Paint
07-24-2006, 14:14
Paint
Leroy, are you doing touchup or a repaint? I love the looks of the 88
to 90 wbpts. Some of the stripe colors they introduced in the 90's
got less classic and more personal. I often wondered if BB just
allowed customers to make these design crimes in special order
coaches. A fun thing to do is manipulate the color of your coach in
a paint program. Doesn't sound like it will hurt to get creative
with the colors if you are thinking of a repaint.
while looking for a coach when I read "custom paint" it had the same
effect as "she's got a pretty face"
94pt gray silver pink and green
missing a chandelier and piano
--- In WanderlodgeForum@yahoogroups.com, "jwasnewski"
> Curt:
> I talked to Steve Birtles today about my paint codes. He says you
may
> be able to decifer the numbers. I have not had success. Numbers
> follow:
> 92329----No clue what this number means.
> 73773----Base--Light silver--Frito-Lay Fleet I believe.
> 81573----Stripe--there are two different colored stripes.
> 79780----Light
> 81735----Dark
> Colors are---Light silver, dark silver, turquoise stripe, salmon?
> mauve? stripe.
> Thanks:
> Leroy Eckert
> 1990-WB-40
> Niceville, FL
07-24-2006, 14:24
Paint
Lets try this again
Leroy will probably chime in on this the second code I believe is 79773
The first I have no idea
Stephen 77fc35
> leroy will probaly ship in but the second code i beilve should be
> 79773 ithink thats what he said it was and the first I have no idea
> Stephen 77fc35
> --- In WanderlodgeForum@yahoogroups.com, "lcondosta"
> > 81573 med lagoon met ford motor co 79780cumulus gray met ford motor
> > co 81735 rose met ford motor co other two must be wrong codes Lee
> > A Condosta BASF Jobber Holden Beach N.C 85PT40--- In
> > wrote:
> > > Curt:
> > may
> > > follow:
> > > 79780----Light
> > > 81735----Dark
> > > mauve? stripe.
> > > Thanks:
> > > Leroy Eckert
> > > 1990-WB-40
> > > Niceville, FL
07-24-2006, 15:35
Paint
Gregory: Not thinking about a repainting. The paint is in fabulous shape, not
a scratch anyplace except a couple of recent chips that I did while changing the
broken end of the main Zip Dee awning brace. I dropped the main awning on the
side of the coach. Ouch! Dumb! It could have been worse.
I don't know about the paint or design on our girlie bus---turquoise and rose
over two tone gray---but our interior was altered by the original owner during
construction. Our interior is top notch. I have been told that Royal did the
interior, haven't been able to verify. Got Steven Birtles looking into it
although it really doesn't mean anything, talking points maybe. The idea of
repainting has previously been squashed by the wife. Thanks for the response.
Were you referring to Liberace? Don't forget the cape. LOL
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Monday, July 24, 2006 9:14 PM
Subject: [WanderlodgeForum] Re: Paint
> Curt:
may
> follow:
> 79780----Light
> 81735----Dark
> mauve? stripe.
> Thanks:
> Leroy Eckert
> 1990-WB-40
> Niceville, FL
07-24-2006, 15:45
Paint
Lee: Thanks much for the reply. A double check shows 73773 should have been
79773. The 92329 number is stamped in the upper left hand corner of the paint
code sticker. So, 79773 is the correct number. Can I purchase the paint from
you? I haven't found any locally. Need it for touch up purposes. What is the
shelf life?
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Monday, July 24, 2006 8:01 PM
> Curt:
may
> follow:
> 79780----Light
> 81735----Dark
> mauve? stripe.
> Thanks:
> Leroy Eckert
> 1990-WB-40
> Niceville, FL
07-24-2006, 16:05
Paint
leroy, if it is touchup I would just take the bus to a good dealer
autobody shop and get an out the door quote ( may be less expensive
than you think). Chances are that the paint color will change with
the transfering out of the 1990's restricted formulas. and in the
quart mininum mix quantities you will need you are talking over 400.
bucks. A good shop can site mix and blend. you won't get the code
excuse "but sir that is the paint code you ordered." Prism in the
metalic paints is also something that will be hard to match unless
you have special skills. maybe the paint code is a royal number. Bob
and Dixie G have a 92 Royal conversion, I wonder if they have info on
the codes.
94pt no Royality
Romoland Ca
fabulous shape, not a scratch anyplace except a couple of recent
chips that I did while changing the broken end of the main Zip Dee
awning brace. I dropped the main awning on the side of the coach.
turquoise and rose over two tone gray---but our interior was altered
by the original owner during construction. Our interior is top
notch. I have been told that Royal did the interior, haven't been
able to verify. Got Steven Birtles looking into it although it
response.
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Gregory OConnor
the 88
90's
in
same
> Gregory O'Connor
> > Curt:
you
> may
> > follow:
> > 79780----Light
> > 81735----Dark
salmon?
> > mauve? stripe.
> > Thanks:
> > Leroy Eckert
> > 1990-WB-40
> > Niceville, FL
07-25-2006, 09:17
Paint
Gregory: I did think about shading differences etc. You are
probably correct. I may get a bid from the local paint shop. The
area that I screwed up is on the entry door, maybe 2x3. Didn't dent
anything, just scratched and chipped the paint, obviously right where
I can constantly see the damage. Thanks for the input.
Been gone from CA for awhile. Isn't Romoland between Riverside and
Temecula or Hemet? Lived in Riverside for 25yrs
Leroy Eckert
1990WB-40
Niceville, FL
-- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor"
400.
Bob
on
> the codes.
> Gregory O'Connor
> 94pt no Royality
> Romoland Ca
altered
> response.
> > Leroy Eckert
> > 1990 WB-40
> > Niceville, FL
> the 88
> 90's
coach
> in
creative
> same
> > Gregory O'Connor
> > wrote:
> > > Curt:
> you
> > may
Numbers
> > > follow:
> > > 79780----Light
> > > 81735----Dark
> salmon?
> > > mauve? stripe.
> > > Thanks:
> > > Leroy Eckert
> > > 1990-WB-40
> > > Niceville, FL
07-26-2006, 13:09
Paint
--Leroy 79773-Indian silver met ford motor co. Would like to help
but the freight would be more than the paint cost Check BASF.com for
a paint dist. near you. Lee Condosta Holden Beach N.C 85PT40 In
should have been 79773. The 92329 number is stamped in the upper
left hand corner of the paint code sticker. So, 79773 is the
correct number. Can I purchase the paint from you? I haven't found
any locally. Need it for touch up purposes. What is the shelf life?
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: lcondosta
motor
Lee
> > Curt:
you
> may
Numbers
> > follow:
> > 79780----Light
> > 81735----Dark
salmon?
> > mauve? stripe.
> > Thanks:
> > Leroy Eckert
> > 1990-WB-40
> > Niceville, FL
07-26-2006, 16:57
Paint
Leroy, If you get back to California look me up. Romoland is south
of March Air Field. A scratch here or there adds character. Wonder
if a BB Bird decal would do the trick.
94ptRomoland Ca
dent
where
> Leroy Eckert
> 1990WB-40
> Niceville, FL
dealer
expensive
with
> the
> 400.
code
unless
> Bob
info
> on
> > the codes.
> > Gregory O'Connor
> > 94pt no Royality
> > Romoland Ca
Dee
coach.
> altered
been
> the
> > response.
> > > Leroy Eckert
> > > 1990 WB-40
> > > Niceville, FL
of
> > the 88
> > 90's
just
order
> coach
> > in
> creative
> > same
> > > Gregory O'Connor
> > > wrote:
> > > > Curt:
says
> > you
> > > may
> Numbers
> > > > follow:
> > > > 79780----Light
> > > > 81735----Dark
> > salmon?
> > > > mauve? stripe.
> > > > Thanks:
> > > > Leroy Eckert
> > > > 1990-WB-40
> > > > Niceville, FL
07-26-2006, 23:42
Paint
Gregory: Hopefully we can travel to CA next summer. Sounds like I'll need a
class A license pulling a trailer. 7000 pound flat trailer with auto. The
grandkids go back to school next week, that will limit our travel area. Leaving
this afternoon for the IHBA boat drags in Gadsden, Alabama. My friend Don
Ermshar, Riverside, CA is currently second in points, Blown Alchohol Flat
Bottom doing 178MPH in the 1/4, on water. He's now 65 and has a screw loose.
Also have friends in Hemet, Temecula and Aguanga.
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Wednesday, July 26, 2006 11:57 PM
94ptRomoland Ca
dent
where
> Leroy Eckert
> 1990WB-40
> Niceville, FL
dealer
expensive
with
> the
> 400.
code
unless
> Bob
info
> on
> > the codes.
> > Gregory O'Connor
> > 94pt no Royality
> > Romoland Ca
Dee
coach.
> altered
been
> the
> > response.
> > > Leroy Eckert
> > > 1990 WB-40
> > > Niceville, FL
of
> > the 88
> > 90's
just
order
> coach
> > in
> creative
> > same
> > > Gregory O'Connor
> > > wrote:
> > > > Curt:
says
> > you
> > > may
> Numbers
> > > > follow:
> > > > 79780----Light
> > > > 81735----Dark
> > salmon?
> > > > mauve? stripe.
> > > > Thanks:
> > > > Leroy Eckert
> > > > 1990-WB-40
> > > > Niceville, FL
07-27-2006, 03:50
Paint
Leroy, Class A is needed for trailers at and above 10,000# GVW even
if they are empty. 5th wheel at or above 15,000# GVW. CHP pulls out
these rules when it looks like the driver is being unsafe.
The easiest way to beat a ticket is by default - when the CHP officer
does not showup in court. I was cited by a Officer J Kennedy and
rescheduled court for 'Good Friday'. When Officer H. Grinblatt gave
me a ticket I rescheduled for the start of 'Yom Kippur'. My most
recent ticket was isued by Officer Ms. Kimberly C.
I sent a check. Women can multitask.
94ptRomoland Ca
I'll need a class A license pulling a trailer. 7000 pound flat
trailer with auto. The grandkids go back to school next week, that
will limit our travel area. Leaving this afternoon for the IHBA boat
drags in Gadsden, Alabama. My friend Don Ermshar, Riverside, CA is
currently second in points, Blown Alchohol Flat Bottom doing 178MPH
in the 1/4, on water. He's now 65 and has a screw loose. Also
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
south
Wonder
> Gregory O'Connor
> 94ptRomoland Ca
The
> dent
> where
> > Leroy Eckert
> > 1990WB-40
> > Niceville, FL
> dealer
> expensive
> with
> > the
over
> > 400.
> code
> unless
number.
> > Bob
> info
> > on
> > > the codes.
> > > Gregory O'Connor
> > > 94pt no Royality
> > > Romoland Ca
recent
Zip
> Dee
> coach.
> > altered
top
> been
it
of
for
> > the
> > > response.
> > > > Leroy Eckert
> > > > 1990 WB-40
> > > > Niceville, FL
> of
> > > the 88
> > > 90's
> just
> order
> > coach
> > > in
> > creative
> the
> > > same
> > > > Gregory O'Connor
> > > > wrote:
> > > > > Curt:
> says
> > > you
> > > > may
> > Numbers
> > > > > follow:
> > > > > 79780----Light
> > > > > 81735----Dark
> > > salmon?
> > > > > mauve? stripe.
> > > > > Thanks:
> > > > > Leroy Eckert
> > > > > 1990-WB-40
> > > > > Niceville, FL
