Generator Wiring Diagram
07-05-2006, 15:18
Does any one out there have a wiring diagram for the 12.5 KW Kohler
generator in the 83FC35? I am having to replace all the wire connectors
to that large start/relay box, they were corroded off. Also had to
replace the 3 relays. My bus did not come with any wiring
diagrams...Any help would be great...also, when I hold down my brake, I
can hear air leaking out and my air pressure gauge for the rear drops.
Is this normal or the sign of a bad air leak???
Thanks
Chris Reed
83 FC35 Sb
Plant City, FL.
07-06-2006, 16:41
Chris:
There are schematics in the files section that should fit your gen set. As
to the air leak, NO, that is not normal. Sounds like you have a leaking
break pedal valve. That is one air leak you need to find and address, soonest.
Safe travels,
>Thanks
>Chris Reed
>83 FC35 Sb
>Plant City, FL.
