Washing The Bird
07-20-2006, 13:49
Washing The Bird
Pete,
RENT a Deionized Water System so you don't have to dry the bus...save lots of time/effort. No towel drying and the coach drys spotless. Best I've found is to use a soap that does not remove wax, as dish soap will. I buy my washing soap at an automotive detail supply store. About $20.00/gal.. Better and cheaper than the local auto. parts store products. I use a 5/gal. bucket and an automotive washing brush. Using the Deionized Water System, keep the coach rinsed off as you go so the soap doesn't dry. Saves a lot of time and the coach looks great. -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
07-21-2006, 04:20
Washing The Bird
Thanks Curt.
Good tip on the washing soap ... I've usually gotten it from the local auto parts store when I used to wash my own car. (Free or nominal-cost car wash with fill up at a local gas station has caused me to forget some of this stuff ... unfortunately, despite easily meeting the minimum fill up requirement, I can't get the WL through the gas station car wash...) Your mention of wax give me a horrible thought... do you need to wax the thing? Or does the clear coat provide enough protection? I suppose that the local detail shop could retire on what it would cost to hire it done...! Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Jul 20, 2006, at 6:49 PM, Curt Sprenger wrote: > Pete, > > RENT a Deionized Water System so you don't have to dry the bus...save > lots of time/effort. No towel drying and the coach drys spotless. > > Best I've found is to use a soap that does not remove wax, as dish > soap > will. I buy my washing soap at an automotive detail supply store. > About > $20.00/gal.. Better and cheaper than the local auto. parts store > products. I use a 5/gal. bucket and an automotive washing brush. > > Using the Deionized Water System, keep the coach rinsed off as you > go so > the soap doesn't dry. Saves a lot of time and the coach looks great. > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > [Non-text portions of this message have been removed] |
07-21-2006, 04:52
Washing The Bird
Waxed ours 2 weeks ago 8 hours 3/4 can of mothers carnauba case of
beer makes for a nice tan the next day --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Thanks Curt. > > Good tip on the washing soap ... I've usually gotten it from the > local auto parts store when I used to wash my own car. (Free or > nominal-cost car wash with fill up at a local gas station has caused > me to forget some of this stuff ... unfortunately, despite easily > meeting the minimum fill up requirement, I can't get the WL through > the gas station car wash...) > > Your mention of wax give me a horrible thought... do you need to wax > the thing? Or does the clear coat provide enough protection? I > suppose that the local detail shop could retire on what it would cost > to hire it done...! > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 4203 > El Sobrante, CA > > > > > On Jul 20, 2006, at 6:49 PM, Curt Sprenger wrote: > > > Pete, > > > > RENT a Deionized Water System so you don't have to dry the bus...save > > lots of time/effort. No towel drying and the coach drys spotless. > > > > Best I've found is to use a soap that does not remove wax, as dish > > soap > > will. I buy my washing soap at an automotive detail supply store. > > About > > $20.00/gal.. Better and cheaper than the local auto. parts store > > products. I use a 5/gal. bucket and an automotive washing brush. > > > > Using the Deionized Water System, keep the coach rinsed off as you > > go so > > the soap doesn't dry. Saves a lot of time and the coach looks great. > > > > -- > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > [Non-text portions of this message have been removed] > |
07-21-2006, 04:59
Washing The Bird
Pete,
It's good to keep a coat of wax or polymer sealant on the coach. I apply a coat every 8 or 9 months using the polymer sealant. It goes on and wipes off with ease. Leaves a great looking finish. I buy the polymer sealant from a local detail supply shop. It takes me 6 hours doing half the coach so I make it a two day project. Our unit has all the rivets holding the skin. A tooth brush works well to remove the sealant residue from around the rivets, and adds a lot of time. I believe your coach has the smooth sides so less time than I spend. A friend is in the auto. detail business...his guys will wash and wax the coach for $400.00. ..ouch. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Pete Masterson wrote: > Thanks Curt. > > Good tip on the washing soap ... I've usually gotten it from the > local auto parts store when I used to wash my own car. (Free or > nominal-cost car wash with fill up at a local gas station has caused > me to forget some of this stuff ... unfortunately, despite easily > meeting the minimum fill up requirement, I can't get the WL through > the gas station car wash...) > > Your mention of wax give me a horrible thought... do you need to wax > the thing? Or does the clear coat provide enough protection? I > suppose that the local detail shop could retire on what it would cost > to hire it done...! > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 4203 > El Sobrante, CA > |
07-21-2006, 05:26
Washing The Bird
Ouch that appears to be the going rate,
We met a guy near Titusville, Florida, His fee was $10.00 per foot, for a wash / wax and a free toad wash. We do the two or three day wash /wax program, but never in consecutive days. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Pete, > It's good to keep a coat of wax or polymer sealant on the coach. I apply > a coat every 8 or 9 months using the polymer sealant. It goes on and > wipes off with ease. Leaves a great looking finish. I buy the polymer > sealant from a local detail supply shop. It takes me 6 hours doing half > the coach so I make it a two day project. Our unit has all the rivets > holding the skin. A tooth brush works well to remove the sealant residue > from around the rivets, and adds a lot of time. I believe your coach has > the smooth sides so less time than I spend. > > A friend is in the auto. detail business...his guys will wash and wax > the coach for $400.00. ..ouch. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Pete Masterson wrote: > > > Thanks Curt. > > > > Good tip on the washing soap ... I've usually gotten it from the > > local auto parts store when I used to wash my own car. (Free or > > nominal-cost car wash with fill up at a local gas station has caused > > me to forget some of this stuff ... unfortunately, despite easily > > meeting the minimum fill up requirement, I can't get the WL through > > the gas station car wash...) > > > > Your mention of wax give me a horrible thought... do you need to wax > > the thing? Or does the clear coat provide enough protection? I > > suppose that the local detail shop could retire on what it would cost > > to hire it done...! > > > > Pete Masterson > > aeonix1@... > > '95 Bluebird Wanderlodge WBDA 4203 > > El Sobrante, CA > > > |
07-21-2006, 15:51
Washing The Bird
Curt, why would I rent one when I know a guy in Anaheim who has his
own. Kevin, Jack and I take turns when your bus pad is empty( which is quite often ) Greg 94pt Romoland Ca --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Pete, > > RENT a Deionized Water System so you don't have to dry the bus...save > lots of time/effort. No towel drying and the coach drys spotless. > > Best I've found is to use a soap that does not remove wax, as dish soap > will. I buy my washing soap at an automotive detail supply store. About > $20.00/gal.. Better and cheaper than the local auto. parts store > products. I use a 5/gal. bucket and an automotive washing brush. > > Using the Deionized Water System, keep the coach rinsed off as you go so > the soap doesn't dry. Saves a lot of time and the coach looks great. > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > |
07-21-2006, 18:12
Washing The Bird
Greg,
Hey, stop telling...others will take roost. Best wash system in this part of the country for us do-it-yourself guys. Be good now! Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Gregory OConnor wrote: > Curt, why would I rent one when I know a guy in Anaheim who has his > own. Kevin, Jack and I take turns when your bus pad is empty( which > is quite often ) > > Greg > 94pt > Romoland Ca > > --- In WanderlodgeForum@yahoogroups.com > > > > > > Pete, > > > > RENT a Deionized Water System so you don't have to dry the > bus...save > > lots of time/effort. No towel drying and the coach drys spotless. > > > > Best I've found is to use a soap that does not remove wax, as dish > soap > > will. I buy my washing soap at an automotive detail supply store. > About > > $20.00/gal.. Better and cheaper than the local auto. parts store > > products. I use a 5/gal. bucket and an automotive washing brush. > > > > Using the Deionized Water System, keep the coach rinsed off as you > go so > > the soap doesn't dry. Saves a lot of time and the coach looks great. > > > > -- > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > |
07-22-2006, 04:58
Washing The Bird
Curt,
It's a shame you're so far from me ... but when I move in full time later this year, perhaps I can use your "wash stand" as well! Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Jul 21, 2006, at 11:12 PM, Curt Sprenger wrote: > Greg, > Hey, stop telling...others will take roost. Best wash system in this > part of the country for us do-it-yourself guys. Be good now! > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Gregory OConnor wrote: > >> Curt, why would I rent one when I know a guy in Anaheim who has his >> own. Kevin, Jack and I take turns when your bus pad is empty( which >> is quite often ) >> >> Greg >> 94pt >> Romoland Ca >> >> --- In WanderlodgeForum@yahoogroups.com >> >> >>> >>> Pete, >>> >>> RENT a Deionized Water System so you don't have to dry the >> bus...save >>> lots of time/effort. No towel drying and the coach drys spotless. >>> >>> Best I've found is to use a soap that does not remove wax, as dish >> soap >>> will. I buy my washing soap at an automotive detail supply store. >> About >>> $20.00/gal.. Better and cheaper than the local auto. parts store >>> products. I use a 5/gal. bucket and an automotive washing brush. >>> >>> Using the Deionized Water System, keep the coach rinsed off as you >> go so >>> the soap doesn't dry. Saves a lot of time and the coach looks great. >>> >>> -- >>> Curt Sprenger 1987 PT38, Anaheim Hills, Calif. >>> >> >> > > > > ------------------------ Yahoo! Groups Sponsor -------------------- > ~--> > Yahoo! Groups gets a make over. See the new email design. > http://us.click.yahoo.com/XISQkA/lOaOAA/.../pkiolB/TM > -------------------------------------------------------------------- > ~-> > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] |
