Alternator / charging help
07-11-2006, 05:57
When I took the Bird in for an oil change, tune up etc I noticed that
the belt for the front alternator (ALT #1) was off, lying on the
frame. Had Inland Diesel replace all belts and this alternator was
brought back on line. When we started the Bird this morning there was
no charge at all to any batteries either coach side or engine side.
Is there a relay that might be hanging up or circuit breaker that is
easy to over look? We took off ALT #1 and are having it checked as we
type.
Thanks
Steve Quandt
93 PT-40
Iron Mountain, MI
07-11-2006, 09:44
Steve, On my 93 the #1 alternator is the one on the right side of the
coach down low next to the rear bumper. The #2 Alternator is the one on
the left side of the coach that's really hard to get to usually done
thru the bedroom floor. This #1 and #2 Alternator position corresponds
to the alternator charge indicator on the dash pane Usually if you have
problem's with the system it's the #2 alternator It has a very long
cable and is somewhat undersized. When it goes bad it's easy to just
take the belt off and forget it.??? and rely on the #2 which is easy to
change and work on. If they had the belt off (not sure which one)
chances are their was a reason. Check your voltage on the large
electrical bus panel on the firewall by the battery, this will tell you
how much and which gen is putting out. Good luck...Bob 93pt, Illinois
was
we
> type.
> Thanks
> Steve Quandt
> 93 PT-40
> Iron Mountain, MI
