Racor Information
07-20-2006, 10:49
Racor Information
Not sure if this has made it to the Wanderlodge Forum site, but, here
goes with an apology if you were already aware.
The new Racor Drop in paper Elements have changed color slightly.
There is a reason for that. They no longer fit the old Racor Housings.
Racor has a free of charge spacer to be placed in the housing. The new
filters are slightly shorter. Without this spacer, a large quantity of
fuel bypasses the filtration process. Just thought I'd pass this on
from the marine industry.
Boatless and still looking for the right Bird.
Dave in St. Petersburg
07-20-2006, 12:00
Racor Information
Dave, HUH?? I did not know that. Wait could you please tell us/me more?
My personal email is cme4boats at aol. com. I would like to find out
more about that.
Thanks in advance for the heads up.
ScottB
86FC35
SC
--- In WanderlodgeForum@yahoogroups.com, "boatsarefunus"
Housings.
new
of
07-20-2006, 12:29
Racor Information
> more about that.
Information like that should be posted here for all to see rather than
e-mailing you Scott. If it's important enough for you, it's important
for us...LOL. Don't want you finding out and putting that SC spin on
it. LOL
Paul
97wb43
MD
07-20-2006, 14:34
Racor Information
I just got some new RaCor filters yesterday. I compared the new ones
to the old one that came out...same height, same diameter...but the
bottom of the filter is shaped differently. Seems that there is a
difference. I'd be very interested in hearing about it if I need a
spacer or something.
Scott Forman
82 FC35RB
Memphis
more?
out
> more about that.
> ScottB
> 86FC35
> SC
here
slightly.
> Housings.
The
> new
quantity
> of
on
07-20-2006, 15:01
Racor Information
Paul, I could not agree more. BUT the problem is Dave's post was much
too short! hehehe
ScottB
86FC35
SC
Housings.
new
of
07-21-2006, 01:36
Racor Information
Here is some more information on the Racor Change.
This only applies to the "older" 500 Series Diesel Filter Housings.
A rubber spacer Part# 15424 is available free of charge from Racor by
calling their tech support number 800-344-3286. I was not sure if the
vintage Birds used 500, 900, or 1000 series housings. Again this only
applies to the 500 series as far as I know. A call to their tech
support number above might reveal any other information.
By the way, their tech support bulletins # 7627 and 7566, available on
their web site state that the new style elements are a form, fit, and
function exact replacement for the old style elements in the 900, 1000
series. No information or mention about the 500 series problem and
resolution is posted.
Hope this helps to clarify.
07-21-2006, 03:43
Racor Information
I believe my FC has a 900 series, but I am at work and can't check
it. Can anyone verify that FC's had 900's?
Thanks
Scott Forman
82 FC35RB
Memphis
by
only
on
1000
07-21-2006, 05:16
Racor Information
Dave,
Thank you for the Racor information.
I called the number. They will send out the rubber spacer free of
charge. All units before 1997 need the spacer. Starting in August they
will include the rubber spacer with the filter.
07-21-2006, 05:52
Racor Information
Dave, others, I contacted RACOR today and checked with their tech
support. They advised it was only for the 500 series built before
1997 and as of August this year there will be a spacer in all new
elements. So check your coaches, I have a 900 series which is
unaffected.
Great Catch Dave, thanks for the heads up.
ScottB
86FC35
SC
by
only
on
1000
07-21-2006, 08:18
Racor Information
My 82 Fc has a 900.
Kerry
-- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...>
> Thanks
> Scott Forman
> 82 FC35RB
> Memphis
Housings.
Racor
> by
if
> the
this
> only
tech
available
> on
fit,
> and
900,
> 1000
