sporlan valve
08-16-2006, 20:51
sporlan valve
Dan, back off those bolts on the valve. Perhaps there is some crud on the
diaphram.You'll get some water in that compartment- so don't back off the bolts too far. Most of the time the crud will leak out. It did on mine. There is a rebuild kit for it and maybe Stephen Birtles has the kits. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
08-17-2006, 00:30
sporlan valve
On my return from Colorado this week I had a problem with my water
system... lifted the bed to get at the sporlan valve to tap it and was not able to get it to work correctly.... My question is where can I get a new one as I called Blue Bird parts and the tech Dept. and neither has called me back.... I believe it;s the sporlan valve as it has been giving me problems and now it won't move at all... I think its stuck half open and half closed cause on city water it continues to fill the tank with vary little pressure in the coach ... when I try the coach pump ( it is working ) there is no pressure cause with the valve half open it just bypasses the valve.... I have flicked the valve switch on and off and it will not work.......So where can I get one ??? little help here please DAN 92 WLWB 40ft. Depere Wi./ Summerfield Fl. 920-915-3777 it's for sale w/ rebuilt motor |
08-17-2006, 00:49
sporlan valve
Stephen Britles has the repair kits.
http://www.capeinnovation.com/ Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Dan Saari" wrote: > > > On my return from Colorado this week I had a problem with my water > system... lifted the bed to get at the sporlan valve to tap it and was > not able to get it to work correctly.... My question is where can I get > a new one as I called Blue Bird parts and the tech Dept. and neither > has called me back.... I believe it;s the sporlan valve as it has been > giving me problems and now it won't move at all... I think its stuck > half open and half closed cause on city water it continues to fill the > tank with vary little pressure in the coach ... when I try the coach > pump ( it is working ) there is no pressure cause with the valve half > open it just bypasses the valve.... I have flicked the valve switch on > and off and it will not work.......So where can I get one ??? little > help here please DAN > > 92 WLWB 40ft. > Depere Wi./ Summerfield Fl. > 920-915-3777 it's for sale w/ rebuilt motor > |
08-17-2006, 01:18
sporlan valve
Dont replace the valve! You can get a kit from Sporlan consisting of
the diaphram springs etc to rebuild it. I got mine locally from the Jordan Co. Syracuse,NY Tom Warner Vernon center,NY 1985 PT 40 At 08:30 AM 8/17/2006, you wrote: > On my return from Colorado this week I had a problem with my water >system... lifted the bed to get at the sporlan valve to tap it and was >not able to get it to work correctly.... My question is where can I get >a new one as I called Blue Bird parts and the tech Dept. and neither >has called me back.... I believe it;s the sporlan valve as it has been >giving me problems and now it won't move at all... I think its stuck >half open and half closed cause on city water it continues to fill the >tank with vary little pressure in the coach ... when I try the coach >pump ( it is working ) there is no pressure cause with the valve half >open it just bypasses the valve.... I have flicked the valve switch on >and off and it will not work.......So where can I get one ??? little >help here please DAN > >92 WLWB 40ft. >Depere Wi./ Summerfield Fl. >920-915-3777 it's for sale w/ rebuilt motor > > > > > > > >Yahoo! Groups Links > > > > |
08-17-2006, 01:42
sporlan valve
I believe Stephen Birtles has these valves or at least the rebuild kits. If
he doesn't reply to your original email request you can contact him at cape0001 AT Gmail DOT com On 17/08/06, Dan Saari > > > On my return from Colorado this week I had a problem with my water > system... lifted the bed to get at the sporlan valve to tap it and was > not able to get it to work correctly.... My question is where can I get > a new one as I called Blue Bird parts and the tech Dept. and neither > has called me back.... I believe it;s the sporlan valve as it has been > giving me problems and now it won't move at all... I think its stuck > half open and half closed cause on city water it continues to fill the > tank with vary little pressure in the coach ... when I try the coach > pump ( it is working ) there is no pressure cause with the valve half > open it just bypasses the valve.... I have flicked the valve switch on > and off and it will not work.......So where can I get one ??? little > help here please DAN > > 92 WLWB 40ft. > Depere Wi./ Summerfield Fl. > 920-915-3777 it's for sale w/ rebuilt motor > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
08-17-2006, 02:13
sporlan valve
If you can't get a response from BB, bry Parliament Coach near
Clearwater (a BB dealer). The valve is also used in many commercial plumbing applications in case that helps. If your tank water level is below the valve (empty?), you can take the valve apart to see if there is simply a piece of debris keeping it open (fairly common). The valve is O-ring sealed, will likely seal again until a rebuild kit arrives. Also try switching the fill valve on and off a few times with water flowing, it might clear the debris. - Jeff Miller in Holland, MI always carrying a Sprorlan rebuild kit --- In WanderlodgeForum@yahoogroups.com, "Dan Saari" wrote: > > > On my return from Colorado this week I had a problem with my water > system... lifted the bed to get at the sporlan valve to tap it and was > not able to get it to work correctly.... My question is where can I get > a new one as I called Blue Bird parts and the tech Dept. and neither > has called me back.... I believe it;s the sporlan valve as it has been > giving me problems and now it won't move at all... I think its stuck > half open and half closed cause on city water it continues to fill the > tank with vary little pressure in the coach ... when I try the coach > pump ( it is working ) there is no pressure cause with the valve half > open it just bypasses the valve.... I have flicked the valve switch on > and off and it will not work.......So where can I get one ??? little > help here please DAN > > 92 WLWB 40ft. > Depere Wi./ Summerfield Fl. > 920-915-3777 it's for sale w/ rebuilt motor > |
08-17-2006, 02:28
sporlan valve
Dan,
Sometimes you can take them apart and clean them out.. If not- Stephen Birtles has the rebuild kits. Stephen 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Dan Saari Sent: Thursday, August 17, 2006 8:30 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] sporlan valve On my return from Colorado this week I had a problem with my water system... lifted the bed to get at the sporlan valve to tap it and was not able to get it to work correctly.... My question is where can I get a new one as I called Blue Bird parts and the tech Dept. and neither has called me back.... I believe it;s the sporlan valve as it has been giving me problems and now it won't move at all... I think its stuck half open and half closed cause on city water it continues to fill the tank with vary little pressure in the coach ... when I try the coach pump ( it is working ) there is no pressure cause with the valve half open it just bypasses the valve.... I have flicked the valve switch on and off and it will not work.......So where can I get one ??? little help here please DAN 92 WLWB 40ft. Depere Wi./ Summerfield Fl. 920-915-3777 it's for sale w/ rebuilt motor [Non-text portions of this message have been removed] |
08-17-2006, 02:29
sporlan valve
They're pretty easy to take apart. You could take it apart and clean
it up to see if it stops sticky. Someone on this forum sells a rebuild kit for them--I think if you search on sporlan valve, they're name should come up. Sorry to hear about your engine problem. Kerry -- In WanderlodgeForum@yahoogroups.com, "Dan Saari" > > > On my return from Colorado this week I had a problem with my water > system... lifted the bed to get at the sporlan valve to tap it and was > not able to get it to work correctly.... My question is where can I get > a new one as I called Blue Bird parts and the tech Dept. and neither > has called me back.... I believe it;s the sporlan valve as it has been > giving me problems and now it won't move at all... I think its stuck > half open and half closed cause on city water it continues to fill the > tank with vary little pressure in the coach ... when I try the coach > pump ( it is working ) there is no pressure cause with the valve half > open it just bypasses the valve.... I have flicked the valve switch on > and off and it will not work.......So where can I get one ??? little > help here please DAN > > 92 WLWB 40ft. > Depere Wi./ Summerfield Fl. > 920-915-3777 it's for sale w/ rebuilt motor > |
08-17-2006, 03:48
sporlan valve
The S valve needs pressure to close and with the system is not used
or pressurized it floats open. The works get scummed up and they need a cleaning. For a quick fix I hook up to high pressure city, run the outside hand wash sink and try and close the e-fill switch off. ( others will warn you that this may cause pipe dammage and my sporlan is a little clogged up) . To check if the e switch and selonoid are working, turn it on, go under the bed, unscrew the e selonoid and pick it up and down, you should feel the magnetic pull. If all that is working simply remove the other four (4?) screws open the valve and clean the guts with bathroom cleaner. If you replace the valve replumb it to hold a ball man valve also. ( the man valve is good to use on the road if the sporlan or when the sporlan gets scummed once again) Gregory O'Connor 94ptRomolandCa . --- In WanderlodgeForum@yahoogroups.com, "Dan Saari" > > > On my return from Colorado this week I had a problem with my water > system... lifted the bed to get at the sporlan valve to tap it and was > not able to get it to work correctly.... My question is where can I get > a new one as I called Blue Bird parts and the tech Dept. and neither > has called me back.... I believe it;s the sporlan valve as it has been > giving me problems and now it won't move at all... I think its stuck > half open and half closed cause on city water it continues to fill the > tank with vary little pressure in the coach ... when I try the coach > pump ( it is working ) there is no pressure cause with the valve half > open it just bypasses the valve.... I have flicked the valve switch on > and off and it will not work.......So where can I get one ??? little > help here please DAN > > 92 WLWB 40ft. > Depere Wi./ Summerfield Fl. > 920-915-3777 it's for sale w/ rebuilt motor > |
08-17-2006, 04:22
sporlan valve
Dan,
I bought a rebuild kit and a spare valve this spring. I went to: http://www.sporlan.com/main.shtm, click on "Authorized Wholesalers", enter your State, and a list of places to buy one will appear. - Rick 87FC35 Rochester, MN --- In WanderlodgeForum@yahoogroups.com, "Dan Saari" > > > On my return from Colorado this week I had a problem with my water > system... lifted the bed to get at the sporlan valve to tap it and was > not able to get it to work correctly.... My question is where can I get > a new one as I called Blue Bird parts and the tech Dept. and neither > has called me back.... I believe it;s the sporlan valve as it has been > giving me problems and now it won't move at all... I think its stuck > half open and half closed cause on city water it continues to fill the > tank with vary little pressure in the coach ... when I try the coach > pump ( it is working ) there is no pressure cause with the valve half > open it just bypasses the valve.... I have flicked the valve switch on > and off and it will not work.......So where can I get one ??? little > help here please DAN > > 92 WLWB 40ft. > Depere Wi./ Summerfield Fl. > 920-915-3777 it's for sale w/ rebuilt motor > |
