Need Hep AC replacement???
07-19-2006, 03:16
1. My Air Conditioners are all broken and I would like to replace
them.
a. 1991 BlueBird WLWB
2. Current Air Conditioner
a. Dometic
b. Penguin
c. 13,500 btu
d. ducted
e. remote thermostat ( analog )
f. no heat strip
e. part number - 620015.405
3. Problem
a. I have called Bluebird, Dometic, Camping World, and a couple
of local distributers, and with each phone call have received a
different part number for replacement of my old ac unit. The best
part is that Dometic has even given me different part number
replacements with successive phone calls.
4. Has anyone replaced their AC units and if so
a. what part numbers for the AC unit and the thermostat
b. analog or digital
c. how much rewiring was required.?
d. do all newer dometic ac units have the same mounting hole
locations relative to the hole in the roof of the coach?
5. Dometics Customer Service is one of the worst.
a. near to impossible to get anyone on the phone.
b. absolutely no idea of their own products.
c. if I already did not have a Dometic, then I would shop for
something else.
Thanks
Burton and Charmaine "Hot and Miserable"
Salt Lake City, UT
1991 WLWB
07-19-2006, 05:55
I have a damaged unit (thanks to a large tree branch -- it apparently
was pushed up by the King Dome at the very front of the coach, then
rebounded onto the front AC unit ... and my rear AC unit vibrates
like crazy (although it still cools). The center AC runs pretty much
as expected.
I was thinking of replacing two of the units with high efficiency
units. Both Coleman and Dometic make a 13500 btu 10 amp AC --
compared to the 15.5 amps (each) of the current units on my 'bird.
See further comments below...
aeonix1@...
'95 Bluebird Wanderlodge WBDA 4203
El Sobrante, CA
> them.
> a. Dometic
> b. Penguin
> c. 13,500 btu
> d. ducted
> f. no heat strip
Mine are "penguin" -- model 600315.221 -- othwise similar.
> 3. Problem
I contacted Dometic by email through their web site had had several
exchanges with them at customersupportcenter@...
They were able to answer my questions...
I am told that the DuoTherm High Efficiency Brisk Air AC (10 amps)
can be used on my coach. Model number 59530. That it will work with
the ducted system. And, finally that the thermostat (with "Assy #
3105356.024 on the circuit board) will work with the new AC.
> something else.
My experience via email was quite different --- answers were prompt
(within 24 hours) and they asked for additional info which I provided
and again responded promptly. They also provided a PDF with
installation instructions so that I could examine the current
installation and see how the new unit would compare.
It is important to note that the Penguin units are a low profile
design and the 10 amp unit is about 3.5 inches taller. On my coach
this will not present a problem as the King Dome already is about
that much taller (so I'm not losing any clearance). The swap on other
coaches may present a loss of height clearance.
07-21-2006, 23:56
burthum; Last year I replaced the center A/C on my 91 BB. had to go back to
the same unit I had in the coach. went to 15000 btu .the reason was the
wiring in the BB.It has the flat ribbon wire and if you change that over it
takes a lot of rewiring. They said it would cost apprx $700.00 for the
rewire.I am happy with the new unit.Dave WBPT 40
>From: "burthum"
>Subject: [WanderlodgeForum] Need Hep AC replacement???
>Date: Wed, 19 Jul 2006 15:16:34 -0000
>them.
> a. Dometic
> b. Penguin
> c. 13,500 btu
> d. ducted
> f. no heat strip
>3. Problem
>something else.
>Thanks
>Salt Lake City, UT
>1991 WLWB
