Another vacuum generator question
09-11-2006, 06:40
My apologies for plaguing the list with vacuum generator questions but
I'm trying to figure out if I can retrofit a different vacuum generator. The original had 3 ports in addition to the threaded supply port. The are labeled with letters "E" "V" and "s". The "V' is the main vacuum line to the vacuum canister on the cruise control. (I believe). The "e" is exhaust I think because this is where it was 'leaking' or exhausting. The 's' had a vacuum hose attached to it but I don't know where it goes. Can anyone give a guess as to waht "S" means or can you tell me where the additional vaccum line terminates? Kerry 82 FC 35 Denver |
09-11-2006, 06:54
Kerry,
I can look at mine- however, it won't be for a few more weeks. I plan on many 'outside' projects on the bird' here in a few weeks when it gets closer to fall- its too hot to be out working on the outside stuff this time of year!!! I have switched all of my projects to 'indoor'. Stephen H 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Monday, September 11, 2006 2:40 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Another vacuum generator question My apologies for plaguing the list with vacuum generator questions but I'm trying to figure out if I can retrofit a different vacuum generator. The original had 3 ports in addition to the threaded supply port. The are labeled with letters "E" "V" and "s". The "V' is the main vacuum line to the vacuum canister on the cruise control. (I believe). The "e" is exhaust I think because this is where it was 'leaking' or exhausting. The 's' had a vacuum hose attached to it but I don't know where it goes. Can anyone give a guess as to waht "S" means or can you tell me where the additional vaccum line terminates? Kerry 82 FC 35 Denver ___ [Non-text portions of this message have been removed] |
09-11-2006, 07:26
Kerry,
I think I found it... Check this out http://www.gtc-products.com/?id=vacuumGen "S" - If it is a vacuum port as you say it is, could that be for a vacuum gauge or a vacuum pressure "S"ensor as indicated in the above link. I'd guess you do not need that second vacuum port unless there is something more on your coach that operates using vacuum. That's my guess. If the vacuum generator you found is inexpensive, it can't hurt to try one. But first I'd us a hand held (manual) vacuum tester. Hook it up to the cruise control bellows. Pump the vacuum tester until the bellows sucks in. Read the pressure and compare that to the vacuum generator you found on the net. Good luck. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. davidkerryedwards wrote: > My apologies for plaguing the list with vacuum generator questions but > I'm trying to figure out if I can retrofit a different vacuum > generator. The original had 3 ports in addition to the threaded > supply port. The are labeled with letters "E" "V" and "s". The "V' > is the main vacuum line to the vacuum canister on the cruise control. > (I believe). The "e" is exhaust I think because this is where it was > 'leaking' or exhausting. The 's' had a vacuum hose attached to it but > I don't know where it goes. Can anyone give a guess as to waht "S" > means or can you tell me where the additional vaccum line terminates? > > Kerry > 82 FC 35 > Denver > > __ > > > |
09-11-2006, 07:52
Curt:
Thanks. That does look like the right kind of thing although it says it is powered by nitrogen and not air. The one I found at Anders was $9.95 and I'm trying to get it thru a local distributor. They have two versions, one with more pull. I'm still working to figure out what the additional line is. I forgot to ask Bennie when I had him on the phone. Kerry --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Kerry, > > I think I found it... Check this out > http://www.gtc-products.com/?id=vacuumGen > > "S" - If it is a vacuum port as you say it is, could that be for a > vacuum gauge or a vacuum pressure "S"ensor as indicated in the above > link. I'd guess you do not need that second vacuum port unless there is > something more on your coach that operates using vacuum. > > That's my guess. > > If the vacuum generator you found is inexpensive, it can't hurt to try > one. But first I'd us a hand held (manual) vacuum tester. Hook it up to > the cruise control bellows. Pump the vacuum tester until the bellows > sucks in. Read the pressure and compare that to the vacuum generator you > found on the net. > > Good luck. > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > davidkerryedwards wrote: > > > My apologies for plaguing the list with vacuum generator questions but > > I'm trying to figure out if I can retrofit a different vacuum > > generator. The original had 3 ports in addition to the threaded > > supply port. The are labeled with letters "E" "V" and "s". The "V' > > is the main vacuum line to the vacuum canister on the cruise control. > > (I believe). The "e" is exhaust I think because this is where it was > > 'leaking' or exhausting. The 's' had a vacuum hose attached to it but > > I don't know where it goes. Can anyone give a guess as to waht "S" > > means or can you tell me where the additional vaccum line terminates? > > > > Kerry > > 82 FC 35 > > Denver > > > > __ > > > > > > > |
09-11-2006, 08:03
You might try Googling 12 Volt Vacuum Pump. There are options avalilable.
MH ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 11, 2006 1:40 PM Subject: [WanderlodgeForum] Another vacuum generator question My apologies for plaguing the list with vacuum generator questions but I'm trying to figure out if I can retrofit a different vacuum generator. The original had 3 ports in addition to the threaded supply port. The are labeled with letters "E" "V" and "s". The "V' is the main vacuum line to the vacuum canister on the cruise control. (I believe). The "e" is exhaust I think because this is where it was 'leaking' or exhausting. The 's' had a vacuum hose attached to it but I don't know where it goes. Can anyone give a guess as to waht "S" means or can you tell me where the additional vaccum line terminates? Kerry 82 FC 35 Denver [Non-text portions of this message have been removed] |
09-11-2006, 09:00
Kerry, If you find a suitable pump, I would appreciate knowing your source as I
am having a similar problem. Thanks. Alex Smith 82FC35 Tallahassee davidkerryedwards Curt: Thanks. That does look like the right kind of thing although it says it is powered by nitrogen and not air. The one I found at Anders was $9.95 and I'm trying to get it thru a local distributor. They have two versions, one with more pull. I'm still working to figure out what the additional line is. I forgot to ask Bennie when I had him on the phone. Kerry --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Kerry, > > I think I found it... Check this out > http://www.gtc-products.com/?id=vacuumGen > > " > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > davidkerryedwards wrote: > > > My apologies for plaguing the list with vacuum generator questions but > > I'm trying to figure out if I can retrofit a different vacuum > > generator. The original had 3 ports in addition to the threaded > > supply port. The are labeled with letters "E" "V" and "s". The "V' > > is the main vacuum line to the vacuum canister on the cruise control. > > (I believe). The "e" is exhaust I think because this is where it was > > 'leaking' or exhausting. The 's' had a vacuum hose attached to it but > > I don't know where it goes. Can anyone give a guess as to waht "S" > > means or can you tell me where the additional vaccum line terminates? > > > > Kerry > > 82 FC 35 > > Denver > > > > __ > > > > > > > --------------------------------- All-new Yahoo! Mail - Fire up a more powerful email and get things done faster. [Non-text portions of this message have been removed] |
09-11-2006, 09:19
I ordered both sizes of this version:
http://www.anver.com/document/vacuum%20c...ts/vacuum% 20generators/pumps-jv.h\ tm I called Anver and they gave me the name of their local supplier who should have them for me in a couple of weeks. I;ll let you know if they work. For $9.95 it's worth a shot. I don't know if they shut off once an adequate vacuum is produced. If they don't I may install a valve in the line to turn it on and off when needed. Kerry 82 FC 35 Trying to suck. Denver --- In WanderlodgeForum@yahoogroups.com, Alex Smith > > Kerry, If you find a suitable pump, I would appreciate knowing your source as I am having a similar problem. Thanks. > Alex Smith > 82FC35 > Tallahassee > > davidkerryedwards wrote: Curt: > Thanks. That does look like the right kind of thing although it says > it is powered by nitrogen and not air. The one I found at Anders > was $9.95 and I'm trying to get it thru a local distributor. They > have two versions, one with more pull. I'm still working to figure > out what the additional line is. I forgot to ask Bennie when I had > him on the phone. > > Kerry > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > Kerry, > > > > I think I found it... Check this out > > http://www.gtc-products.com/?id=vacuumGen > > > > " > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > > > > > davidkerryedwards wrote: > > > > > My apologies for plaguing the list with vacuum generator > questions but > > > I'm trying to figure out if I can retrofit a different vacuum > > > generator. The original had 3 ports in addition to the threaded > > > supply port. The are labeled with letters "E" "V" and "s". > The "V' > > > is the main vacuum line to the vacuum canister on the cruise > control. > > > (I believe). The "e" is exhaust I think because this is where it > was > > > 'leaking' or exhausting. The 's' had a vacuum hose attached to > it but > > > I don't know where it goes. Can anyone give a guess as to > waht "S" > > > means or can you tell me where the additional vaccum line > terminates? > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > __ > > > > > > > > > > > > > > > > > > --------------------------------- > All-new Yahoo! Mail - Fire up a more powerful email and get things done faster. > > [Non-text portions of this message have been removed] > |
09-11-2006, 16:29
> >The generator is a venturi unit as you know. It has a valve in it controlled by a diaphram. Air passes by the venturi and is vented. The vented air includes the air it pulls with it to create a vaccum. when enough vacum has been generated, the sensing line "s" pulls the diaphram and closes the valve. If you connect the vacum line to the sensing line no air should be comming out of the vent. If it does the diaphram has a hole in it. The vaccum line and the sensing line should be routed to a vaccum canister to hold enough vaccum to operate the billows of the cruise control. Once the canister gets enough vaccum in it the sensing line closes the the valve. I had my fill of the entire unit and replaced the curise control with an electric unit. It works very well is on fourth the size and is remoted outside of the engine compartment. Hope this helps, Jim Yorba Linda, CA 82 35 FC |
09-12-2006, 01:15
Jim:
Thanks, that explains it. I'm pretty sure mine had a leak in the diaphragm. If it didn't before I disassembled it, it definitely does now! I'm not sure the vacuum generators I have sourced have that self-control shut off feature. Did you use the Rostra Global Cruise as a replacement? How is the servo operated on that unit and how long did it take to install it? Kerry 82 FC 35 Denver- -- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > >The generator is a venturi unit as you know. It has a valve in it > controlled by a diaphram. Air passes by the venturi and is vented. The > vented air includes the air it pulls with it to create a vaccum. when > enough vacum has been generated, the sensing line "s" pulls the > diaphram and closes the valve. If you connect the vacum line to the > sensing line no air should be comming out of the vent. If it does the > diaphram has a hole in it. The vaccum line and the sensing line should > be routed to a vaccum canister to hold enough vaccum to operate the > billows of the cruise control. Once the canister gets enough vaccum in > it the sensing line closes the the valve. I had my fill of the entire > unit and replaced the curise control with an electric unit. It works > very well is on fourth the size and is remoted outside of the engine > compartment. > > Hope this helps, > > Jim > > Yorba Linda, CA > 82 35 FC > |
09-12-2006, 02:10
A little off topic, but. . . I just ran across this patent for a
new(?) device which claims to do precisely what you describe our vacuum generators accomplish. Did someone fail to patent the original? http://72.14.253.104/search?q=cache:egDT...nsati\ ng-venturi-vacuum-system-dt20060209ptan20060027235.php+self-regulating+venturi+v\ acuum+pump&hl=en&gl=us&ct=clnk&cd=5 Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > >The generator is a venturi unit as you know. It has a valve in it > controlled by a diaphram. Air passes by the venturi and is vented. The > vented air includes the air it pulls with it to create a vaccum. when > enough vacum has been generated, the sensing line "s" pulls the > diaphram and closes the valve. If you connect the vacum line to the > sensing line no air should be comming out of the vent. If it does the > diaphram has a hole in it. The vaccum line and the sensing line should > be routed to a vaccum canister to hold enough vaccum to operate the > billows of the cruise control. Once the canister gets enough vaccum in > it the sensing line closes the the valve. I had my fill of the entire > unit and replaced the curise control with an electric unit. It works > very well is on fourth the size and is remoted outside of the engine > compartment. > > Hope this helps, > > Jim > > Yorba Linda, CA > 82 35 FC > |
