tank life expectancy
08-05-2006, 07:30
What is the life expectancy of the holding tanks and propane tank? How
often does the propane tank need to be inspected? I know if my propane
grill tank has rust or is over 5 years old they won't fill it unless it
is inspected.
Gardner, still wannabe, but closer
08-06-2006, 06:04
Gardner: I do not know the technical answer if there is one. Someone may. I
cleaned minor surface rust from my tank, used ospho to treat it and repainted it
with high quality engine paint. I haven't had any refill problems, and do not
have rust.
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Saturday, August 05, 2006 2:30 PM
Subject: [WanderlodgeForum] tank life expectancy
is inspected.
08-06-2006, 13:47
Leroy,
Thanks.
If I purchase the coach I am looking at this time, that will be
one of the things I will put in the 'must do' list. Do the fill
stations actually check the tanks when they fill an RV? I would
think it would be a legal requirement.
Gardner, closer to a BE, but still a Wannabe.
Someone may. I cleaned minor surface rust from my tank, used ospho
to treat it and repainted it with high quality engine paint. I
haven't had any refill problems, and do not have rust.
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Gardner Yeaw
tank? How
propane
unless it
> is inspected.
08-07-2006, 00:08
Gardner:
Before I cleaned my tank up, I asked BB about time limits for propane tanks. No
one knew the answer. I check my lines periodically for leaks using bubble soap.
I have not had a refill station question or inspect my tank before filling. It
looks new and is relabeled. Soooo, I do not know the answer.
Leroy Eckert
1990WB-40
Niceville, FL
Sent: Sunday, August 06, 2006 8:47 PM
Subject: [WanderlodgeForum] Re: tank life expectancy
Leroy,
Thanks.
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Gardner Yeaw
tank? How
propane
unless it
> is inspected.
08-07-2006, 00:41
My understanding is that the ASME tanks don't require recertification like the
grill tanks do. Of course if they see something that could be dangerous when
you have the tanks refilled, they should not fill them and inform you of the
problem.
Bruce Morris (919)872-7635 Raleigh, NC
Webmaster - WOO (http://www.wanderlodge.us)
1983 WL FC35RB
FMCA: 7142s Ham Radio: KI4ME
Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv
Sent: Sunday, August 06, 2006 9:47 PM
Leroy,
Thanks.
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Gardner Yeaw
tank? How
propane
unless it
> is inspected.
08-07-2006, 10:44
Leroy,
I was checking and, as expected, a horizontal tank for an RV is slightly
more than a vertical one.
Vertical 40 gallon—79.95
Horizontal 9.8 gallon--$420 (on sale)
I will check more listings, but I think it’s pretty clear it will be
expensive if needed.
Gardner, Closer, but still a wannabe
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Leroy Eckert
Sent: Monday, August 07, 2006 8:08 AM
Subject: Re: [WanderlodgeForum] Re: tank life expectancy
Gardner:
No one knew the answer. I check my lines periodically for leaks using bubble
soap. I have not had a refill station question or inspect my tank before
filling. It looks new and is relabeled. Soooo, I do not know the answer.
Leroy Eckert
1990WB-40
Niceville, FL
Leroy,
Thanks.
, "Leroy Eckert"
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Gardner Yeaw
tank? How
propane
unless it
> is inspected.
08-07-2006, 10:49
Leroy,
Sorry, the last post should have said 40LB 10 gallon
Gardner:
Leroy Eckert
1990WB-40
Niceville, FL
Leroy,
Thanks.
, "Leroy Eckert"
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Gardner Yeaw
tank? How
propane
unless it
> is inspected.
08-07-2006, 11:01
Gardner
Do you really think you will have invest in a new tank?
the tank on our 77 is original still holds propane and we expect to
get a lot more years out of it and ours certainly holds more than 10
gallons more like 35-40 dependent on the weather
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, Gardner Yeaw wrote:
> Leroy,
slightly
> I will check more listings, but I think it's pretty clear it will be
> Gardner:
propane tanks.
using bubble
> Leroy Eckert
> 1990WB-40
> Niceville, FL
> From: Gardner Yeaw
> Leroy,
> Thanks.
> , "Leroy Eckert"
> > Leroy Eckert
> > 1990 WB-40
> > Niceville, FL
> > From: Gardner Yeaw
> tank? How
> propane
> unless it
> > is inspected.
08-07-2006, 12:23
Stephen,
I am not sure. I only looked at the tank, I didn’t try to physically
check how deep the rust was. It is just a mater safety more than anything
else. If it ruptured, 40 gallons of propane could be a pretty nasty
explosion.
Gardner
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Stephen Birtles
Sent: Monday, August 07, 2006 7:01 PM
Gardner
Stephen 77fc35
, Gardner Yeaw
> Leroy,
slightly
> [mailto: WanderlodgeForum@yahoogroups.com
> Gardner:
propane tanks.
using bubble
> Leroy Eckert
> 1990WB-40
> Niceville, FL
> From: Gardner Yeaw
> Leroy,
> Thanks.
> , "Leroy Eckert"
> > Leroy Eckert
> > 1990 WB-40
> > Niceville, FL
> > From: Gardner Yeaw
> tank? How
> propane
> unless it
> > is inspected.
08-08-2006, 08:24
Gardner:
I don't have my book in front of me but I think my tank is around 49 gallons.
Unless the rust is really crazy I do not think there is a problem. Since I
converted to diesel fired Hydronic heat I have enough propane for 2-3 years. My
gas fires the outside grills (2) and the stove. That's it.
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Monday, August 07, 2006 5:49 PM
Subject: RE: [WanderlodgeForum] Re: tank life expectancy
Leroy,
Gardner:
Leroy Eckert
1990WB-40
Niceville, FL
Leroy,
Thanks.
, "Leroy Eckert"
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Gardner Yeaw
tank? How
propane
unless it
> is inspected.
