Steerable vs Liftable vs Dumpable Tag
07-25-2006, 15:57
Here's the way I see it:
Dumpable tag is good, drags sideways on tight manuevers and leaves
black skidmarks on white concrete, but it helps A LOT. It is slow to
dump and slower to inflate, plan ahead. Touching the brakes with it
dumped is bad, the tires will skid (pre-'95 had no ABS).
Liftable tag is better. Can be driven with the tag lifted, at low
speeds. Highway speeds no. Load ratings at the same air pressure go
up as speed is reduced, part of the matrix. Still takes a little
time to lift and lower, but the cool factor of people watching it do
its thing makes up for it. You could run around town with it lifted
if your tire pressures are correct for the speed & load.
Steerable tag is good too, doesn't steer sharp enough to have no
drag at full steering lock, but much reduced side-loads and should
reduce effective wheelbase when turning sharp. Would be nice to add
negative turn angles to eliminate sway at highway speeds, ... anyone
want to donate a coach for me to experiment with? Steerable &
dumpable makes it better, and if it really bothered you it could be
made liftable, it's only money.
- Jeff Miller
in Holland, MI
> Both axles are dumped. the liftable is just dumped and lifted.
Lift
> axles are mainly designed to save tread when there is no
> payload.There is never lack of load on a lodge. I cant believe
that
> BB ever intended you to drive down the road with it lifted. . The
> raidal sidewalls do not give enough play to keep from skidding in
a
> tamden axle set with tight parkinglot manuvers .These manuvers at
> low speed are easier on the tire tread and asphalt with a dumped
bag
> skidding tag. It is not a good Idea to drive fast with the Tag
dumped
> because a high speed bump may cause tire blow out. Dumping the
tag
> bags still keeps quite a bit of weight on the tag tires. Since
RV's
> hardly weare out tread it is better to drag 2 treads with dumped
load
> then stress all 6 sidewalls fully loaded. The Antilock braking
will
> prevent a dumped or damaged tag from locking up .
> Gregory O'Connor
> pdt40 not pdlt40
07-26-2006, 02:03
Jeff et al,
The liftable tags AUTOMATICALLY lower if speeds exceed 15MPH, so no
concern with driving at high speed with the tag up.
Paul
97wb43
