Exhaust problem
07-12-2006, 06:07
Exhaust problem
I've run into a problem with the connection of the two exhaust manifolds,
(tubes, pipes)
that run across the top of my 8V92 engine. I've had the connection loosen twice
before,
one time causing the alternator to be fried and replaced. The last time I
'fixed', sic. it, it
held for about a year and a half but this year driving north from Florida I
could hear the
engine getting louder as the pipes loosened and finally began to blow black
smoke as we
traveled home from the Myrtle Rally. As those of you who attended that rally
know my
mechanical prowess is not great, hence the first annual 'broken but here' award
holds a
dear spot in my coach, therefore I ask if any one else has had the following
problem and
how did you solve it?
The problem seems to be that the, (sorry about the nomenclature), connections
from pipe
to pipe do not clamp down properly. On one side there is a flange?? that is
clamped to the
left hand (looking forward) pipe as it crosses over the engine. It has a curved
end that the
curved clamp, clamps to.
On the other side there is a ring that is supposed to slip over that pipe and I
think it is
supposed to clamp down on the pipe running to the right side. Trouble is there
is space
between that ring and the pipe and the clamp does not clamp but has play. The
last time I
'fixed' it I put a piece of curved thin metal between the ring and pipe and
peened down the
right side edges of the clamp to make contact.
Perhaps I'm missing some other piece or there is some material that I could fill
the space
with so that the clamp clamps. Or maybe someone else has had this problem and
has a
great fix. Thanks in advance
I am adding a url to a page with pictures to go with the text to make my
explanations
clearer.
http://bennersfarm.com/BF%20Home/Bluebir...lemma.html
thanks again.
07-12-2006, 08:11
Exhaust problem
Bob:
I had a similar problem based on your description. When my wife gets home I'll
have her scan a drawing I made. I do not know how to find it in the computer.
When you get the drawing tell me if the area is what you are describing.
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Wednesday, July 12, 2006 1:07 PM
Subject: [WanderlodgeForum] Exhaust problem
(tubes, pipes)
twice before,
could hear the
smoke as we
know my
award holds a
problem and
from pipe
clamped to the
curved end that the
I think it is
is space
last time I
peened down the
fill the space
has a
explanations
clearer.
thanks again.
07-12-2006, 08:34
Exhaust problem
Bob:
Let me try to send the drawing. If you do not recieveit, send me your email and
I will attach it to the return email.
Leroy Eckert
1990 WB-40
Niceville, FL
jwasnewski@...
(tubes, pipes)
twice before,
could hear the
smoke as we
know my
award holds a
problem and
from pipe
clamped to the
curved end that the
I think it is
is space
last time I
peened down the
fill the space
has a
explanations
clearer.
thanks again.
01-02-2010, 06:02
Exhaust problem
Hi all: Mike Bulriss is down here at S. Padre Island with me and discovered
that he had a cracked flange on the pipe connection between the drivers side
manifold and the turbo on an 8V92.
If anyone has one, let me know, otherwise we will have to drive 150 miles to the
nearest supply on Monday. He was planning to depart tomorrow morning.
If this flange breaks off, he will lose his turbo boost and lay a smokescreen
for atleast a mile.
R.E. (ron) Marabito, Dallas, TX 92WB40
