What should be cost for changing out oil cooler hoses?
04-18-2005, 15:54
Sence I have never dealt with changing these hoses, how many hours do
you think it would take a shop to change these out? Jon Jon Lechich 1978Wonderlodge Bremerton Washington |
04-18-2005, 16:18
Changing them isn't bad, you need a couple of mechanic fingers a couple of
inches long and couple of 5 gallon buckets to catch the glycol. Drain the radiator after turning off all the faucet type valves you can find and the road side block drain. Remove the clamps and use the fingers to loosen the hose around the barb. Most any place that sells tools will have the finger tools, that's what I call 'em maybe hose removal tool would be a good name. I use them constantly when doing maintenance work. Just a hook like thingy with a screw driver like handle. Use the "lined" type clamps exclusively on your bird, you won't be happy if you let shops work on your bus, most worker bees in truck shops hate buses. You really need to be comfortable with fuel filter changing techniques. It will be a required skill. If you don't have an electric pusher fuel pump back by the rear axle, you should install one very soon. Mike Hohnstein Germantown, WI ----- Original Message ----- From: Jon To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 18, 2005 10:54 PM Subject: [WanderlodgeForum] What should be cost for changing out oil cooler hoses? Sence I have never dealt with changing these hoses, how many hours do you think it would take a shop to change these out? Jon Jon Lechich 1978Wonderlodge Bremerton Washington ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
04-19-2005, 01:20
"Remove the clamps and use the fingers to loosen the hose around the
barb. Most any place that sells tools will have the finger tools, that's what I call 'em maybe hose removal tool would be a good name." ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Good Morning Mike, Here is a link with a picture of your "hook like thingy" http://tinyurl.com/bk4vu "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA ///////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@w...> wrote: > Changing them isn't bad, you need a couple of mechanic fingers a couple of inches long and couple of 5 gallon buckets to catch the glycol. Drain the radiator after turning off all the faucet type valves you can find and the road side block drain. Remove the clamps and use the fingers to loosen the hose around the barb. Most any place that sells tools will have the finger tools, that's what I call 'em maybe hose removal tool would be a good name. I use them constantly when doing maintenance work. Just a hook like thingy with a screw driver like handle. Use the "lined" type clamps exclusively on your bird, you won't be happy if you let shops work on your bus, most worker bees in truck shops hate buses. You really need to be comfortable with fuel filter changing techniques. It will be a required skill. If you don't have an electric pusher fuel pump back by the rear axle, you should install one very soon. > Mike Hohnstein > Germantown, WI > ----- Original Message ----- > From: Jon > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 18, 2005 10:54 PM > Subject: [WanderlodgeForum] What should be cost for changing out oil cooler hoses? > > > > Sence I have never dealt with changing these hoses, how many hours do > you think it would take a shop to change these out? Jon > Jon Lechich > 1978Wonderlodge > Bremerton Washington > > > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
