Lube Oil Cooler Hose Replacement
08-14-2006, 06:14
Replaced the two lube oil cooler hoses, per Ernie suggestion, with hoses
supplied by local Cat dealer. Getting the short hose in was NOT FUN. Makes you wish you could meet the engineer that designed that connection!!! Nevertheless, glad I did it now rather than out on the road as Ernie had to do. Thanks for the help Ernie. Probably would have missed them if you hadn't mentioned them on the forum. Regards, Eric in San Antonio 84FC35SBWL2 |
08-14-2006, 09:31
Glad I could help.
Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
