Engine Swap
07-05-2006, 11:13
Engine Swap
It's been said in this forum in the past that the Series 60 is too tall to
fit in the usual space of a 92 Series Detroit. FWIW. Any other comments?
Kevin Mc
YL CA
86 38 PT
07-05-2006, 14:09
Engine Swap
Friends:
Knowledge abounds on this site. Some may think I am losing it but here
goes. Can a series 60 Detroit and an Allison world 6 speed trans be
installed in a 1990 WB-40 without major modifications? It would replace
an 8v92 and 5 speed. Sounds like a relatively inexpensive way to retro
a fine motor home. Second, is anyone in the Southeast planning to
attend the IHBA Drag Boat races in Gadsden AL. at the end of this month?
We will be staying at River Country Campround on the Coosa River. It
would be fun to see another Bird or two there. I will have two young
grandkids with me. Thanks.
Leroy Eckert
1990 WB-40
Nceville, FL.
07-06-2006, 01:38
Engine Swap
Thanks: Your input is much appreciated.
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Wednesday, July 05, 2006 10:13 PM
Subject: Re: [WanderlodgeForum] Engine Swap
Kevin Mc
YL CA
86 38 PT
07-06-2006, 12:22
Engine Swap
You might find a Cummins that will work. They have a more compact
engine. Real question is, will it have the HP you need and torque?
Seems to me, that about 2 years ago, someone visited this forum and
mentioned that combination.
R.E. (Ron) Marabito, Dallas, tX 92WB40
--- In WanderlodgeForum@yahoogroups.com, "jwasnewski"
> Friends:
> Leroy Eckert
> 1990 WB-40
> Nceville, FL.
07-06-2006, 15:14
Engine Swap
Ron--
Appreciate the information and forum history. My 8v92 is in fabulous shape, ( I
think), it runs dry, doesn't overheat, doesn't sling oil and doesn't drop oil
from the slobber tubes. It uses about a quart of oil each 1000 miles. That
should be OK for an 8v92 with 110,000 miles. Sometimes I wonder if it has oil
in the pan. I don't know, maybe it is getting ready to go boom. I hope not. I
just thought a new high tech engine would be a reasonable upgrade. I think I
better leave the 8v92 alone.
Thanks again,
Leroy Eckert
1990 WB-40
Niceville, FL.
Sent: Thursday, July 06, 2006 7:22 PM
Subject: [WanderlodgeForum] Re: Engine Swap
> Friends:
> Leroy Eckert
> 1990 WB-40
> Nceville, FL.
07-06-2006, 16:20
Engine Swap
Shhhhhhhh Leroy, there are people out there that would kill for an engine
like that. VBG
On 06/07/06, Leroy Eckert wrote:
> Ron--
> shape, ( I think), it runs dry, doesn't overheat, doesn't sling oil and
> doesn't drop oil from the slobber tubes. It uses about a quart of oil each
> 1000 miles. That should be OK for an 8v92 with 110,000 miles. Sometimes I
> wonder if it has oil in the pan. I don't know, maybe it is getting ready to
> go boom. I hope not. I just thought a new high tech engine would be a
> reasonable upgrade. I think I better leave the 8v92 alone.
> Thanks again,
> Leroy Eckert
> 1990 WB-40
> Niceville, FL.
> From: ronmarabito2002
> "jwasnewski"
> > Friends:
> > Leroy Eckert
> > 1990 WB-40
> > Nceville, FL.
Rob, Sue & Merlin Robinson
94 WLWB
07-07-2006, 13:11
Engine Swap
Leroy:
If the engine has been maintained properly and continues so, it
should outlast your ownership. That engine is just now broken in.
> Ron--
fabulous shape, ( I think), it runs dry, doesn't overheat, doesn't
sling oil and doesn't drop oil from the slobber tubes. It uses about
a quart of oil each 1000 miles. That should be OK for an 8v92 with
110,000 miles. Sometimes I wonder if it has oil in the pan. I don't
know, maybe it is getting ready to go boom. I hope not. I just
> Thanks again,
> Leroy Eckert
> 1990 WB-40
> Niceville, FL.
> > Friends:
but here
replace
retro
this month?
River. It
young
> > Leroy Eckert
> > 1990 WB-40
> > Nceville, FL.
01-08-2008, 14:23
Engine Swap
I finished ny engine swap today. I replaced the original 3206NA with
a reman 3208 from Reviva ( see http://www.reviva.com). While I had the
engine out I replaced and repaired seberal other things. I installed
a new starter (Elreg distributors ltd $221 for a new starter) a new
Power steering pump (from Hydra steer $518 - Eaton RP1G). Also
replaced the transmission filter and fluid. I sand blasted the
pullies and several engine pieces that I had to swap over. I also did
the swing rad mod. I used #12 hydrolic hoses and fittings in order to
keep the 5-8 ID of the original lines. I read that if you go to 1-2ID
hoses I read that the flow rate goes from 17GPM to 11GPM. The hoses
were expensive $260 and are rated to 3000psi which is way overkill.
The engine change out was not that difficult. After removing the rad,
dog house, etc the engine had to be lifted in order for the exhaust
manifolds to clear the main frame rails, then it was straight out the
front. There is only about 1 eighth on an inch on either side. The
rubber fuel lines from the frame of the bus the the engine were in
bad shape. If you ave a bus the same vintage you might want to check
them. Power steering supply line (low pres) was also in bad shape.
New engine has the 3 ring piston. Initial start was immediate as they
run their engines before they are shipped. Noticiable difference in
the amount of white smoke on a cold start. Also engine is quieter. I
think that my old engine has a bit of piston slap noise and prob some
valve train noise.
I have not had it on the road yet but am looking forward to see if
there is a power difference.
Pete
Prairie Dog
78 Fc 35 foot
Courtenay BC
01-08-2008, 14:38
Engine Swap
Pete,
I assume you mean there was less white smoke on a cold start?
I also have a 1978 N/A coach. I am not ready to do an engine swap
but I wondered how you lifted the engine. Did you use a jack from
below? Did you pull out the engine and trans together, or did you
uncouple them while still in the chassis?
And last, but not least, did you photograph the event?
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "susanmarycamilleri"
with
installed
new
did
to
2ID
hoses
rad,
exhaust
check
they
in
I
some
> valve train noise.
> Pete
> Prairie Dog
> 78 Fc 35 foot
> Courtenay BC
01-08-2008, 14:51
Engine Swap
I noticed a couple of mistakes in my original post.I replaced my 3208
not 3206.
Yes almost no white smoke on a cold start (4degrees C). To lift the
engine I used a 2 ton folding engine crane at the front and a 2 ton
floor jack at the back with a T bracked welded to the floor jack and
bolted to the rear underside of the engine. I left the transmission
in the bus resting on a motorcycle jack stand. I separated the engine
anf trans at the flex plate. ie left the torque converter in the
transmission.
I did take some pictures in order to remember how things went back
together.
Pete
Prairie Dog
78 35 FC
> Pete,
> Gardner
> 78FC33
> with
> installed
> new
> did
order
> to
> 2ID
> hoses
overkill.
> rad,
> exhaust
> the
The
in
> check
> they
> in
quieter.
> I
> some
> > valve train noise.
if
> > Pete
> > Prairie Dog
> > 78 Fc 35 foot
> > Courtenay BC
