Power problem in our bus
02-09-2007, 15:46
i checked at the two 50 amp breakers that are linked together in the
bedroom. they each had 110 v at the breaker and I have flipped them
several times and they feel normal. is it possible that one is bad. is
there anything else to check? thank you all for your help.
Robert Rahn
88 pt 40
Kalispell, Mt.
02-09-2007, 15:58
Did you check the input side or the outlet side of the breaker? I'm
betting you have a bad breaker if you have full voltage going to each
breaker or leg.
currently in Hondo, TX
--- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn"
> Robert Rahn
> 88 pt 40
> Kalispell, Mt.
02-09-2007, 16:01
Does the dead leg 1 have power out of the breaker? Both sides hot as Curt
suggested?
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Friday, February 09, 2007 9:46 PM
Subject: [WanderlodgeForum] Power problem in our bus
Robert Rahn
88 pt 40
Kalispell, Mt.
02-09-2007, 16:36
If both sides of the circuit breaker are hot, the only other thing I can think
of is check all of your wall outlets for GFI's and reset them. Maybe others
have ideas to help.
Leroy Eckert
Niceville, FL
Sent: Friday, February 09, 2007 10:01 PM
Subject: Re: [WanderlodgeForum] Power problem in our bus
suggested?
Leroy Eckert
Niceville, FL
Robert Rahn
88 pt 40
Kalispell, Mt.
