3208 on the road
08-02-2006, 15:27
3208 on the road
Milwaukee to Lewiston ID on I-90 to Missoula MT to US 12 over the divide to
Lewiston. A great route, very scenic and no bad grades. Bought some land out there and set up a pull through site with all the amenities. Did PM to the truck for the several trips I need to take before the snow flies after words did a couple of short trips. Lost a small hose in the coolant system 75 miles from the house, needed a 1/8" pipe plug to fix that. Real problem was the Dello Mobil 15/40. Used 3 qts. in 400 miles, did much better on Rotella. Called Dupree and cried, he made some suggestions. I went with 30 straight weight and a couple of cans of STP and headed west. It was real hot and I kept the speed at 60 mph. Started out using direct @ 2000 rpm, 195 coolant and oil sump temp. After a while I went to OD and tried keeping the engine down to 1600 rpm. Oil temp went down to 150, that caught my attention as it was damn near that hot on the road surface. Cat sez to keep engine speed down as it will save fuel, it's the truth. I was at 38k gvw and averaged over 8 mpg, and my toter is not as aerodynamic as a bus. The real deal was I used only one qt. of oil in 3400 miles. On the return trip I got a little impatient and picked up the pace, mileage dropped as speed picked up. Worst was 7 on the last leg running 70 @ 1900 into a serious head wind. Back in the day, I always was a straight weight guy, I guess after this experience I still am. Heck with that multi weight stuff, it don't get it as far as I'm concerned. I used tractor oil bought at a Fleet Farm store, it was a good price too. I need to get that 10 speed in my FC. MH [Non-text portions of this message have been removed] |
08-03-2006, 01:58
3208 on the road
Hello Mike,
Don't want to get thread started on the subject of what oil to use but I use Rotella 20W-40 and didn't have to add any on round trip from SAT to Ouray (about 3000 miles) running at 60-65 mph. I've noticed that if I fill the engine to full mark on the dipstick it will quickly blow out or consume oil down about 1/2 to 2/3 of the way to the "add" mark on the dipstick. After that, the oil consumption is nil. All that said, you may want to watch where you carry your oil level as it may save you some money to control it a little lower. Before I retired in 2000, I made lube oil for Pennzoil and Conoco for a few years and saw a lot of engine tests and other lube research in the process. As for STP, I don't recommend it for car or coach. A lot of work done out there on any good quality oil to get the right balance of vicosity and lubricity for a given application. The average Joe doesn't have enough information to start modifying a lube blend. Regards, Eric 84FC35SB --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Milwaukee to Lewiston ID on I-90 to Missoula MT to US 12 over the divide to Lewiston. > A great route, very scenic and no bad grades. Bought some land out there and set up a pull through site with all the amenities. > Did PM to the truck for the several trips I need to take before the snow flies after words did a couple of short trips. Lost a small hose in the coolant system 75 miles from the house, needed a 1/8" pipe plug to fix that. Real problem was the Dello Mobil 15/40. Used 3 qts. in 400 miles, did much better on Rotella. Called Dupree and cried, he made some suggestions. I went with 30 straight weight and a couple of cans of STP and headed west. > It was real hot and I kept the speed at 60 mph. Started out using direct @ 2000 rpm, 195 coolant and oil sump temp. After a while I went to OD and tried keeping the engine down to 1600 rpm. Oil temp went down to 150, that caught my attention as it was damn near that hot on the road surface. > Cat sez to keep engine speed down as it will save fuel, it's the truth. I was at 38k gvw and averaged over 8 mpg, and my toter is not as aerodynamic as a bus. The real deal was I used only one qt. of oil in 3400 miles. On the return trip I got a little impatient and picked up the pace, mileage dropped as speed picked up. Worst was 7 on the last leg running 70 @ 1900 into a serious head wind. > Back in the day, I always was a straight weight guy, I guess after this experience I still am. Heck with that multi weight stuff, it don't get it as far as I'm concerned. I used tractor oil bought at a Fleet Farm store, it was a good price too. > I need to get that 10 speed in my FC. > MH > > > [Non-text portions of this message have been removed] > |
08-03-2006, 02:15
3208 on the road
Eric Johnson,
Allow me to impose on your knowledge. Can you tell me what you think is the best oil for a 1986 Detroit Diesel 8V92TA, 475hp. engine. Howard Truitt Camilla, Ga. 86 8V92 PT40 [Non-text portions of this message have been removed] |
08-03-2006, 02:33
3208 on the road
Hello Howard,
I'm no expert on specific engine applications. My recommendation would be to use the weight and type recommended by the engine manufacturer. I noticed that Harvey Lawrence has a document about lube oil in the "Files" section. In that article he says you should only use a single weight oil in a Detroit Diesel due to the type of engine it is. I assume he based that on manufacturer recommendation. Harvey also makes some excellent points about the formulation and function of lube oil in his article. Regards, Eric 8435FCSB --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Eric Johnson, > Allow me to impose on your knowledge. > Can you tell me what you think is the best > oil for a 1986 Detroit Diesel 8V92TA, 475hp. engine. > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > > [Non-text portions of this message have been removed] > |
08-03-2006, 03:04
3208 on the road
Mike:
When I was driving thru the hills of Kentucky and West Virginia and had the problems with my crossover pipe I noticed a direct correlation between exhaust gas temperatures and oil consumption. Prior to the exhaust repair, I was running EGT's at the high end of 1100-1200 amd after the fix high was only 900 and that was very infrequent. I was using oil before the fix and consumption dropped to almost zero after the exhaust repair. I have Rotella Synthetic in it. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Milwaukee to Lewiston ID on I-90 to Missoula MT to US 12 over the divide to Lewiston. > A great route, very scenic and no bad grades. Bought some land out there and set up a pull through site with all the amenities. > Did PM to the truck for the several trips I need to take before the snow flies after words did a couple of short trips. Lost a small hose in the coolant system 75 miles from the house, needed a 1/8" pipe plug to fix that. Real problem was the Dello Mobil 15/40. Used 3 qts. in 400 miles, did much better on Rotella. Called Dupree and cried, he made some suggestions. I went with 30 straight weight and a couple of cans of STP and headed west. > It was real hot and I kept the speed at 60 mph. Started out using direct @ 2000 rpm, 195 coolant and oil sump temp. After a while I went to OD and tried keeping the engine down to 1600 rpm. Oil temp went down to 150, that caught my attention as it was damn near that hot on the road surface. > Cat sez to keep engine speed down as it will save fuel, it's the truth. I was at 38k gvw and averaged over 8 mpg, and my toter is not as aerodynamic as a bus. The real deal was I used only one qt. of oil in 3400 miles. On the return trip I got a little impatient and picked up the pace, mileage dropped as speed picked up. Worst was 7 on the last leg running 70 @ 1900 into a serious head wind. > Back in the day, I always was a straight weight guy, I guess after this experience I still am. Heck with that multi weight stuff, it don't get it as far as I'm concerned. I used tractor oil bought at a Fleet Farm store, it was a good price too. > I need to get that 10 speed in my FC. > MH > > > [Non-text portions of this message have been removed] > |
08-03-2006, 03:09
3208 on the road
Yeah, well what ever. Multi weight oils are a marketing tool used to appeal to
those who don't like to think about technical issues. Them engineers who make the stuff have a point of view but my laboratory is my road use and what the dip stick sez. That's real world experience, at least in my world. I would get 1000 miles out of Rotella before it would start to go away on level, the Dello didn't come close to that and we are talking 55 gallon drum supply, not bulk. My engine has 60k miles on a out of frame major overhaul and 3 ring conversion was done as was the roller cam update. Those who aren't satisfied with oil consumption in their personal units might consider the change to straight weight. Keep in mind, warm up times are increased a little and one has to be mindful of the time of year. As for my drum of Dello, we will attempt to foist it on our many diesel pick up customers, I'm going back to the old ways. MH ----- Original Message ----- From: Eric Johnson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 03, 2006 8:58 AM Subject: [WanderlodgeForum] Re: 3208 on the road Hello Mike, Don't want to get thread started on the subject of what oil to use but I use Rotella 20W-40 and didn't have to add any on round trip from SAT to Ouray (about 3000 miles) running at 60-65 mph. I've noticed that if I fill the engine to full mark on the dipstick it will quickly blow out or consume oil down about 1/2 to 2/3 of the way to the "add" mark on the dipstick. After that, the oil consumption is nil. All that said, you may want to watch where you carry your oil level as it may save you some money to control it a little lower. Before I retired in 2000, I made lube oil for Pennzoil and Conoco for a few years and saw a lot of engine tests and other lube research in the process. As for STP, I don't recommend it for car or coach. A lot of work done out there on any good quality oil to get the right balance of vicosity and lubricity for a given application. The average Joe doesn't have enough information to start modifying a lube blend. Regards, Eric 84FC35SB --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Milwaukee to Lewiston ID on I-90 to Missoula MT to US 12 over the divide to Lewiston. > A great route, very scenic and no bad grades. Bought some land out there and set up a pull through site with all the amenities. > Did PM to the truck for the several trips I need to take before the snow flies after words did a couple of short trips. Lost a small hose in the coolant system 75 miles from the house, needed a 1/8" pipe plug to fix that. Real problem was the Dello Mobil 15/40. Used 3 qts. in 400 miles, did much better on Rotella. Called Dupree and cried, he made some suggestions. I went with 30 straight weight and a couple of cans of STP and headed west. > It was real hot and I kept the speed at 60 mph. Started out using direct @ 2000 rpm, 195 coolant and oil sump temp. After a while I went to OD and tried keeping the engine down to 1600 rpm. Oil temp went down to 150, that caught my attention as it was damn near that hot on the road surface. > Cat sez to keep engine speed down as it will save fuel, it's the truth. I was at 38k gvw and averaged over 8 mpg, and my toter is not as aerodynamic as a bus. The real deal was I used only one qt. of oil in 3400 miles. On the return trip I got a little impatient and picked up the pace, mileage dropped as speed picked up. Worst was 7 on the last leg running 70 @ 1900 into a serious head wind. > Back in the day, I always was a straight weight guy, I guess after this experience I still am. Heck with that multi weight stuff, it don't get it as far as I'm concerned. I used tractor oil bought at a Fleet Farm store, it was a good price too. > I need to get that 10 speed in my FC. > MH > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
08-03-2006, 03:52
3208 on the road
Howard:
If you want a lot of info and comments on the Detroit Diesel engine, you should also join the MCI bus nut forum. Gosh they had lots to say LOL, and lot of info as well Bill "Howard O. Truitt" Eric Johnson, Allow me to impose on your knowledge. Can you tell me what you think is the best oil for a 1986 Detroit Diesel 8V92TA, 475hp. engine. Howard Truitt Camilla, Ga. 86 8V92 PT40 [Non-text portions of this message have been removed] --------------------------------- The best gets better. See why everyone is raving about the All-new Yahoo! Mail. [Non-text portions of this message have been removed] |
08-03-2006, 04:43
3208 on the road
Howard, there is a very good technical article on oil recommendations on
Detroit Diesel's web site. You'll have to look for it as I have lost the specific link but I would highly recommend that all DD folks download, read and save it. Jerry Mississippi Gulf Coast Still Looking _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Eric Johnson Sent: Thursday, August 03, 2006 9:33 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: 3208 on the road Hello Howard, I'm no expert on specific engine applications. My recommendation would be to use the weight and type recommended by the engine manufacturer. I noticed that Harvey Lawrence has a document about lube oil in the "Files" section. In that article he says you should only use a single weight oil in a Detroit Diesel due to the type of engine it is. I assume he based that on manufacturer recommendation. Harvey also makes some excellent points about the formulation and function of lube oil in his article. Regards, Eric 8435FCSB --- In WanderlodgeForum@ yahoogroups.com, "Howard O. Truitt" > > Eric Johnson, > Allow me to impose on your knowledge. > Can you tell me what you think is the best > oil for a 1986 Detroit Diesel 8V92TA, 475hp. engine. > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
08-04-2006, 09:24
3208 on the road
Howard; when I had my 91 DD overhauled by the DD dealer they recomended Delo
40 wt for the summer and Delo 30 wt for winter driving. Dave 91 WLWB PT 40 >From: Wilhelmus Schreurs >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: 3208 on the road >Date: Thu, 3 Aug 2006 11:52:02 -0400 (EDT) > >Howard: > If you want a lot of info and comments on the Detroit Diesel engine, you >should also join the MCI bus nut forum. Gosh they had lots to say LOL, and >lot of info as well > > Bill > >"Howard O. Truitt" > Eric Johnson, >Allow me to impose on your knowledge. >Can you tell me what you think is the best >oil for a 1986 Detroit Diesel 8V92TA, 475hp. engine. >Howard Truitt >Camilla, Ga. >86 8V92 PT40 > >[Non-text portions of this message have been removed] > > > > > > >--------------------------------- >The best gets better. See why everyone is raving about the All-new Yahoo! >Mail. > >[Non-text portions of this message have been removed] > |
08-04-2006, 09:35
3208 on the road
Eric: For what it's worth, I also use Rotella in my 8v92, with very good
results. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Eric Johnson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 03, 2006 8:58 AM Subject: [WanderlodgeForum] Re: 3208 on the road Hello Mike, Don't want to get thread started on the subject of what oil to use but I use Rotella 20W-40 and didn't have to add any on round trip from SAT to Ouray (about 3000 miles) running at 60-65 mph. I've noticed that if I fill the engine to full mark on the dipstick it will quickly blow out or consume oil down about 1/2 to 2/3 of the way to the "add" mark on the dipstick. After that, the oil consumption is nil. All that said, you may want to watch where you carry your oil level as it may save you some money to control it a little lower. Before I retired in 2000, I made lube oil for Pennzoil and Conoco for a few years and saw a lot of engine tests and other lube research in the process. As for STP, I don't recommend it for car or coach. A lot of work done out there on any good quality oil to get the right balance of vicosity and lubricity for a given application. The average Joe doesn't have enough information to start modifying a lube blend. Regards, Eric 84FC35SB --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Milwaukee to Lewiston ID on I-90 to Missoula MT to US 12 over the divide to Lewiston. > A great route, very scenic and no bad grades. Bought some land out there and set up a pull through site with all the amenities. > Did PM to the truck for the several trips I need to take before the snow flies after words did a couple of short trips. Lost a small hose in the coolant system 75 miles from the house, needed a 1/8" pipe plug to fix that. Real problem was the Dello Mobil 15/40. Used 3 qts. in 400 miles, did much better on Rotella. Called Dupree and cried, he made some suggestions. I went with 30 straight weight and a couple of cans of STP and headed west. > It was real hot and I kept the speed at 60 mph. Started out using direct @ 2000 rpm, 195 coolant and oil sump temp. After a while I went to OD and tried keeping the engine down to 1600 rpm. Oil temp went down to 150, that caught my attention as it was damn near that hot on the road surface. > Cat sez to keep engine speed down as it will save fuel, it's the truth. I was at 38k gvw and averaged over 8 mpg, and my toter is not as aerodynamic as a bus. The real deal was I used only one qt. of oil in 3400 miles. On the return trip I got a little impatient and picked up the pace, mileage dropped as speed picked up. Worst was 7 on the last leg running 70 @ 1900 into a serious head wind. > Back in the day, I always was a straight weight guy, I guess after this experience I still am. Heck with that multi weight stuff, it don't get it as far as I'm concerned. I used tractor oil bought at a Fleet Farm store, it was a good price too. > I need to get that 10 speed in my FC. > MH > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
