Back home from a road trip and a power steering question.
07-29-2006, 07:47
without looking Idont know exactly what is on there at the reservoir
end but if it was high pressure it would be crimp if low pressure it would br barbed i do believe the resevoir has a fitting on it that would preclude machined or crimped ends I will loook later whenit cools down Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Did you replace them with crimped fittings all the way around? The > barbed fittings at my reservoir have been seeping, the barbed > reservoir fitting at the pump leaks and I assume (?) the return hose > from the steering box is just a barbed fitting also and it leaks since > there's a stain under that location everytime I stop. How long did it > take you to do the job? > Wouldn't the routing of the hoses be blind regardless of how you > accessed the steering box? > > Kerry > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > > > crimped fittings at steering box and crimped fittings at pump > > barb fittings at resevoir. > > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > > > > Were your hoses attached with hose clamps or did they have proper > > > crimped fittings? > > > > > > Kerry > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > > > > > > > We did it that wayon a 77 BUT there is much blind work to do > > > > You have to be careful when the hoses run down the front and side of > > > > the engine you cant really see the placement it did hwoever make it > > > > easier to attach the hoses to be the steering box. > > > > Stephen 77fc35 > > > > > > > > > > |
07-29-2006, 08:58
That the way we did it on last bus - '81FC. I wouldn't call easy for the guy
who was under the bus who had to catch the whole thing, it's heavy. There's no other way if the gear must be removed to overhaul. But the hose thing was not bad at all. I was very surprised to find a gold color door hinge under there. Anybody know what I mean? I guess it was standard procedure then. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 29, 2006 11:32 AM Subject: [WanderlodgeForum] Re: Back home from a road trip and a power steering question. Steve Anderson over on the FC forum says he accessed the steering box and hoses on his 79 from above by removing the driver's seat and a floor panel. Anyone here try that on an 82? Seems like it would make the job much easier. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com "davidkerryedwards" > > I was hoping for an answer that didn't involve that but I suspected as > much. I figured the reason why the factory never fessed up to their > mistake and fixed it despite numerous complaints by the original > owner, that the job was a PIA. > > Kerry > 82 FC 35 > > --- In WanderlodgeForum@yahoogroups.com "pattypape" > wrote: > > > > > > Kerry, > > > > We replaced hose by removing the batteries and battery tray. While > > you are in there, I would suggest replacing the high pressure hose. > > Lots of pressure and a higher failure hose than the return hose. > > NAPA can make this hose just show them the old hose. > > > > Bill 88 FC Michigan > > > > > [Non-text portions of this message have been removed] |
07-29-2006, 13:17
You might consider that the only way the barbed fitting at the
reservoir would leak is if it was under pressure, which does occur when the fluid heats since the reservoir is not vented. Vent the reservoir, you might be leak-less. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Did you replace them with crimped fittings all the way around? The > barbed fittings at my reservoir have been seeping, the barbed > reservoir fitting at the pump leaks and I assume (?) the return hose > from the steering box is just a barbed fitting also and it leaks since > there's a stain under that location everytime I stop. How long did it > take you to do the job? > Wouldn't the routing of the hoses be blind regardless of how you > accessed the steering box? > > Kerry > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > > > crimped fittings at steering box and crimped fittings at pump > > barb fittings at resevoir. > > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > > > > Were your hoses attached with hose clamps or did they have proper > > > crimped fittings? > > > > > > Kerry > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > > > > > > > We did it that wayon a 77 BUT there is much blind work to do > > > > You have to be careful when the hoses run down the front and side of > > > > the engine you cant really see the placement it did hwoever make it > > > > easier to attach the hoses to be the steering box. > > > > Stephen 77fc35 > > > > > > > > > > |
07-29-2006, 14:05
Definitely worth a try. I'll remove the dipstick and see what happens.
Kerry --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > You might consider that the only way the barbed fitting at the > reservoir would leak is if it was under pressure, which does occur > when the fluid heats since the reservoir is not vented. > > Vent the reservoir, you might be leak-less. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > Did you replace them with crimped fittings all the way around? The > > barbed fittings at my reservoir have been seeping, the barbed > > reservoir fitting at the pump leaks and I assume (?) the return hose > > from the steering box is just a barbed fitting also and it leaks > since > > there's a stain under that location everytime I stop. How long did > it > > take you to do the job? > > Wouldn't the routing of the hoses be blind regardless of how you > > accessed the steering box? > > > > Kerry > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > > > > > > > crimped fittings at steering box and crimped fittings at pump > > > barb fittings at resevoir. > > > Stephen 77fc35 > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > > > > > > > Were your hoses attached with hose clamps or did they have > proper > > > > crimped fittings? > > > > > > > > Kerry > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > > > > > > > > > > We did it that wayon a 77 BUT there is much blind work to do > > > > > You have to be careful when the hoses run down the front and > side of > > > > > the engine you cant really see the placement it did hwoever > make it > > > > > easier to attach the hoses to be the steering box. > > > > > Stephen 77fc35 > > > > > > > > > > > > > > > |
07-30-2006, 14:23
My power steering can leaked as did the fittings going to and from
the can. Bought a new can from BB. Cost $300. It has a vent tube and is a little bit taller. Had my local truck shop replace the can and the leaking hoses..not cheap..had to modify the bottom of can, a little different than the original. All labor cost was $1,400. A lot of time involved at 90 bucks an hour. No leaks now and tow car staying clean. Until I had this done, drilled hole in top of can...works but not for long term. Bob Lawrence 84 PT36 Tacoma,Wa > > Definitely worth a try. I'll remove the dipstick and see what happens. > > Kerry > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > wrote: > > > > You might consider that the only way the barbed fitting at the > > reservoir would leak is if it was under pressure, which does occur > > when the fluid heats since the reservoir is not vented. > > > > Vent the reservoir, you might be leak-less. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > > > > Did you replace them with crimped fittings all the way around? |
