Microphor Air Assisted Toilet
08-01-2006, 14:09
Hi Everyone,
I am going to replace the Microphor toilet in my 1993 Wanderlodge. The toilet has never worked correctly and I am tired of fooling with it. Can anyone suggest a NON MICROPHOR air assisted toilet for replacement? Thanks in advance for any advice you can give me. Randy Merrill |
08-01-2006, 14:41
--- In WanderlodgeForum@yahoogroups.com, "Randy Merrill"
put in a standard rv toilet,it required making a bigger hole in the floor,and installing a bigger pipe to the black tank.we did it in a day. it was well worth the time IMO. randy dupree93wb > > Hi Everyone, > > I am going to replace the Microphor toilet in my 1993 Wanderlodge. The > toilet has never worked correctly and I am tired of fooling with it. > Can anyone suggest a NON MICROPHOR air assisted toilet for replacement? > > > Thanks in advance for any advice you can give me. > > > Randy Merrill > |
08-02-2006, 06:09
Randy Microphor also has the samr toilet with electric flush and no
air required is the same exact base as air flush. allen 88wlwb 40 --- In WanderlodgeForum@yahoogroups.com, "Randy Merrill" > > Hi Everyone, > > I am going to replace the Microphor toilet in my 1993 Wanderlodge. The > toilet has never worked correctly and I am tired of fooling with it. > Can anyone suggest a NON MICROPHOR air assisted toilet for replacement? > > > Thanks in advance for any advice you can give me. > > > Randy Merrill > |
08-02-2006, 07:05
--- In WanderlodgeForum@yahoogroups.com, "car_go_van"
> > Randy Microphor also has the samr toilet with electric flush and no > air required is the same exact base as air flush. > allen 88wlwb 40 Microphor makes both the electric and air flush because of different applications. The electric requires a straight dump into the black tank. The air operates differently and can be mounted away from directly over the black tank allowing more freedom of design. With the air model, the contents of the bowl are first dumped into a hopper below the bowl. After the flapper closes the hopper is preasurized and the waste is pushed out of the hopper through a smaller diameter pipe to the black tank. Properly adjusted they both work very well and are trouble free. I know randy is not a fan of the air model but I have to say that I have never had a problem with either model and that includes about 7 years use on each. With the air model you need to maintain pressure to keep water in the bowl but even if you don't, the wated drains to the hopper which acts as a trap and seals the toilet from the tank. Both air and electric models are an excellent product that, if maintained will last for many years. Rich D. '99LXi43' CT > > --- In WanderlodgeForum@yahoogroups.com, "Randy Merrill" > > > > > Hi Everyone, > > > > I am going to replace the Microphor toilet in my 1993 Wanderlodge. > The > > toilet has never worked correctly and I am tired of fooling with it. > > Can anyone suggest a NON MICROPHOR air assisted toilet for > replacement? > > > > > > Thanks in advance for any advice you can give me. > > > > > > Randy Merrill > > > |
08-02-2006, 08:12
That explains a lot. I thought the air assist may have been a
substitute for a laxative. Kerry --- In WanderlodgeForum@yahoogroups.com, "g_man1146" > > --- In WanderlodgeForum@yahoogroups.com, "car_go_van" > > > > > Randy Microphor also has the samr toilet with electric flush and > no > > air required is the same exact base as air flush. > > allen 88wlwb 40 > > Microphor makes both the electric and air flush because of different > applications. The electric requires a straight dump into the black > tank. The air operates differently and can be mounted away from > directly over the black tank allowing more freedom of design. With > the air model, the contents of the bowl are first dumped into a > hopper below the bowl. After the flapper closes the hopper is > preasurized and the waste is pushed out of the hopper through a > smaller diameter pipe to the black tank. Properly adjusted they both > work very well and are trouble free. I know randy is not a fan of > the air model but I have to say that I have never had a problem with > either model and that includes about 7 years use on each. With the > air model you need to maintain pressure to keep water in the bowl > but even if you don't, the wated drains to the hopper which acts as > a trap and seals the toilet from the tank. > Both air and electric models are an excellent product that, if > maintained will last for many years. > Rich D. '99LXi43' CT > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Randy Merrill" > > > > > > > > Hi Everyone, > > > > > > I am going to replace the Microphor toilet in my 1993 > Wanderlodge. > > The > > > toilet has never worked correctly and I am tired of fooling with > it. > > > Can anyone suggest a NON MICROPHOR air assisted toilet for > > replacement? > > > > > > > > > Thanks in advance for any advice you can give me. > > > > > > > > > Randy Merrill > > > > > > |
