Racor
07-21-2006, 02:57
Racor
Ihave a new 1000fg racor old style with filter no heater
$125.00 Stephen |
07-22-2006, 04:05
Racor
Hi Stephen,
My filter has 3 sensors going to it. Does that mean that one of them is for heat? Haven't figured them out yet. Bob Lawrence 84 PT36 Tacoma,Wa. > > Ihave a new 1000fg racor old style with filter no heater > $125.00 > Stephen > |
07-22-2006, 22:27
Racor
Hi Bob,
My 900FG had two wires going to the bowl (water sensor) and one going to the middle of the unit (fuel heater) There were a total of 3 wires on the 900 that I had. I replaced with a 1000 FG- which has 4 wires. The old fuel heater in the 900FG just grouded to the frame. The new one has a ground wire of its own that needs to be attached somewhere outside the unit- probably because of all the plastic in the new one. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi Stephen, > My filter has 3 sensors going to it. Does that mean that one of them > is for heat? Haven't figured them out yet. > Bob Lawrence > 84 PT36 > Tacoma,Wa. > > > > Ihave a new 1000fg racor old style with filter no heater > > $125.00 > > Stephen > > > |
05-18-2007, 10:50
Racor
New guy here again. Per Racor manual, refill Racor housing with diesel
after draining and replacing filter. Necessary? Thanks in advance Brad Bloxham 78/35FC 3208NA Yuma, AZ. |
05-18-2007, 11:03
Racor
Absolutely. Also I would suggest doing the spin on fuel filter last and
replace it quickly with a new "full" spin on filter. This will help to minimize air in the sytem and the amount of cranking you have to do. On 18/05/07, kingmtpg > > New guy here again. Per Racor manual, refill Racor housing with diesel > after draining and replacing filter. Necessary? Thanks in advance Brad > Bloxham 78/35FC 3208NA Yuma, AZ. > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-18-2007, 11:06
Racor
Brad I should have said....."if you have a secondary spin on fuel filter".
05-18-2007, 11:18
Racor
Ryan,
Very important so you don't starve your engine of oil. Al Johnson '96 BMC B75 Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, "kingmtpg" wrote: > > New guy here again. Per Racor manual, refill Racor housing with diesel > after draining and replacing filter. Necessary? Thanks in advance Brad > Bloxham 78/35FC 3208NA Yuma, AZ. > |
05-18-2007, 13:25
Racor
I coat the rubber seal with grease and fill the filter with one quart
of ATF and balance diesel. GregoryO'Connor 94ptRomolandCa--- In WanderlodgeForum@yahoogroups.com, "Al" wrote: > > Ryan, > Very important so you don't starve your engine of oil. > Al Johnson > '96 BMC B75 > Mandeville, Louisiana > > --- In WanderlodgeForum@yahoogroups.com, "kingmtpg" > wrote: > > > > New guy here again. Per Racor manual, refill Racor housing with > diesel > > after draining and replacing filter. Necessary? Thanks in advance > Brad > > Bloxham 78/35FC 3208NA Yuma, AZ. > > > |
05-18-2007, 23:08
Racor
To minimize the chance of too much air getting in the system change one
filter, the Racor, for instance, then start the engine and let it run a couple of minutes. Shut the engine down and change the other filter, the spin on, for instance, and start the engine. This way, if you goober it up, you will have a good idea which one you did wrong. The goal is trying to keep excess air out of the system, hence filling the Racor, and by the way, filling the spin on, if applicable prior to installing it. Don't get wrapped around the axle on this. It is a simple, straight forward evolution. Regards, Jim |
