tires
08-24-2007, 12:41
Post: #71
tires
Early coaches all had 20 inch rims
sound like the coach had a front end upgrade
our has 22.5 all around
mike H has shoe horned 24.5 into a fc
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "jimbojcs" wrote:
> --- In WanderlodgeForum@yahoogroups.com, Pete Masterson
> > The load rating should exceed the maximum weight allowed for the
> axle
> > (we assume you don't overload your coach). You should find the
> axle
> > rating in your blue box (if you have it). Divide that by 4 (for
> the
> > number of tires) to get the individual tire loads. Add some more
> for
> > a safety factor. Since I'm not so familiar with early FCs, I
> thought
> > all 'birds had 22.5 size wheels... but that might be more recent
> > models. Most use an 11 or 12R x 22.5 depending on year.
> > You might be able to find a weight rating chart on the tire
> > manufacturer's web site.
> > I guess i have to do a little more research...My bus has
> alluminum wheels front and rear. The front wheels are 22.5 and the
> rear wheels are 20's. It doesn't look like a 22.5 would fit properly
> under the rear, but maybe someone put 20's on because that was all
> they had.....like i said, i'll have to do some more research on my
> particular model.
> > Pete Masterson
> > '95 Blue Bird Wanderlodge WBDA 42
> > El Sobrante CA
> > aeonix1@
> > On Aug 24, 2007, at 12:54 PM, jimbojcs wrote:
> > > I am looking at purchasing some Dunlop SP 160's 10.00 R x 20 for
> the
> > > rear of my 77 FC. The date of manufacture on the tires i found is
> > > march of 2007. Is there anything else i should look at such as
> load
> > > rating, etc. I am new to the big truck world and would
> appreciate any
> > > good tire info... Is anyone familiar with these tires? Thanks,
> jim
> > > sears
08-24-2007, 16:11
Post: #72
tires
> Stephen 77fc35
> Thanks stephen, my coach has had quite a few upgrades...I guess
i'll just keep my 20 inch tires on the back for now, they are
cheaper too! Can you tell me what might be included in a front end
upgrade other than tires and rims? jim
> > axle
> > axle
(for
> > the
more
> > for
> > thought
recent
properly
all
my
> > particular model.
> > > Pete Masterson
> > > El Sobrante CA
> > > aeonix1@
for
> > the
found is
as
> > load
> > appreciate any
Thanks,
> > jim
> > > > sears
08-24-2007, 22:44
Post: #73
tires
that all there is except replace the lug nuts with new
you will have to do the same with the rear if you change them
Stephen 77fc35
Dupree Valves
> > Stephen 77fc35
> the
> > > axle
> > > axle
> (for
> > > the
> more
> > > for
> > > thought
> recent
> the
> properly
> all
> my
> > > particular model.
> > > > Pete Masterson
> > > > El Sobrante CA
> > > > aeonix1@
> for
> > > the
> found is
> as
> > > load
> > > appreciate any
> Thanks,
> > > jim
> > > > > sears
07-05-2009, 05:39
Post: #74
tires
Hi, my first post. I just bought a 1979 fc35 off ebay,i live in
Jeffersonville,IN, i'm going to Ranburne, AL friday to pick it up.
Can someone tell me what size tire's are on the bus, thank's.
07-05-2009, 08:57
Post: #75
tires
You will need to check with the owner to be sure. My 77FC35 had the
rims replaced by the previous owner so he could run standard truck
size 11R22.5's on it.
Dorn Hetzel
77FC35
Hogansville, GA
07-05-2009, 09:48
Post: #76
tires
If you can get them for $500 each buy them! I just bought 2 last Dec. $1249.00
I did shop around.
4 tires @ $2000.00 is cheap for Michelins 12R 22.5 XZA*.
Kurt Horvath
95 PT 42
10AC
--- In WanderlodgeForum@yahoogroups.com, "williamcharrison"
> Hi all,
> I am writing from (and wilting in) Malaysia where I will work
> for the next several days. It helps pass the time to daydream about
> my bird. Question is, in Akron/Cleveland Ohio or Erie/Meadville Pa.
> area does anyone know of a tire outlet where 12R22.5 Michelin's can
> be purchased for less than $2000 for a set of 4?
07-05-2009, 09:50
Post: #77
tires
--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002"
> Hate to tell you this, but your truck driver friend is giving you
> poor advice. He is basing it on the trucking industry point of XZA
> view. They have their tires in service all the time, which keeps
> the rubber alive. Most truck tires see 100,000 miles a year.
> You have an RV, which based upon your description, gets very little
> use and spends the majority of time sitting. This destroys tires.
> I'll bet you don't put 10 to 15,000 miles a year on yours. Any
> manufacturer will tell you that 6 years max and you should remove
> the tires regardless of how they look.
Interesting to note that the Michelin folks at the last BB RIV at Perry
Fairgrounds said that they have changed their guidelines to 10 years for RV
tires, provided they are inspected continuously for cracks not to exceed 1/32".
Also said absolutely no tire shine or any other rubber dressing to be used,
cover tires when not on the road to block UV.
First of this year, replaced six Michelin 315/85R22.5 XZA which were original
equipment on our coach. Just had some barely visible hairline cracks. Date
coded 1999. Another note, these tires had been run with Nitrogen, which
eliminates moisture inside the tire.
07-05-2009, 10:33
Post: #78
tires
O.K, everyone.....
I'm now throughly confused. I have Michelins all the way around on my 94 WB.
Steer tires 4 years old. Drive tires 5 years old, Tag tires 6 years old. No
cracks, good tread. I was wanting to replace my steers and had figured on two
Goodyears for thew steers and moving the michelins to the Drive and the best of
the drives to the Tag.
My tire man here at home (does tires for a couple of churches one has a Prevost
Tour Bus and the other has a BB) recommends Goodyears, Firestones and
Bridgestones in that order. Does not recommend Michelins. Prices:
Goodyears $508.00 each including new ss valve stems and mounting.
Firestones $465.00 each, include ss valve stems and mounting.
Bridgestones $561.00 each, includes new ss valve stems and mounting.
The tire debate goes no, but I not choosy - just want the best tire for the
money.
Help!
Tommy Rountree
07-05-2009, 10:42
Post: #79
tires
Don't Bridgestones have a harder sidewall then the others?
I had B's on my van and they were stiif. Put M's on and ride is better. Or is is me?
83PT40
Wanderlodge
--- On Sun, 7/5/09, tommy.rountree wrote:
Subject: [WanderlodgeForum] Re: tires
Date: Sunday, July 5, 2009, 5:33 PM
O.K, everyone.... .
I'm now throughly confused. I have Michelins all the way around on my 94 WB. Steer tires 4 years old. Drive tires 5 years old, Tag tires 6 years old. No cracks, good tread. I was wanting to replace my steers and had figured on two Goodyears for thew steers and moving the michelins to the Drive and the best of the drives to the Tag.
My tire man here at home (does tires for a couple of churches one has a Prevost Tour Bus and the other has a BB) recommends Goodyears, Firestones and Bridgestones in that order. Does not recommend Michelins. Prices:
The tire debate goes no, but I not choosy - just want the best tire for the money.
Help!
Tommy Rountree
07-05-2009, 13:26
Post: #80
tires
You will not find them for $500 unless they are "hot". I think Michelin just
raised their prices again. Somewhere around $650 each out the door is a good
price. I have been quoted more!
Bruce
1988 FC35
