Minor rust under paint
08-16-2006, 04:52
I have a few places where there is rust showing through the paint, like
just below the Wanderlodge emblem on the rear and a couple of other places. The worst is on top of the refrigerator vent cap. I realize once started it is never completely stopped, but I am curious what have others used to treat the affected areas before repainting. Ospho is one product suggested, but is it good under exterior paint? Are there other products that have given good results? My current plan is to clean up the affected areas, treat them, and prime them for protection until I am ready for paint. I live in the North East, so I want to be ready for the winter (outdoor storage with a cover). Thanks, Gardner 78FC33 |
08-16-2006, 05:22
Gardner:
Ospho works well and is designed to be painted. I used Ospho on my propane tank, then painted with engine paint. Looks new. I have also used POR15 extensively. It is great stuff. Leroy Eckert 1990 WB40 Niceville, FL ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 16, 2006 11:52 AM Subject: [WanderlodgeForum] Minor rust under paint I have a few places where there is rust showing through the paint, like just below the Wanderlodge emblem on the rear and a couple of other places. The worst is on top of the refrigerator vent cap. I realize once started it is never completely stopped, but I am curious what have others used to treat the affected areas before repainting. Ospho is one product suggested, but is it good under exterior paint? Are there other products that have given good results? My current plan is to clean up the affected areas, treat them, and prime them for protection until I am ready for paint. I live in the North East, so I want to be ready for the winter (outdoor storage with a cover). Thanks, Gardner 78FC33 [Non-text portions of this message have been removed] |
08-16-2006, 05:27
In my youth I was a manager of a Ziebart rust proofing shop. Took lots
of training on how and why you get rust. Have you tried to poke an awl through the rust? If the metal is perforated then the rust is coming from behind the body panel. To repair this properly the cancerous portions have to be cut out and replaced. Any other method of repair is temporary and a waste of time. If the bubbling is simply rust that is between the paint and the body then you have no real problem. Most rust comes from the inside of the body, especially in an RV. Bruce 1988 FC35 |
08-16-2006, 07:11
Bruce,
I will give it the awl test, but it seems like surface. I can see, however, that since it is below the emblem it probably started in the holes used to mount it, and therefor could be deeper than I had hoped. Ernie, Yup, we talked about the tank already, I was interested in differences between that and the galvanized metal. Thanks Gardner FC7833 --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > In my youth I was a manager of a Ziebart rust proofing shop. Took lots > of training on how and why you get rust. Have you tried to poke an awl > through the rust? If the metal is perforated then the rust is coming > from behind the body panel. To repair this properly the cancerous > portions have to be cut out and replaced. Any other method of repair > is temporary and a waste of time. If the bubbling is simply rust that > is between the paint and the body then you have no real problem. Most > rust comes from the inside of the body, especially in an RV. > > Bruce 1988 FC35 > |
08-16-2006, 12:23
Gardner:
I'm passing along the name of a product that will cut your cosmetic maintenance time dramatically. I have been using it for 15 years on any metal that needs polishing. It isn't cheap, you get what you pay for. It is the best I have found. It is Semichrome--available over the internet at http://www.mall4antiques.com About $70.00 for 1000 grams. Imported from Germany, the can should last about 5 years if you only use it on the bus.(Wheels , bumpers, mirrors, etc.) Beware! When you first open the can it will knock you down with a heavy ammonia smell. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 16, 2006 12:22 PM Subject: Re: [WanderlodgeForum] Minor rust under paint Gardner: Ospho works well and is designed to be painted. I used Ospho on my propane tank, then painted with engine paint. Looks new. I have also used POR15 extensively. It is great stuff. Leroy Eckert 1990 WB40 Niceville, FL ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 16, 2006 11:52 AM Subject: [WanderlodgeForum] Minor rust under paint I have a few places where there is rust showing through the paint, like just below the Wanderlodge emblem on the rear and a couple of other places. The worst is on top of the refrigerator vent cap. I realize once started it is never completely stopped, but I am curious what have others used to treat the affected areas before repainting. Ospho is one product suggested, but is it good under exterior paint? Are there other products that have given good results? My current plan is to clean up the affected areas, treat them, and prime them for protection until I am ready for paint. I live in the North East, so I want to be ready for the winter (outdoor storage with a cover). Thanks, Gardner 78FC33 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-16-2006, 12:53
Leroy,
I think we used to use something called simichrome magic wadding polish, which came in a can and was basically a fibrous material soaked in something. You would take a little wad and polish things up. It worked great, but was a bit cheaper. (But that was 40 years ago). It also seemed to tarnish up faster, but again, that was also a long time ago. Gardner 78FC35 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Leroy Eckert Sent: Wednesday, August 16, 2006 8:24 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Minor rust under paint Gardner: I'm passing along the name of a product that will cut your cosmetic maintenance time dramatically. I have been using it for 15 years on any metal that needs polishing. It isn't cheap, you get what you pay for. It is the best I have found. It is Semichrome--available over the internet at http://www.mall4antiques.com About $70.00 for 1000 grams. Imported from Germany, the can should last about 5 years if you only use it on the bus.(Wheels , bumpers, mirrors, etc.) Beware! When you first open the can it will knock you down with a heavy ammonia smell. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 16, 2006 12:22 PM Subject: Re: [WanderlodgeForum] Minor rust under paint Gardner: Ospho works well and is designed to be painted. I used Ospho on my propane tank, then painted with engine paint. Looks new. I have also used POR15 extensively. It is great stuff. Leroy Eckert 1990 WB40 Niceville, FL ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 16, 2006 11:52 AM Subject: [WanderlodgeForum] Minor rust under paint I have a few places where there is rust showing through the paint, like just below the Wanderlodge emblem on the rear and a couple of other places. The worst is on top of the refrigerator vent cap. I realize once started it is never completely stopped, but I am curious what have others used to treat the affected areas before repainting. Ospho is one product suggested, but is it good under exterior paint? Are there other products that have given good results? My current plan is to clean up the affected areas, treat them, and prime them for protection until I am ready for paint. I live in the North East, so I want to be ready for the winter (outdoor storage with a cover). Thanks, Gardner 78FC33 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-16-2006, 13:17
Gardner:
No wadding in the can. It is somekinda pink semi-paste. It's great. Will turn your hands black. Yuk, but the wheels are beautiful. I think everything was cheaper 40 years ago, but you didn't have some of the trick stuff we have today. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 16, 2006 7:53 PM Subject: RE: [WanderlodgeForum] Minor rust under paint Leroy, I think we used to use something called simichrome magic wadding polish, which came in a can and was basically a fibrous material soaked in something. You would take a little wad and polish things up. It worked great, but was a bit cheaper. (But that was 40 years ago). It also seemed to tarnish up faster, but again, that was also a long time ago. Gardner 78FC35 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Leroy Eckert Sent: Wednesday, August 16, 2006 8:24 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Minor rust under paint Gardner: I'm passing along the name of a product that will cut your cosmetic maintenance time dramatically. I have been using it for 15 years on any metal that needs polishing. It isn't cheap, you get what you pay for. It is the best I have found. It is Semichrome--available over the internet at http://www.mall4antiques.com About $70.00 for 1000 grams. Imported from Germany, the can should last about 5 years if you only use it on the bus.(Wheels , bumpers, mirrors, etc.) Beware! When you first open the can it will knock you down with a heavy ammonia smell. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 16, 2006 12:22 PM Subject: Re: [WanderlodgeForum] Minor rust under paint Gardner: Ospho works well and is designed to be painted. I used Ospho on my propane tank, then painted with engine paint. Looks new. I have also used POR15 extensively. It is great stuff. Leroy Eckert 1990 WB40 Niceville, FL ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 16, 2006 11:52 AM Subject: [WanderlodgeForum] Minor rust under paint I have a few places where there is rust showing through the paint, like just below the Wanderlodge emblem on the rear and a couple of other places. The worst is on top of the refrigerator vent cap. I realize once started it is never completely stopped, but I am curious what have others used to treat the affected areas before repainting. Ospho is one product suggested, but is it good under exterior paint? Are there other products that have given good results? My current plan is to clean up the affected areas, treat them, and prime them for protection until I am ready for paint. I live in the North East, so I want to be ready for the winter (outdoor storage with a cover). Thanks, Gardner 78FC33 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
