NAVAGATION G P S
08-15-2006, 03:39
NAVAGATION G P S
I use a Garmin street pilot 3, voice directions, you need to download large
cities from your computer, however no problem. shows speed, time, mileage, etc. Also show rest areas and next exit stuff. Walker 84fc35 kc mo [Non-text portions of this message have been removed] |
08-15-2006, 05:37
NAVAGATION G P S
I am looking for a GPS Navagation unit. I have one installed in my
Laptop that works well, but using the laptop on the Toad is unwieldy. The Magellan 360 looks like a good all-around device. Any use this unit and care to comment? Any comments on ANY unit? Thanks Jack Smith 1973FC31 SoCal |
08-15-2006, 06:46
NAVAGATION G P S
--- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith"
> > I am looking for a GPS Navagation unit. I have one installed in my > Laptop that works well, but using the laptop on the Toad is unwieldy. > The Magellan 360 looks like a good all-around device. Any use this > unit and care to comment? > Any comments on ANY unit? Jack, If you are only looking for basic GPS (location info) with POI's and basic routing, I would suggest you trade in your cell phone for the new Motorla Q from Verizon. I am running GPS on mine now with a bluetooth GPS receiver ($70-100) and it works amazingly well as it is constantly downloading map sections as you move from either Google Earth or MSN Virtual Earth, and the added benefit is you can switch to satellite view as well. You can get the Q for $100 with a new 1 year contract with Verizon via Amazon. AND, it's a great phone. I also use it as a blackberry for my e-mail and can tether my laptop to it when I don't have wi-fi available. Paul 97wb43 |
08-15-2006, 07:29
NAVAGATION G P S
I use the Garmin 2610 GPS unit. Place it on the dash by the windshield and it
works good, takes a minute to acquire the signal when first turned on but has not lost the signal when driving. There is a bean bag mount with a tacky bottom so the GPS does not slide across the dash when turning and it holds very well. It plugs into the power outlet and can be easily moved between vehicles. It is fairly easy to use with a little practice and the touch screen makes it easy to navigate thru the menus. It does have settings for the type of vehicle being driven, car, truck or bus. It "avoids" roads with known restrictions when the bus option is selected. It also recalculates the path when a turn is missed, displays the distance and time remaining to destination and recalculates the time remaining as you progress based on current speed. It could use more selections for known gas/food stops but there has always been plenty available. Troy Tikalsky Waconia, Mn 1986 Newell 40' ----- Original Message ----- From: Jack & Donna Smith To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 15, 2006 12:37 PM Subject: [WanderlodgeForum] NAVAGATION G P S I am looking for a GPS Navagation unit. I have one installed in my Laptop that works well, but using the laptop on the Toad is unwieldy. The Magellan 360 looks like a good all-around device. Any use this unit and care to comment? Any comments on ANY unit? Thanks Jack Smith 1973FC31 SoCal [Non-text portions of this message have been removed] |
08-15-2006, 10:47
NAVAGATION G P S
Hi Jack,
I use a Garmin GPS Map 76S. It is a hand-held unit that I can take into the back country, is waterproof, floats, and uses very little power. I have to download maps of metro areas if I want street navigataion, but I can also download very detailed terrain maps if we are hiking or boondocking in the coach and want to take a morning walk in the brush. It probably is not the best street navigation unit, but has the nice option of being portable and used on land or sea. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" > > I am looking for a GPS Navagation unit. I have one installed in my > Laptop that works well, but using the laptop on the Toad is unwieldy. > The Magellan 360 looks like a good all-around device. Any use this > unit and care to comment? > Any comments on ANY unit? > Thanks > Jack Smith > 1973FC31 > SoCal > |
08-15-2006, 12:41
NAVAGATION G P S
I use a combination of a Streetpilot III and a Garmin GPS III on my
motorcycles. The Garmin 2610 is also very popular with riders. All of them are good units for motorhome purposes, with the Streetpilot III having about a $300 value on eBay these days and the 2610 having perhaps a $500 value. The 2610 has a touch screen and more memory. The early Streetpilots were prone to having their displays become unreadable in bright sunlight, hence one reason why I have kept a GPS III as a backup. With the amount of space available in most Wanderlodges I would be tempted to look into something with a large display, such as some of the marine units, but to be honest I am not familiar with things in that range. I will say that Garmin has excellent service (they will rebuilld or replace almost any unit) so that's one major reason to stick with Garmin. Finally, consider where you plan to travel. In the continental US you shouldn't have any problem, but if you go to Mexico make sure that there is a decent map database either installed or available. To my chagrin the routing in my Streetpilot III made the entire unit have spasms and render itself somewhat useless when I was in the vicinity of Monterrey, NL. Go figure. --PirateJohn-- Directeur Sportif, Team Confuzed http://www.PirateJohn.com [Non-text portions of this message have been removed] |
08-15-2006, 13:34
NAVAGATION G P S
Jack,
My wife bought me a Tom Tom and I love it. It even works in the bird. But one flaw, it does not have a big rig setting like some of of the GPS systems. Al Johnson '96 BMC B75 '03 Dodge B100 '93 Dodge B100 '04 VW Passat.. Going to B100 once I get it back from Service '00 Infiniti I30 For Sale --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" > > I am looking for a GPS Navagation unit. I have one installed in my > Laptop that works well, but using the laptop on the Toad is unwieldy. > The Magellan 360 looks like a good all-around device. Any use this > unit and care to comment? > Any comments on ANY unit? > Thanks > Jack Smith > 1973FC31 > SoCal > |
User(s) browsing this thread: 6 Guest(s)
