galley monitor panel
04-18-2005, 09:47
Hi all,
I recently had my galley monitor panel inspected and serviced by pmmi
and after installation it will not power up. I am assuming it is a
blown fuse, but do not have a fuse map/diagram to know which one to
change out. How would I go about finding a diagram for my bird?
Thanks.
Michael Steinbacher
1990 wlsp 36
sacramento, ca
04-18-2005, 11:36
I show it in the LH front electrical component panel, wire should be
orange marked #15, a fuse, top of row, SK19, it is a 2A fuse.
First check to be sure you have the electronic master switch turned on.
- Jeff Miller
http://www.wanderlodge.net
--- In WanderlodgeForum@yahoogroups.com, "steinbachermichael"
<mgstein@h...> wrote:
> Hi all,
> Thanks.
> Michael Steinbacher
> 1990 wlsp 36
> sacramento, ca
04-18-2005, 13:33
Hello Mike
BB might have a wiring schematic for your bird, but
its hard to figure out. Anyhow, Go to your LEFT
OVERHEAD E-Panel, its behind the rear wall in the the
left front overhead cabinet. Take that wall out, its 4
phillips screws kind of hidden in the cloth cover of
the plywood, and you will see the E-Panel. You will
see 3 circuit blocks. Look on the left circuit block,
which is Block A, and find C/B # 17, second column
second C/B from bottom and that should be the System
Monitor Panel C/B. Pull the fuse and check it. (If
some one else before you had the coach totally
re-wired, then 3+/-6 years of research will get you
your answer. Check with Randy first though.) If you
can find this C/B as I described, then maybe I can
help you by sending you a list of C/B's and their
panel location.
Good Luck
Juergen in PA (sunny 72)
1991 WLSP36
--- steinbachermichael <mgstein@...> wrote:
> Hi all,
> serviced by pmmi
> assuming it is a
> know which one to
> for my bird?
> Thanks.
> Michael Steinbacher
> 1990 wlsp 36
> sacramento, ca
Do You Yahoo!?
http://mail.yahoo.com
04-18-2005, 13:42
Jeff, I show your C/B as the dashclock on block A C/B
#15
Juergen in PA
1991 WLSP36
> 2A fuse.
> - Jeff Miller
> > Hi all,
> assuming it is a
> know which one to
> > Thanks.
> > Michael Steinbacher
> > 1990 wlsp 36
> > sacramento, ca
Do you Yahoo!?
Plan great trips with Yahoo! Travel: Now over 17,000 guides!
http://travel.yahoo.com/p-travelguide
04-18-2005, 14:28
I took the information from an '89 SP circuit diagram Juergen, shows
fuse as 19, wire as 15. I don't know if the wiring was changed in '91
with the other changes or ??
I did think about pulling your CD and checking to see what the '91
wiring is, glad you checked also.
Sounds like we're in the same cabinet anyway? Does yours show a 2A
fuse?
I'm still hoping his electronic master switch is off.
- Jeff Miller
--- In WanderlodgeForum@yahoogroups.com, john duke
> #15
> Juergen in PA
> 1991 WLSP36
> > 2A fuse.
> > - Jeff Miller
> > > Hi all,
> > assuming it is a
> > know which one to
> > > Thanks.
> > > Michael Steinbacher
> > > 1990 wlsp 36
> > > sacramento, ca
> Do you Yahoo!?
04-21-2005, 02:33
Hi Jeff
As far as wiring is concerned, and knowing who
designed it plus all the ?? inbetween owners who
modified something, anything is possible. So far I
found that all my fuses /circuit numbers matched my
wiring that i finally deciphered a little more. But
still must check each item, problem as it comes up.
YES, I believe that 89 SP's have very likely different
wiring set-ups, but as you said, at least we are in
the same closet.
Juergen in PA (60 and cloudy, no snow)
1991 WLSP36
> was changed in '91
> see what the '91
> yours show a 2A
> fuse?
> off.
> - Jeff Miller
> C/B
> > #15
> > Juergen in PA
> > 1991 WLSP36
> is a
> > > 2A fuse.
> > > - Jeff Miller
> > > > Hi all,
> inspected
> I am
> > > assuming it is a
> to
> > > know which one to
> > > > Thanks.
> > > > Michael Steinbacher
> > > > 1990 wlsp 36
> > > > sacramento, ca
> > Do you Yahoo!?
> 17,000 guides!
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
http://smallbusiness.yahoo.com/resources/
04-25-2005, 05:20
Hi John and Jeff,
Sorry it took me awhile to get back with you. Thank you for your
responses regarding the fuse location. Actually you were both
incorrect in the location, sorry. I received an email from Bennie,
back at Wanderlodge, and informed me that the fuse was in LH
overhead cabinet above the dinette (I finally found it). It was
breaker number #19, a 2 amp fuse. By the way, in the LH overhead
front, over driver's side, their isn't a fuse panel their at all.
Thanks again, and thanks to this forum.
Michael Steinbacher
1990 WLSP 36
Sacramento, CA
> Hi Jeff
> the same closet.
> 1991 WLSP36
> > was changed in '91
> > see what the '91
> > yours show a 2A
> > fuse?
> > off.
> > - Jeff Miller
> > C/B
> > > #15
> > > Juergen in PA
> > > 1991 WLSP36
> > is a
> > > > 2A fuse.
> > > > - Jeff Miller
> > > > > Hi all,
> > inspected
> > I am
> > > > assuming it is a
> > to
> > > > know which one to
> > > > > Thanks.
> > > > > Michael Steinbacher
> > > > > 1990 wlsp 36
> > > > > sacramento, ca
> > > Do you Yahoo!?
> > 17,000 guides!
> Do you Yahoo!?
