Xantrex Prosine 2.0 Charge Settings
08-15-2006, 05:51
Hello all,
Just completed the installation of a Xantrex Prosine 2.0 inverter under the guidance and help of Tom Warner in NY. Tom knows his stuff!! Anyhow- the question that I have concerns the settings for 6V flooded cell batteries. Is anyone aware of a web site that gives the Bulk, Absorption and Float rates for the charger settings on the Prosine units? I suppose that the rates would be the same for other chargers too. I am using the flooded 6V golf cart batteries from Sam's club. They are made by Johonson Controls and have 105 Ah of capactity each. The total bank contains 315 Ah (3 pairs in series). I was hoping that someone out there on the site has the same arrangement/batteries and could let me know how they are set up. Tom has the Heart 2500 & Link interface which has a different configuration algorithim than mine. Shane Fedeli 85PT40 Hershey, PA |
08-15-2006, 12:04
Shane,
Try: http://www.xantrex.com/web/id/238/docserve.asp This is the user guide from Xantrex. Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Hello all, > Just completed the installation of a Xantrex Prosine 2.0 inverter > under the guidance and help of Tom Warner in NY. Tom knows his stuff!! > Anyhow- the question that I have concerns the settings for 6V flooded > cell batteries. Is anyone aware of a web site that gives the Bulk, > Absorption and Float rates for the charger settings on the Prosine > units? I suppose that the rates would be the same for other chargers > too. I am using the flooded 6V golf cart batteries from Sam's club. > They are made by Johonson Controls and have 105 Ah of capactity each. > The total bank contains 315 Ah (3 pairs in series). I was hoping that > someone out there on the site has the same arrangement/batteries and > could let me know how they are set up. Tom has the Heart 2500 & Link > interface which has a different configuration algorithim than mine. > > Shane Fedeli > 85PT40 > Hershey, PA > |
08-15-2006, 12:12
Shane,
The Trojan T105 batteries are rated at 225Ah, so once you series and then parallel the pairs, you end up with 675 amp hours. http://www.trojanbattery.com/ProductLite...fCart.aspx then click on the link to Trojan Batteries Work Hard So You Can Play Hard A PDF document will open and you get the specs on the near Bullet proof and time proven T105's. Later Jay Darst 85PT40 also, cept in Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Hello all, > Just completed the installation of a Xantrex Prosine 2.0 inverter > under the guidance and help of Tom Warner in NY. Tom knows his stuff!! > Anyhow- the question that I have concerns the settings for 6V flooded > cell batteries. Is anyone aware of a web site that gives the Bulk, > Absorption and Float rates for the charger settings on the Prosine > units? I suppose that the rates would be the same for other chargers > too. I am using the flooded 6V golf cart batteries from Sam's club. > They are made by Johonson Controls and have 105 Ah of capactity each. > The total bank contains 315 Ah (3 pairs in series). I was hoping that > someone out there on the site has the same arrangement/batteries and > could let me know how they are set up. Tom has the Heart 2500 & Link > interface which has a different configuration algorithim than mine. > > Shane Fedeli > 85PT40 > Hershey, PA > |
08-16-2006, 00:06
Hi Shane,
You need to set your battery type to flooded, the charge characteristics to factory and the size to 675 Ah. If you do not have the battery temp sensor, set the temp(cold,warm,hot) to match your current conditions. If you live where you have extremes, change this when your seasonal temps set in. Craig 91WB40 WPB, FL --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Hello all, > Just completed the installation of a Xantrex Prosine 2.0 inverter > under the guidance and help of Tom Warner in NY. Tom knows his stuff!! > Anyhow- the question that I have concerns the settings for 6V flooded > cell batteries. Is anyone aware of a web site that gives the Bulk, > Absorption and Float rates for the charger settings on the Prosine > units? I suppose that the rates would be the same for other chargers > too. I am using the flooded 6V golf cart batteries from Sam's club. > They are made by Johonson Controls and have 105 Ah of capactity each. > The total bank contains 315 Ah (3 pairs in series). I was hoping that > someone out there on the site has the same arrangement/batteries and > could let me know how they are set up. Tom has the Heart 2500 & Link > interface which has a different configuration algorithim than mine. > > Shane Fedeli > 85PT40 > Hershey, PA > |
08-16-2006, 10:33
Thanks again Jay. Was a little confused on the Ah ratings. My cells
have a "reserve capacity" of 105 mins stamped on them. I take that to mean that after 105 mins, they are at 50% of capacity and pretty useless for starting a Detriot. Guess you needed an extra bank of cells for the kickin' sound system that you put in. -Shane --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > Shane, > > The Trojan T105 batteries are rated at 225Ah, so once you series and > then parallel the pairs, you end up with 675 amp hours. > > > http://www.trojanbattery.com/ProductLite...fCart.aspx > > then click on the link to > Trojan Batteries Work Hard So You Can Play Hard > > A PDF document will open and you get the specs on the near Bullet > proof and time proven T105's. > > > Later > Jay Darst > 85PT40 also, cept in Springfield, IL > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > wrote: > > > > Hello all, > > Just completed the installation of a Xantrex Prosine 2.0 inverter > > under the guidance and help of Tom Warner in NY. Tom knows his > stuff!! > > Anyhow- the question that I have concerns the settings for 6V > flooded > > cell batteries. Is anyone aware of a web site that gives the Bulk, > > Absorption and Float rates for the charger settings on the Prosine > > units? I suppose that the rates would be the same for other > chargers > > too. I am using the flooded 6V golf cart batteries from Sam's club. > > They are made by Johonson Controls and have 105 Ah of capactity > each. > > The total bank contains 315 Ah (3 pairs in series). I was hoping > that > > someone out there on the site has the same arrangement/batteries > and > > could let me know how they are set up. Tom has the Heart 2500 & > Link > > interface which has a different configuration algorithim than mine. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > |
08-16-2006, 10:52
If you want to get a better understanding of wet cell batteries,
take a moment and look at the Trojan website. It is very helpful no matter what kind of batteries you have... http://www.trojanbattery.com/ProductLite...fCart.aspx then click on the link to Trojan Batteries Work Hard So You Can Play Hard A PDF document will open Jay Darst 85PT40 Spfld, IL --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Thanks again Jay. Was a little confused on the Ah ratings. My cells > have a "reserve capacity" of 105 mins stamped on them. I take that > to mean that after 105 mins, they are at 50% of capacity and pretty > useless for starting a Detriot. > > Guess you needed an extra bank of cells for the kickin' sound system > that you put in. > > -Shane > > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > Shane, > > > > The Trojan T105 batteries are rated at 225Ah, so once you series > and > > then parallel the pairs, you end up with 675 amp hours. > > > > > > http://www.trojanbattery.com/ProductLite...fCart.aspx > > > > then click on the link to > > Trojan Batteries Work Hard So You Can Play Hard > > > > A PDF document will open and you get the specs on the near Bullet > > proof and time proven T105's. > > > > > > Later > > Jay Darst > > 85PT40 also, cept in Springfield, IL > > > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > > wrote: > > > > > > Hello all, > > > Just completed the installation of a Xantrex Prosine 2.0 inverter > > > under the guidance and help of Tom Warner in NY. Tom knows his > > stuff!! > > > Anyhow- the question that I have concerns the settings for 6V > > flooded > > > cell batteries. Is anyone aware of a web site that gives the > Bulk, > > > Absorption and Float rates for the charger settings on the > Prosine > > > units? I suppose that the rates would be the same for other > > chargers > > > too. I am using the flooded 6V golf cart batteries from Sam's > club. > > > They are made by Johonson Controls and have 105 Ah of capactity > > each. > > > The total bank contains 315 Ah (3 pairs in series). I was hoping > > that > > > someone out there on the site has the same arrangement/batteries > > and > > > could let me know how they are set up. Tom has the Heart 2500 & > > Link > > > interface which has a different configuration algorithim than > mine. > > > > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > |
