Diesel Fuel leak
08-08-2006, 15:04
Diesel Fuel leak
I have noticed a very small amount of diesel fuel in the engine valley.
I can also smell it outside the front of the bus after a drive. I have looked all over and only found a one loose bolt on the pump. It was a bolt on the side that faces the valley or back of the engine. I tightend it and I still have fuel in the valley. I have checked all around and can't locate any leaks. Should I be real concerned with this leak? It's not much.... Engine still runs fine...would it be taking a big chance to go one a longer trip with this leak? Thanks Chris Reed 83 FC35 SB Plant City, FL. |
08-08-2006, 15:13
Diesel Fuel leak
Throttle shaft seal is a common culprit, also check to be sure all of
the injector lines are tight. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Chris" wrote: > > I have noticed a very small amount of diesel fuel in the engine valley. > I can also smell it outside the front of the bus after a drive. I have > looked all over and only found a one loose bolt on the pump. It was a > bolt on the side that faces the valley or back of the engine. I > tightend it and I still have fuel in the valley. I have checked all > around and can't locate any leaks. > Should I be real concerned with this leak? It's not much.... > Engine still runs fine...would it be taking a big chance to go one a > longer trip with this leak? > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL. > |
08-08-2006, 15:14
Diesel Fuel leak
Start washing the pump and valley with brake clean, then blue paper shop towels
work good. Keep cleaning and running the engine until you find the source of the leak or at least the area it's coming from, then I can tell you what's up. MH ----- Original Message ----- From: Chris To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 08, 2006 10:04 PM Subject: [WanderlodgeForum] Diesel Fuel leak I have noticed a very small amount of diesel fuel in the engine valley. I can also smell it outside the front of the bus after a drive. I have looked all over and only found a one loose bolt on the pump. It was a bolt on the side that faces the valley or back of the engine. I tightend it and I still have fuel in the valley. I have checked all around and can't locate any leaks. Should I be real concerned with this leak? It's not much.... Engine still runs fine...would it be taking a big chance to go one a longer trip with this leak? Thanks Chris Reed 83 FC35 SB Plant City, FL. [Non-text portions of this message have been removed] |
08-08-2006, 15:23
Diesel Fuel leak
I was experiencing the same symptoms on our '81 FC and it turned out to be the
return line was leaking. I believe it was on top of the tranny. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Chris To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 08, 2006 8:04 PM Subject: [WanderlodgeForum] Diesel Fuel leak I have noticed a very small amount of diesel fuel in the engine valley. I can also smell it outside the front of the bus after a drive. I have looked all over and only found a one loose bolt on the pump. It was a bolt on the side that faces the valley or back of the engine. I tightend it and I still have fuel in the valley. I have checked all around and can't locate any leaks. Should I be real concerned with this leak? It's not much.... Engine still runs fine...would it be taking a big chance to go one a longer trip with this leak? Thanks Chris Reed 83 FC35 SB Plant City, FL. [Non-text portions of this message have been removed] |
08-08-2006, 15:24
Diesel Fuel leak
Wash the engine clean and Dust it with Talc then look for the wet
spot. Mike, Dont worry I wont elaborate Greg O'Connor 94PtRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Chris" wrote: > > I have noticed a very small amount of diesel fuel in the engine valley. > I can also smell it outside the front of the bus after a drive. I have > looked all over and only found a one loose bolt on the pump. It was a > bolt on the side that faces the valley or back of the engine. I > tightend it and I still have fuel in the valley. I have checked all > around and can't locate any leaks. > Should I be real concerned with this leak? It's not much.... > Engine still runs fine...would it be taking a big chance to go one a > longer trip with this leak? > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL. > |
08-09-2006, 02:34
Diesel Fuel leak
Chris,
Follow the previous posts, get it clean, this is good advice. In the 3208 Cat manual there is a picture of two rear drain plugs, These plugs have O ring seals, Check these seals. Careful because fuel runs out of these holes. I will second Jeff motion, It is probably the throttle rod seal. I will add an additional posting on this topic. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Chris" wrote: > > I have noticed a very small amount of diesel fuel in the engine valley. > I can also smell it outside the front of the bus after a drive. I have > looked all over and only found a one loose bolt on the pump. It was a > bolt on the side that faces the valley or back of the engine. I > tightend it and I still have fuel in the valley. I have checked all > around and can't locate any leaks. > Should I be real concerned with this leak? It's not much.... > Engine still runs fine...would it be taking a big chance to go one a > longer trip with this leak? > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL. > |
08-09-2006, 13:53
Diesel Fuel leak
Does the pump have to be removed to replace the throttle seal?
So the bolt that I tightened on the pump has an o-ring in it..that might still be leaking? Thanks Chris Reed 83 FC35 SB Plant City, FL pattypape Chris, Follow the previous posts, get it clean, this is good advice. In the 3208 Cat manual there is a picture of two rear drain plugs, These plugs have O ring seals, Check these seals. Careful because fuel runs out of these holes. I will second Jeff motion, It is probably the throttle rod seal. I will add an additional posting on this topic. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Chris" wrote: > > I have noticed a very small amount of diesel fuel in the engine valley. > I can also smell it outside the front of the bus after a drive. I have > looked all over and only found a one loose bolt on the pump. It was a > bolt on the side that faces the valley or back of the engine. I > tightend it and I still have fuel in the valley. I have checked all > around and can't locate any leaks. > Should I be real concerned with this leak? It's not much.... > Engine still runs fine...would it be taking a big chance to go one a > longer trip with this leak? > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL. > [Non-text portions of this message have been removed] |
08-09-2006, 13:57
Diesel Fuel leak
I've read instructions and seen pictures of it being done with the
pump on the engine. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Chris Reed wrote: > > Does the pump have to be removed to replace the throttle seal? > So the bolt that I tightened on the pump has an o-ring in it..that might still be leaking? > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL > > pattypape > > > Chris, > > Follow the previous posts, get it clean, this is good advice. > > In the 3208 Cat manual there is a picture of two rear drain plugs, > These plugs have O ring seals, Check these seals. Careful because > fuel runs out of these holes. > I will second Jeff motion, It is probably the throttle rod seal. > I will add an additional posting on this topic. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, "Chris" > wrote: > > > > I have noticed a very small amount of diesel fuel in the engine > valley. > > I can also smell it outside the front of the bus after a drive. I > have > > looked all over and only found a one loose bolt on the pump. It > was a > > bolt on the side that faces the valley or back of the engine. I > > tightend it and I still have fuel in the valley. I have checked > all > > around and can't locate any leaks. > > Should I be real concerned with this leak? It's not much.... > > Engine still runs fine...would it be taking a big chance to go one > a > > longer trip with this leak? > > Thanks > > Chris Reed > > 83 FC35 SB > > Plant City, FL. > > > > > > > > > [Non-text portions of this message have been removed] > |
08-10-2006, 02:05
Diesel Fuel leak
Chris,
There is a rear drain plug and a mounting bolt with seals. Used for draining the pump, either or both can leak. All the rear seals and throttle seal can be replaced without removing the pump. I "DO NOT" think you want to remove the injection pump Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, Chris Reed > > Does the pump have to be removed to replace the throttle seal? > So the bolt that I tightened on the pump has an o-ring in it..that might still be leaking? > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL > > pattypape > > > Chris, > > Follow the previous posts, get it clean, this is good advice. > > In the 3208 Cat manual there is a picture of two rear drain plugs, > These plugs have O ring seals, Check these seals. Careful because > fuel runs out of these holes. > I will second Jeff motion, It is probably the throttle rod seal. > I will add an additional posting on this topic. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, "Chris" > wrote: > > > > I have noticed a very small amount of diesel fuel in the engine > valley. > > I can also smell it outside the front of the bus after a drive. I > have > > looked all over and only found a one loose bolt on the pump. It > was a > > bolt on the side that faces the valley or back of the engine. I > > tightend it and I still have fuel in the valley. I have checked > all > > around and can't locate any leaks. > > Should I be real concerned with this leak? It's not much.... > > Engine still runs fine...would it be taking a big chance to go one > a > > longer trip with this leak? > > Thanks > > Chris Reed > > 83 FC35 SB > > Plant City, FL. > > > > > > > > > [Non-text portions of this message have been removed] > |
