained enough when it stops leaking coolant at the
thermostat. (Sorry Curt, I couldn't resist). Kevin McKeown\ YL CA 86 38 PT [Non-text portions of this message have been removed] |
07-05-2006, 11:29
Thermostats and parts are on order for our 1987 8V92. How much coolant
will need to be drained to lower the coolant level to below the thermostat housings? -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
07-05-2006, 15:39
I thought about that when I posted my email. But remember, I have an
A-Hole, down the street that is always looking for reason to call code enforcement. Just trying to be good in the neighborhood. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. krminyl@... wrote: > You know you've drained enough when it stops leaking coolant at the > thermostat. > > (Sorry Curt, I couldn't resist). > > > Kevin McKeown\ > YL CA > 86 38 PT > > [Non-text portions of this message have been removed] > > |
07-05-2006, 16:54
Curt,
I caught about 3 gallons and about 1 gallon missed my bucket :-| There are 2 little 1/4" drain plugs on the "bowls" of the thermostat housings. I used a funnel with a long hose to catch the coolant in buckets. My Bird runs at much lower normal operating temps than before the thermosat change. Oil temp was 230, now 210 Coolant was 190, now 175 trans was 230, now 210-220 The thermostats increase in temp over time. 3 years ago the Bird was displaying temps very close to what they are today, after the thermostat change. I do plan to replace the water pump soon, prawly in August. Just preventative maint ;~] Jay Darst 85PT40 6V92DD MTB654CR Springfield, IL --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Thermostats and parts are on order for our 1987 8V92. How much coolant > will need to be drained to lower the coolant level to below the > thermostat housings? > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > |
07-05-2006, 17:36
Jay,
Thank you for that information. I'll have a couple 5 gal. buckets handy. I'm guessing the 8V will let out more coolant than the 6V. I'm thinking the same about the water pump. The engine mileage is at 87,000. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Jay Darst wrote: > Curt, > > I caught about 3 gallons and about 1 gallon missed my bucket :-| > > There are 2 little 1/4" drain plugs on the "bowls" of the thermostat > housings. I used a funnel with a long hose to catch the coolant in > buckets. > > My Bird runs at much lower normal operating temps than before the > thermosat change. > > Oil temp was 230, now 210 > Coolant was 190, now 175 > trans was 230, now 210-220 > > The thermostats increase in temp over time. 3 years ago the Bird was > displaying temps very close to what they are today, after the > thermostat change. > > I do plan to replace the water pump soon, prawly in August. Just > preventative maint ;~] > > Jay Darst > 85PT40 6V92DD MTB654CR > Springfield, IL > > --- In WanderlodgeForum@yahoogroups.com > > > > > > Thermostats and parts are on order for our 1987 8V92. How much > coolant > > will need to be drained to lower the coolant level to below the > > thermostat housings? > > > > -- > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > |
