headlight upgrade problem
07-06-2006, 08:57
I was in the middle of some repairs and had to use the coach for a
medi-vac type thing. Hence I did the headlamp upgrade very quickly. I
used one relay for the low beams and one for the high beams. Brand new
circuit breakers for both of them. Everything seemed fine. We left
right before dusk for a 700 mile trip (one way). When I turned the
headlights on at dusk, the drivers side light was cutting in and out
randomly. Since I wasn't in a position to stop and check the
connections, we just keep going. After about two hours, it came on
steady and has stayed on consistantly. Originally I thought maybe I
didn't have the relay grounded that well ( I still think I'll re-do
that ). But if that was the problem, wouldn't both lights have been
cutting in and out? Any thoughts?
Tom Sorrentino
Bedford Hills, NY
1978 fc 33'
07-06-2006, 09:51
Tom,
Test that headlight and socket to see if you can duplicate the problem.
Be sure the socket wires are all clean/tight and the socket fits snug to
the headlight. I have new sockets if you need them. I don't like things
that FIX themselves...scary.
> Tom Sorrentino
> Bedford Hills, NY
> 1978 fc 33'
07-06-2006, 14:21
Tom,
Don't know why only one would flicker, but I doubt it is the ground.
When I did my upgrade, my ground worked loose, and it resulted in
the relay burning up with considerable smoke and horrible odor. Had
to drive home on park lights & driving lights. You problem sounds
like it is probably down stream of the relay.
Scott Forman
82 FC35RB
Memphis
--- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino"
I
new
out
> Tom Sorrentino
> Bedford Hills, NY
> 1978 fc 33'
