Mirrors
08-10-2006, 09:56
Mirrors
I have a 84fc 35' I just picked it up at a cat place after an oil
chance. The drivers side mirror was hit by a truck ?? When we moved it back I had forgot where it should be. I don't use it much. I told them it should stick out like the one on the right, it points to about one o'clock. After we got the left one set at about 11 o'clock so it would look the same. I then drove to my storage place and had to look out the windshield to use it. I seems the before I could look at it from the side window. Any ideas? Dennis Walker cram-alot-inn kc mo |
08-10-2006, 10:07
Mirrors
Sure, pull the left mirror arm back till you can use out of the side window.
They won't match exactly and couldn't have before. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: walker To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 10, 2006 2:56 PM Subject: [WanderlodgeForum] Mirrors I have a 84fc 35' I just picked it up at a cat place after an oil chance. The drivers side mirror was hit by a truck ?? When we moved it back I had forgot where it should be. I don't use it much. I told them it should stick out like the one on the right, it points to about one o'clock. After we got the left one set at about 11 o'clock so it would look the same. I then drove to my storage place and had to look out the windshield to use it. I seems the before I could look at it from the side window. Any ideas? Dennis Walker cram-alot-inn kc mo [Non-text portions of this message have been removed] |
08-10-2006, 10:47
Mirrors
Dennis, the previous owner of our 86FC hit something and broke the
inner part of the drivers side mirror. The original mirror I have to look out the drivers side window. We have new Remco mirrors and they will be adjusted to look out the front windshield. The arms on the neweer mirrors will stick wayyyy out if pushed out to the side. To get close to the adjustment from outside put your head against the side of the coach and adjust till you can see the drivers seat. Then go inside and finish the adjustment from the seat. BE CAREFUL not to break the original mirror inside. They are no longer made and very hard to find replacements. There is a cap with a slot on it, the cap unscrews, under the cap is a large nut, that is holding the arm in place. You may want to loosen and retighten once back in place, PB Blaster my be needed! I would check very closely to be sure they did not break the inside. If you find they broke something you will need new mirrors ..the bolt pattern is very hard to match we (Remco and I) are working on a prototype to have an adjustable bolt pattern on the mirror base. Should see them in Charlotte next week for final fitting. Scott B 86FC35 "RUBY" 4SALE SC --- In WanderlodgeForum@yahoogroups.com, "walker" > > I have a 84fc 35' I just picked it up at a cat place after an oil > chance. The drivers side mirror was hit by a truck ?? When we moved it > back I had forgot where it should be. I don't use it much. I told them > it should stick out like the one on the right, it points to about one > o'clock. After we got the left one set at about 11 o'clock so it would > look the same. I then drove to my storage place and had to look out the > windshield to use it. I seems the before I could look at it from the > side window. Any ideas? > Dennis Walker > cram-alot-inn > kc mo > |
08-10-2006, 11:24
Mirrors
Dennis,
Cram-alot-inn, that's catchy! Totally a matter of personal preference, so put it where you like it. I wouldn't care for the driver's side in front of me, God knows I don't see enough of what goes on anyway. So..I like the side mirrors to reference the coach just so that I can see a tiny bit of the side in a relaxed driving position. This way I get the greatest field of vision to the rear. This works best for me whatever I drive. Side window (DS),windshield (PS) about 10:45 @ 1:30 from the tip of my nose. Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > Sure, pull the left mirror arm back till you can use out of the side window. They won't match exactly and couldn't have before. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: walker > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, August 10, 2006 2:56 PM > Subject: [WanderlodgeForum] Mirrors > > > I have a 84fc 35' I just picked it up at a cat place after an oil > chance. The drivers side mirror was hit by a truck ?? When we moved it > back I had forgot where it should be. I don't use it much. I told them > it should stick out like the one on the right, it points to about one > o'clock. After we got the left one set at about 11 o'clock so it would > look the same. I then drove to my storage place and had to look out the > windshield to use it. I seems the before I could look at it from the > side window. Any ideas? > Dennis Walker > cram-alot-inn > kc mo > > > > > > [Non-text portions of this message have been removed] > |
08-11-2006, 00:00
Mirrors
> > I have a 84fc 35' I just picked it up at a cat place after an oil > chance. The drivers side mirror was hit by a truck ?? When we moved it > back I had forgot where it should be. I don't use it much. I told them > it should stick out like the one on the right, it points to about one > o'clock. After we got the left one set at about 11 o'clock so it would > look the same. I then drove to my storage place and had to look out the > windshield to use it. I seems the before I could look at it from the > side window. Any ideas? > Dennis Walker > cram-alot-inn > kc mo > Dennis, you really need to get that old bird and it's driver out on the road the best way to adjust mirrors is experiance. Jim |
08-13-2006, 10:07
Mirrors
Thanks for your help. You all have gave good advice.
Thanks Again Walker Cram-Alot-Inn 84fc35 k.c. mo |
08-13-2006, 11:35
Mirrors
Ok Walker, Cram-alot-inn, then go RV'n.
Remember, those mirrors wont do any good sitting still. They help you see where you have been been, right? Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "walker" > > Thanks for your help. You all have gave good advice. > Thanks Again > Walker > Cram-Alot-Inn > 84fc35 > k.c. mo > |
08-16-2006, 02:28
Mirrors
To: Jeff Miller
Hello Jeff, I am wondering if you know a good mirror to replace the old ones on my 1979, 35' FC. Thanks, Harry in Milwaukee |
08-16-2006, 14:34
Mirrors
I don't really, other than the original supplier: Ramco, in Indiana.
They usually have some used mirrors at the RIV, and occasionally people remove older Ramco mirrors and install newer chrome or dual- power mirrors and sell the old. Post that you're looking, and check the classified areas and you might find a deal. Other than this I'm not sure what models can be found that will fit the radius of the bus front, but I believe that many of the older MCI buses have the same radius (and thus can become donors). - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "harrythepilot" > > To: Jeff Miller > > Hello Jeff, > > I am wondering if you know a good mirror to replace the old ones > on my 1979, 35' FC. > > Thanks, Harry in Milwaukee > |
08-08-2007, 08:48
Mirrors
George, can't help you on your mirror problem, but we have had 80+ no
humidity in Montana. Ernie Ekberg 83PT40 Livingston, Mt smelling smoke from all the fires- no fires here ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
