Air control valve for forward air bags
07-29-2006, 09:53
Hello everyone it has been some time since I last posted a message. I
just put a fresh engine into my 82 FC. I was probably only a head gasket on a 20k since rebuild motor, but for all the trouble to get the engine in and out I said the heck with it. I was wondering if anyone know where to get the forward air bag control valve, other than Bluebird parts? Thanks Jim Hutchings 82 FCRB (good as new) Yorba Linda, ca |
07-29-2006, 10:13
Sorry I can't answer your question. But are you saying that it's
impossible to replace a headgasket on an FC without pulling the motor? From what I've heard there's some kind of nipple connecting block and head on a 3208 that can fail. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > > Hello everyone it has been some time since I last posted a message. I > just put a fresh engine into my 82 FC. I was probably only a head > gasket on a 20k since rebuild motor, but for all the trouble to get > the engine in and out I said the heck with it. I was wondering if > anyone know where to get the forward air bag control valve, other than > Bluebird parts? > > Thanks > > Jim Hutchings > 82 FCRB (good as new) > Yorba Linda, ca > |
07-29-2006, 13:23
If you're talking about the height-control valve it is a standard
truck/bus part, likely NAPA, I buy from a truck parts supplier. It is a slow valve, not the fast one. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > > Hello everyone it has been some time since I last posted a message. I > just put a fresh engine into my 82 FC. I was probably only a head > gasket on a 20k since rebuild motor, but for all the trouble to get > the engine in and out I said the heck with it. I was wondering if > anyone know where to get the forward air bag control valve, other than > Bluebird parts? > > Thanks > > Jim Hutchings > 82 FCRB (good as new) > Yorba Linda, ca > |
07-30-2006, 10:46
No it is quite possible to replace a head gasket in a 3208 without pulling
the engine. Just run a 4X6 through the drivers and passengers windows and you can use it to hoist the heads up and out. I just don't like working I a keyhole. The engine that was "rebuilt" 20,000 miles ago before I bought the coach was just done poorly and I lost faith in it. I had to reseal every gasket on it to stop oil leaks with the exception of the rear seal, which I was not willing to get into. The final straw was when a head bolt snapped all on its own. And as for that little nipple connecting the block and head. it is there and you have to be careful on assembly not to damage it. Also I did a little research and a new and improved Height control valve is available from ridewell. The new valve is supposed to have "minimal deadband for optimal performance." Think I will give it a try. _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Saturday, July 29, 2006 3:13 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Air control valve for forward air bags Sorry I can't answer your question. But are you saying that it's impossible to replace a headgasket on an FC without pulling the motor? From what I've heard there's some kind of nipple connecting block and head on a 3208 that can fail. Kerry 82 FC 35 Denver --- In WanderlodgeForum@ yahoogroups.com, "bluebird3208" > > Hello everyone it has been some time since I last posted a message. I > just put a fresh engine into my 82 FC. I was probably only a head > gasket on a 20k since rebuild motor, but for all the trouble to get > the engine in and out I said the heck with it. I was wondering if > anyone know where to get the forward air bag control valve, other than > Bluebird parts? > > Thanks > > Jim Hutchings > 82 FCRB (good as new) > Yorba Linda, ca > [Non-text portions of this message have been removed] |
