Back home from a road trip and a power steering question.
07-29-2006, 07:47
without looking Idont know exactly what is on there at the reservoir
end but if it was high pressure it would be crimp if low pressure it
would br barbed i do believe the resevoir has a fitting on it that
would preclude machined or crimped ends I will loook later
whenit cools down
Stephen 77fc35
> Did you replace them with crimped fittings all the way around? The
> barbed fittings at my reservoir have been seeping, the barbed
> reservoir fitting at the pump leaks and I assume (?) the return hose
> from the steering box is just a barbed fitting also and it leaks since
> there's a stain under that location everytime I stop. How long did it
> take you to do the job?
> Wouldn't the routing of the hoses be blind regardless of how you
> accessed the steering box?
> Kerry
> --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles"
> > crimped fittings at steering box and crimped fittings at pump
> > barb fittings at resevoir.
> > Stephen 77fc35
> > wrote:
> > > Were your hoses attached with hose clamps or did they have proper
> > > crimped fittings?
> > > Kerry
> > > wrote:
> > > > We did it that wayon a 77 BUT there is much blind work to do
> > > > You have to be careful when the hoses run down the front and
side of
> > > > the engine you cant really see the placement it did hwoever
make it
> > > > easier to attach the hoses to be the steering box.
> > > > Stephen 77fc35
07-29-2006, 08:58
That the way we did it on last bus - '81FC. I wouldn't call easy for the guy
who was under the bus who had to catch the whole thing, it's heavy. There's no
other way if the gear must be removed to overhaul. But the hose thing was not
bad at all. I was very surprised to find a gold color door hinge under there.
Anybody know what I mean? I guess it was standard procedure then.
Sent: Saturday, July 29, 2006 11:32 AM
Subject: [WanderlodgeForum] Re: Back home from a road trip and a power
steering question.
Steve Anderson over on the FC forum says he accessed the steering box
and hoses on his 79 from above by removing the driver's seat and a
floor panel. Anyone here try that on an 82? Seems like it would make
the job much easier.
Kerry
82 FC 35
Denver
--- In
"davidkerryedwards"
> I was hoping for an answer that didn't involve that but I suspected as
> much. I figured the reason why the factory never fessed up to their
> mistake and fixed it despite numerous complaints by the original
> owner, that the job was a PIA.
> Kerry
> 82 FC 35
> --- In
"pattypape"
> > Kerry,
> > We replaced hose by removing the batteries and battery tray. While
> > you are in there, I would suggest replacing the high pressure hose.
> > Lots of pressure and a higher failure hose than the return hose.
> > NAPA can make this hose just show them the old hose.
> > Bill 88 FC Michigan
07-29-2006, 13:17
You might consider that the only way the barbed fitting at the
reservoir would leak is if it was under pressure, which does occur
when the fluid heats since the reservoir is not vented.
Vent the reservoir, you might be leak-less.
- Jeff Miller
in Holland, MI
since
it
> Kerry
> > Stephen 77fc35
proper
> > > crimped fittings?
> > > Kerry
side of
make it
> > > > Stephen 77fc35
07-29-2006, 14:05
Definitely worth a try. I'll remove the dipstick and see what happens.
Kerry
> - Jeff Miller
> in Holland, MI
> since
> it
> > Kerry
> > > Stephen 77fc35
> proper
> > > > crimped fittings?
> > > > Kerry
> side of
> make it
> > > > > Stephen 77fc35
07-30-2006, 14:23
My power steering can leaked as did the fittings going to and from
the can.
Bought a new can from BB. Cost $300. It has a vent tube and is a
little bit taller.
Had my local truck shop replace the can and the leaking hoses..not
cheap..had to modify the bottom of can, a little different than the
original. All labor cost was $1,400. A lot of time involved at 90
bucks an hour. No leaks now and tow car staying clean.
Until I had this done, drilled hole in top of can...works but not
for long term.
Bob Lawrence
84 PT36
Tacoma,Wa
happens.
> Kerry
occur
> > - Jeff Miller
> > in Holland, MI
