Need Dash Air Compressor 1980 FC35
07-26-2006, 07:42
My mechanic can not locate a replacement compressor. Any ideas on
where to find or alternatives? I would prefer to have some air up there versus to abandon the dash air. Thanks. |
07-26-2006, 09:14
More then likely you have a Climate Control compressor (in my 1982
FC35) and the manufacturer now makes a very rugged universal Rotolock ER 210L-25149 Rotolock universal compressor which you can buy at NAPA http://www.ccicompressor.com/universal.aspx http://www.worldaire.com/pdf/WorldaireCC...essors.pdf Be sure you install a new air drier and an appropriate new expansion valve for R134a. Tom Warner Vernon Center,NY 1985 PT 40 (will be getting the same compressor) 7/26/2006, you wrote: >My mechanic can not locate a replacement compressor. Any ideas on >where to find or alternatives? I would prefer to have some air up >there versus to abandon the dash air. Thanks. > > [Non-text portions of this message have been removed] |
07-26-2006, 11:51
PMJI how do you get to the expansion valve
88pt38 jackson, ms Original Message: ----------------- From: Tom Warner warbucks@... Date: Wed, 26 Jul 2006 17:14:41 -0400 To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Need Dash Air Compressor 1980 FC35 More then likely you have a Climate Control compressor (in my 1982 FC35) and the manufacturer now makes a very rugged universal Rotolock ER 210L-25149 Rotolock universal compressor which you can buy at NAPA http://www.ccicompressor.com/universal.aspx http://www.worldaire.com/pdf/WorldaireCC...essors.pdf Be sure you install a new air drier and an appropriate new expansion valve for R134a. Tom Warner Vernon Center,NY 1985 PT 40 (will be getting the same compressor) 7/26/2006, you wrote: >My mechanic can not locate a replacement compressor. Any ideas on >where to find or alternatives? I would prefer to have some air up >there versus to abandon the dash air. Thanks. > > [Non-text portions of this message have been removed] -------------------------------------------------------------------- mail2web - Check your email from the web at http://mail2web.com/ . |
07-27-2006, 14:04
Shawan
I have a compresor with out the pulley.It has been rebuilt.I can be reached at 612-418-2926 or at Lakeland coach 952-890-5232 Dave Buster80wl Bloomington MN. --------------------------------- Do you Yahoo!? Everyone is raving about the all-new Yahoo! Mail Beta. [Non-text portions of this message have been removed] |
07-28-2006, 07:20
Thanks for the info. I ordered one yesterday afternoon. I will see if I can
cancel. I probably will not be able to fund out until Mon. I willl contact you if I can cancel. Regards, SDF ----Original Message Follows---- From: Dave Krolick Reply-To: WanderlodgeForum@yahoogroups.com To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Need Dash Air Compressor 1980 FC35 Date: Thu, 27 Jul 2006 19:04:08 -0700 (PDT) Shawan I have a compresor with out the pulley.It has been rebuilt.I can be reached at 612-418-2926 or at Lakeland coach 952-890-5232 Dave Buster80wl Bloomington MN. --------------------------------- Do you Yahoo!? Everyone is raving about the all-new Yahoo! Mail Beta. [Non-text portions of this message have been removed] |
