Boilers vs Alternator when driving with gen on. 78fc33
07-18-2006, 08:54
While under way with the gen on, are the boilers and the alternator
fighting each other to charge the batteries? If so, that seems like a recipe for smoke. Thanks, Danny 78 FC33 San Jose, CA |
07-18-2006, 10:33
Dan I would venture to say NO there isn't a conflict if the systems are
working correctly. I run down the road as many others do with my genny wide open giving me 120V AC. By the by, if you boilers then maybe you should consider IOTA or some other replacement. On 18/07/06, Dan > > While under way with the gen on, are the boilers and the alternator > fighting each other to charge the batteries? > > If so, that seems like a recipe for smoke. > > Thanks, > > Danny > 78 FC33 > San Jose, CA > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
07-18-2006, 17:13
Hi Rob,
I think you are right. Jeff on the other forum posted that the alternator contributes as needed. So if the boilers are satisfying the set point in the alternator, it does nothing. I am still in "dating" my Bluebird, which I bougt in May. What I mean is, when I commit, I will replace the chargers, the oven, get a backup camera, an inverter etc... So far it has been lots of little fixes, so we'll see if the romance pans out when I get my family out in it. Thanks for the advice on the chargers though! Danny 78FC33 San Jose, CA --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Dan I would venture to say NO there isn't a conflict if the systems are > working correctly. I run down the road as many others do with my genny wide > open giving me 120V AC. By the by, if you boilers then maybe you should > consider IOTA or some other replacement. > > On 18/07/06, Dan > > > > While under way with the gen on, are the boilers and the alternator > > fighting each other to charge the batteries? > > > > If so, that seems like a recipe for smoke. > > > > Thanks, > > > > Danny > > 78 FC33 > > San Jose, CA > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
07-18-2006, 18:46
Your welcome. When you get ready to do the 'backup camera' thing check out
http://www.rvcams.com Several of us, including myself, have found them helpful and fair priced. Tim is the guy to talk to. On 18/07/06, Dan > > Hi Rob, > > I think you are right. Jeff on the other forum posted that the > alternator contributes as needed. So if the boilers are satisfying > the set point in the alternator, it does nothing. > > I am still in "dating" my Bluebird, which I bougt in May. What I > mean is, when I commit, I will replace the chargers, the oven, get a > backup camera, an inverter etc... So far it has been lots of little > fixes, so we'll see if the romance pans out when I get my family out > in it. Thanks for the advice on the chargers though! > > Danny > 78FC33 > San Jose, CA > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > Dan I would venture to say NO there isn't a conflict if the > systems are > > working correctly. I run down the road as many others do with my > genny wide > > open giving me 120V AC. By the by, if you boilers then maybe you > should > > consider IOTA or some other replacement. > > > > On 18/07/06, Dan > > > > > > While under way with the gen on, are the boilers and the > alternator > > > fighting each other to charge the batteries? > > > > > > If so, that seems like a recipe for smoke. > > > > > > Thanks, > > > > > > Danny > > > 78 FC33 > > > San Jose, CA > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
