When is hot to hot.
08-07-2006, 14:55
When is hot to hot.
I was wondering what other 250 HP cats are running for maximum boost
and pryro temps?
Thanks
JIM
1982 FCRB
Yorba Linda, ca
08-07-2006, 15:24
When is hot to hot.
I've got a 210hp with an aftermarket turbo. It runs around 950
degrees on a steep hill. I had some exhaust problems this summer and
it was running rich. For a while it would run around 1150 on a steep
hill but climbed to around 1250 when the turbo wasn't turning fast
enough and it was running at its esritch. On a flat road at 60mph it
runs less than 600 degrees. Air temperature seems to make a
difference. According to what I have read, pistons will start melting
with continual EGT's around 1350.
My boost has never registered 10psi. Highest around 7 psi I think. I
don't want anymore boost given the limits of an NA engine.
What are you running?
Kerry
82 FC 35
Denver
> and pryro temps?
> Thanks
> JIM
> 1982 FCRB
> Yorba Linda, ca
08-08-2006, 02:12
When is hot to hot.
I don't know yet. I have to put the bus on a grade and see what I got.
I will let you know after a road test.
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards
Sent: Monday, August 07, 2006 8:25 PM
Subject: [WanderlodgeForum] Re: When is hot to hot.
Kerry
82 FC 35
Denver
> and pryro temps?
> Thanks
> JIM
> 1982 FCRB
> Yorba Linda, ca
08-08-2006, 15:28
When is hot to hot.
My '84 would run about 15psi and ~1100*.
- Jeff Miller
in Holland, MI
> and pryro temps?
> Thanks
> JIM
> 1982 FCRB
> Yorba Linda, ca
