selling and 15K
08-16-2006, 14:49
selling and 15K
For various reasons we have decided to sell our Bluebird but before
we did that we wanted to take a trip with our Grandaughter to Colorado for a month........To make a long story shorter I will try my best to not ramble.... First of all NEVER take your eye off your temp. gauge when in the mountains,,if you need to, put a small sticky on the windshield that says TEMP... on it .... needless to say because of 3 factors I overheated my 8v92 to the tune of replacing everthing but the turbo, block and crank and 2 1/2 weeks without the coach while in Denver being repaired by Stewert and stevenson (very good reputable firm) Back to the 3 factors 1. I was over the pass and not as diligent at watching the temp. 12 miles later I was on the side of the road 2. my DEDC temp. senser was defective and off by 20 degress which means the check engine light came on 20 degress higher then intended.. 3. someone in my coaches past got a hair brained idea or heard of a way to better balance the cooling flow ( I hear this was not so uncommin in the 90s) and installed a 2 1/4 in. washer with a 1/4 in. hole in the middle, and installed it in the wrong location if in fact you were to do something as stupid as that........ So Boys and Girls LEARN from my mistake,, Even if you have as I did those other 2 factors that created my overheating... IF I HAD BEEN WATCHING THE TEMP AND SHUT IT DOWN IN TIME >> I WOULD STILL HAVE MY 15 K.... I,m still selling the coach ( 92 WLWB 40ft.) someones going to get a hell of a coach with 102 k mile with basically a new motor... Any Ideas as to the best place to sell it...I would like to see it go to someone that will enjoy it as much as we have...Let me know....DAN. P.S. there might have been a 4th factor ,, broken hose clamp which broke on the way up the grade or after it overhheated ????? |
08-16-2006, 20:22
selling and 15K
Dan, contact Kathy Lawrence on Vintage Birds. She can include that ad on the
billboard. We can also do a classified ad on the forum in the Database. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
08-17-2006, 05:08
selling and 15K
Dan:
I'm sorry about your very expensive engine failure. Could you elaborate a little more on what happened? It doesn't seem as though an extra 20 degrees in engine temperature would cause that catastrophic a failure. Did the engine seize or not run at all after overheating? What was the purpose of the washer? Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Dan Saari" wrote: > > > For various reasons we have decided to sell our Bluebird but before > we did that we wanted to take a trip with our Grandaughter to > Colorado for a month........To make a long story shorter I will try > my best to not ramble.... First of all NEVER take your eye off your > temp. gauge when in the mountains,,if you need to, put a small sticky > on the windshield that says TEMP... on it .... needless to say > because of 3 factors I overheated my 8v92 to the tune of replacing > everthing but the turbo, block and crank and 2 1/2 weeks without the > coach while in Denver being repaired by Stewert and stevenson (very > good reputable firm) > Back to the 3 factors 1. I was over the pass and not as diligent at > watching the temp. 12 miles later I was on the side of the road 2. my > DEDC temp. senser was defective and off by 20 degress which means the > check engine light came on 20 degress higher then intended.. 3. > someone in my coaches past got a hair brained idea or heard of a way > to better balance the cooling flow ( I hear this was not so uncommin > in the 90s) and installed a 2 1/4 in. washer with a 1/4 in. hole in > the middle, and installed it in the wrong location if in fact you > were to do something as stupid as that........ > > So Boys and Girls LEARN from my mistake,, Even if you have as I did > those other 2 factors that created my overheating... IF I HAD BEEN > WATCHING THE TEMP AND SHUT IT DOWN IN TIME >> I WOULD STILL HAVE MY > 15 K.... > > I,m still selling the coach ( 92 WLWB 40ft.) someones going to get a > hell of a coach with 102 k mile with basically a new motor... > > Any Ideas as to the best place to sell it...I would like to see it go > to someone that will enjoy it as much as we have...Let me > know....DAN. > > P.S. there might have been a 4th factor ,, broken hose clamp which > broke on the way up the grade or after it overhheated ????? > |
08-17-2006, 15:08
selling and 15K
> > Dan: > I'm sorry about your very expensive engine failure. Could you > elaborate a little more on what happened? It doesn't seem as though > an extra 20 degrees in engine temperature would cause that > catastrophic a failure. Did the engine seize or not run at all > after overheating? What was the purpose of the washer? > > Kerry > 82 Fc 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "Dan Saari" > wrote: > > > > > > > Kerry..... 20 degrees does'nt seem like a lot but if the light had flashed at the preset of 205 degrees you are not yet at a boiling point and can shut it down, but if the senser did'nt warn me untill 225 at this point you are beyond boiling and pushing water out of your system for possible 3-5 miles and the more you loose the faster the temp is rising and an eminent failure can happen REAL fast cause your 40 feet from the situation and its behind you so you do'nt even smell the antifreese... As for the washer type thing...... I got an email today telling me Bluebird installed them....... I,m looking into this because I would like to know why they installed them.. I will tell you this, I did notice a temp. fluxuation on my way back from Colorado without the washer...I will describe this fluxuation and it only happened in the evening when the outside temp. was cooler.....the temp gauge would read 180 and over a span of about 3-4 miles would gradually increase to about 195,, in a matter of 1 mile it would return to 180 and the cycle would repeat over and over.....In thinking about this and wondering about why this would happen at night in cooler weather and not during the day the common sense of the hole situation (to me at least) is this...During the day when the outside temp is warmer the temp. controlled fan runs all the time,consiquently keeping the temp at the 180 thermostat set.. but in the evening when the outside temp. lowers, the fan will automatically shut down and the temp will gradually rise to 195 where the fan is designed to kick in and cool back to 180,,,,, wallau.. the rise and fall of the temp. fluxuation.. Now if in fact the washer was installed to illiminate this fluxuation I don't know... I only know this, the guy that overhauled the motor said that whoever put that washer in there may have had a purpose in mind, but restricting the flow of cool water to the drivers side head ( is what it does in that location) is crazy.. I can also tell you that the drivers side exhaust manifold was cracked and needed to be replaced.. if this was because that side ran hotter because of the washer,,I don'nt know...... whether that washer should have been installed by Bluebird or not ,,again I don't know... hopefully we have some 8v92 gorroozzs out there to jump in on this......LET THE DEBATE BEGIN..... DAN 92 WLWB 40ft. Depere/ Summerfield..... for sale |
08-17-2006, 15:51
selling and 15K
wrote: > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > Dan: > > I'm sorry about your very expensive engine failure. Could you > > elaborate a little more on what happened? It doesn't seem as > though > > an extra 20 degrees in engine temperature would cause that > > catastrophic a failure. Did the engine seize or not run at all > > after overheating? What was the purpose of the washer? > > > > Kerry > > 82 Fc 35 > > Denver > > > > --- In WanderlodgeForum@yahoogroups.com, "Dan Saari" > > wrote: > > > > > > > > > > > > Kerry..... 20 degrees does'nt seem like a lot but if the light had > flashed at the preset of 205 degrees you are not yet at a boiling > point and can shut it down, but if the senser did'nt warn me untill > 225 at this point you are beyond boiling and pushing water out of > your system for possible 3-5 miles and the more you loose the faster > the temp is rising and an eminent failure can happen REAL fast cause > your 40 feet from the situation and its behind you so you do'nt even > smell the antifreese... > > As for the washer type thing...... I got an email today telling me > Bluebird installed them....... I,m looking into this because I would > like to know why they installed them.. I will tell you this, I did > notice a temp. fluxuation on my way back from Colorado without the > washer...I will describe this fluxuation and it only happened in the > evening when the outside temp. was cooler.....the temp gauge would > read 180 and over a span of about 3-4 miles would gradually increase > to about 195,, in a matter of 1 mile it would return to 180 and the > cycle would repeat over and over.....In thinking about this and > wondering about why this would happen at night in cooler weather and > not during the day the common sense of the hole situation (to me at > least) is this...During the day when the outside temp is warmer the > temp. controlled fan runs all the time,consiquently keeping the temp > at the 180 thermostat set.. but in the evening when the outside temp. > lowers, the fan will automatically shut down and the temp will > gradually rise to 195 where the fan is designed to kick in and cool > back to 180,,,,, wallau.. the rise and fall of the temp. fluxuation.. > > Now if in fact the washer was installed to illiminate this > fluxuation I don't know... I only know this, the guy that overhauled > the motor said that whoever put that washer in there may have had a > purpose in mind, but restricting the flow of cool water to the > drivers side head ( is what it does in that location) is crazy.. > > I can also tell you that the drivers side exhaust manifold was > cracked and needed to be replaced.. if this was because that side ran > hotter because of the washer,,I don'nt know...... > > whether that washer should have been installed by Bluebird or > not ,,again I don't know... hopefully we have some 8v92 gorroozzs out > there to jump in on this......LET THE DEBATE BEGIN..... DAN > > 92 WLWB 40ft. > Depere/ Summerfield..... for sale > Kerry....... another part of your question I forgot to answer was about it shutting down.... Within 30 seconds of me spotting the red check engine light I looked at the gauges and saw the temp gauge all the way to the max 260 degrees and before I could reach for the key and pull off in a turn lane to the right ,, it shut itself off or just quit running and it was at this point I looked in the rear veiw mirror and saw it steaming,,,, Keep in mind now 12 miles earlier I had walked around the entire coach and everthing was fine,,, I even stood between the back of the coach and my tow vehicle and took a piss so I know there was no smell of antifreeze..... As I,ve said earlier...things can go to shit in a hurry when going up the mountains and they can happen FAST... your best defense is watch the gauges ,,, hwy,gauges,hwy,gauges,hwy gauges........ DAN |
08-17-2006, 17:08
selling and 15K
Dan:
Sorry to hear about your overheat problem. My temp gauge constantly cycles back and forth between 180 and 200 particularly in cooler temperatures. Generally, on very hot days where ambient temps are above 90, road surface temp most likely approaching 120, I will see what I call temperature creep. It will creep up to 200 an stay there if I am pushing it. ( the pyro at approx. 650 and boost of approx 12) If I stay at 70MPH or slightly less the temp will generally stay around 190. (the pyro at 550 and boost of about 7) I can reduce the temperature to the 180 thermostat setting at any time even if I'm pushing it by switching to fan override. It will hold it there. Switch the fan override off and the sequence begins again. Initially I was concerned but after reading the BB manual I found the fan runs between 400-800RPM normally and approx 1800RPM in override. I have concluded my coach likes to be driven about 67mph. The extra 8-10mph just burns up fuel and is hard on the equipment. I'm certainly not a gooroo, just reporting how my 8v92 runs. Leroy Eckert 1990 WB40 Niceville. FL ----- Original Message ----- From: Dan Saari To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 17, 2006 10:51 PM Subject: [WanderlodgeForum] Re: selling and 15K --- In WanderlodgeForum@yahoogroups.com, "Dan Saari" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > Dan: > > I'm sorry about your very expensive engine failure. Could you > > elaborate a little more on what happened? It doesn't seem as > though > > an extra 20 degrees in engine temperature would cause that > > catastrophic a failure. Did the engine seize or not run at all > > after overheating? What was the purpose of the washer? > > > > Kerry > > 82 Fc 35 > > Denver > > > > --- In WanderlodgeForum@yahoogroups.com, "Dan Saari" > > wrote: > > > > > > > > > > > > Kerry..... 20 degrees does'nt seem like a lot but if the light had > flashed at the preset of 205 degrees you are not yet at a boiling > point and can shut it down, but if the senser did'nt warn me untill > 225 at this point you are beyond boiling and pushing water out of > your system for possible 3-5 miles and the more you loose the faster > the temp is rising and an eminent failure can happen REAL fast cause > your 40 feet from the situation and its behind you so you do'nt even > smell the antifreese... > > As for the washer type thing...... I got an email today telling me > Bluebird installed them....... I,m looking into this because I would > like to know why they installed them.. I will tell you this, I did > notice a temp. fluxuation on my way back from Colorado without the > washer...I will describe this fluxuation and it only happened in the > evening when the outside temp. was cooler.....the temp gauge would > read 180 and over a span of about 3-4 miles would gradually increase > to about 195,, in a matter of 1 mile it would return to 180 and the > cycle would repeat over and over.....In thinking about this and > wondering about why this would happen at night in cooler weather and > not during the day the common sense of the hole situation (to me at > least) is this...During the day when the outside temp is warmer the > temp. controlled fan runs all the time,consiquently keeping the temp > at the 180 thermostat set.. but in the evening when the outside temp. > lowers, the fan will automatically shut down and the temp will > gradually rise to 195 where the fan is designed to kick in and cool > back to 180,,,,, wallau.. the rise and fall of the temp. fluxuation.. > > Now if in fact the washer was installed to illiminate this > fluxuation I don't know... I only know this, the guy that overhauled > the motor said that whoever put that washer in there may have had a > purpose in mind, but restricting the flow of cool water to the > drivers side head ( is what it does in that location) is crazy.. > > I can also tell you that the drivers side exhaust manifold was > cracked and needed to be replaced.. if this was because that side ran > hotter because of the washer,,I don'nt know...... > > whether that washer should have been installed by Bluebird or > not ,,again I don't know... hopefully we have some 8v92 gorroozzs out > there to jump in on this......LET THE DEBATE BEGIN..... DAN > > 92 WLWB 40ft. > Depere/ Summerfield..... for sale > Kerry....... another part of your question I forgot to answer was about it shutting down.... Within 30 seconds of me spotting the red check engine light I looked at the gauges and saw the temp gauge all the way to the max 260 degrees and before I could reach for the key and pull off in a turn lane to the right ,, it shut itself off or just quit running and it was at this point I looked in the rear veiw mirror and saw it steaming,,,, Keep in mind now 12 miles earlier I had walked around the entire coach and everthing was fine,,, I even stood between the back of the coach and my tow vehicle and took a piss so I know there was no smell of antifreeze..... As I,ve said earlier...things can go to shit in a hurry when going up the mountains and they can happen FAST... your best defense is watch the gauges ,,, hwy,gauges,hwy,gauges,hwy gauges........ DAN [Non-text portions of this message have been removed] |
User(s) browsing this thread: 8 Guest(s)
