Speaking of Ice machines
07-20-2006, 12:39
In my quest to continue to keep our ice machine running. I have
spoken on several occaisions with U-line. The last time the machine decided not to work properly I removed the ice mold itself. Man was I suprised! What a mess. Now you should know the mold had been replaced only three years ago. The problem was that the "fingers" had come out of the bearing in the back and caused the machine to "stick" in the heat cycle to remove the ice. So I removed the entire unit..man was there lets just call it "stuff" in the mold. Apparently, the mold is made from a cast metal and covered by a green rubber/silicone stuff. This covering was pulling away from the cast and causing some "stuff" to form while the machine was not used. Lemme tell ya..I would never use ice from this thing. I called U-line and asked about it and was told that what is happening the standing water is causing the coating to pull away from the metal. Hmmm..really? What they said was to try and empty the water before letting it sit for any period of time. Hmmm again..what did they say and how am I gonna do that? So.. I went to the local bldg supply and got a 1/4 turn on off valve and now what we do is on our way home I shut the water off to the machine. I continues to run until allll the water/ice is gone from the mold. We then shut the machine down upon arriving home and open the door, and place some towels inside to soak up the water then wipe it down. This is while we unpack the coach. I hope this works..PLEASE do not look at the mold if you do not want to see the enviornment in which your ice machine is holding water...yuck... Hope this helps Scott B 86FC35 SC |
07-21-2006, 09:48
Don't use anti-freeze in the icemaker.
- Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > > In my quest to continue to keep our ice machine running. I have > spoken on several occaisions with U-line. > > The last time the machine decided not to work properly I removed the > ice mold itself. Man was I suprised! What a mess. Now you should know > the mold had been replaced only three years ago. The problem was that > the "fingers" had come out of the bearing in the back and caused the > machine to "stick" in the heat cycle to remove the ice. So I removed > the entire unit..man was there lets just call it "stuff" in the mold. > > Apparently, the mold is made from a cast metal and covered by a green > rubber/silicone stuff. This covering was pulling away from the cast > and causing some "stuff" to form while the machine was not used. > Lemme tell ya..I would never use ice from this thing. I called U- line > and asked about it and was told that what is happening the standing > water is causing the coating to pull away from the metal. > Hmmm..really? What they said was to try and empty the water before > letting it sit for any period of time. Hmmm again..what did they say > and how am I gonna do that? > > So.. I went to the local bldg supply and got a 1/4 turn on off valve > and now what we do is on our way home I shut the water off to the > machine. I continues to run until allll the water/ice is gone from > the mold. We then shut the machine down upon arriving home and open > the door, and place some towels inside to soak up the water then wipe > it down. This is while we unpack the coach. I hope this works..PLEASE > do not look at the mold if you do not want to see the enviornment in > which your ice machine is holding water...yuck... > > Hope this helps > > Scott B > 86FC35 > SC > |
07-21-2006, 12:09
That a good point Jeff, I have never used anti-freeze in that line. U-
line told me that standing water causes the coating to pull away and it would be best to not have water standing. ScottB 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > Don't use anti-freeze in the icemaker. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Scott" > wrote: > > > > In my quest to continue to keep our ice machine running. I have > > spoken on several occaisions with U-line. > > > > The last time the machine decided not to work properly I removed > the > > ice mold itself. Man was I suprised! What a mess. Now you should > know > > the mold had been replaced only three years ago. The problem was > that > > the "fingers" had come out of the bearing in the back and caused > the > > machine to "stick" in the heat cycle to remove the ice. So I > removed > > the entire unit..man was there lets just call it "stuff" in the > mold. > > > > Apparently, the mold is made from a cast metal and covered by a > green > > rubber/silicone stuff. This covering was pulling away from the > cast > > and causing some "stuff" to form while the machine was not used. > > Lemme tell ya..I would never use ice from this thing. I called U- > line > > and asked about it and was told that what is happening the > standing > > water is causing the coating to pull away from the metal. > > Hmmm..really? What they said was to try and empty the water before > > letting it sit for any period of time. Hmmm again..what did they > say > > and how am I gonna do that? > > > > So.. I went to the local bldg supply and got a 1/4 turn on off > valve > > and now what we do is on our way home I shut the water off to the > > machine. I continues to run until allll the water/ice is gone from > > the mold. We then shut the machine down upon arriving home and > open > > the door, and place some towels inside to soak up the water then > wipe > > it down. This is while we unpack the coach. I hope this > works..PLEASE > > do not look at the mold if you do not want to see the enviornment > in > > which your ice machine is holding water...yuck... > > > > Hope this helps > > > > Scott B > > 86FC35 > > SC > > > |
