No horn
08-15-2006, 02:55
No horn
I just brought my new 78FC home and the main horn does not work. (not
the air or musical horns which I knew didn't work). I haven't looked
yet, but does anyone know where the wire from the horn button on the
steering wheel exits the stering column? The horn only beeped once
while we were doing the final run through, so I assume there is a poor
connection or the button has failed.
Gardner 78FC33
08-15-2006, 03:35
No horn
Check the air/electric horn toggle switch on the dash, maybe it's in
the "air" position?
Bob Janes, Greenville, SC
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
poor
> Gardner 78FC33
08-15-2006, 04:03
No horn
Gardner,
On the '78 FC I had, I occasionally had to remove the horn button and
push it back in. There was not a very good ground connection between
the button and the steering wheel hub.
David Hollis 84 FC35(with Jeff Miller and Ernie on its pedigree)
Springfield,IL
(not
poor
> Gardner 78FC33
08-15-2006, 05:40
No horn
Bob,
I flipped the switch between the trhee settings several times. I
plan to follow the circuit and test continuity along the way. For now
I only need the electric horn for state safety inspection so I may
wire it around the switch if that is the problem.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot"
in
> the "air" position?
(not
looked
once
> poor
> > Gardner 78FC33
08-15-2006, 05:43
No horn
David,
I will check that as well. I suppose the horn button just 'pops'
out with a little encouragement from a thin blade?
I will be at the storage facility tonight and will see what I can
do.
Thanks
Gardner
78FC33
> Gardner,
between
> Springfield,IL
> (not
looked
once
> poor
> > Gardner 78FC33
08-15-2006, 07:34
No horn
In a message dated 8/15/2006 11:14:52 AM Central Daylight Time,
dthollis@... writes:
> Springfield,IL
David, I saw the pictures of our old coach at Clarks Rv sales. She still
looks great!!
83 PT40
Livingston, Montana
08-16-2006, 04:28
No horn
The horn works now, operator error. Ignition needed to be ON!
Gardner
78FC33
> > Springfield,IL
still
> looks great!!
> Ernie Ekberg
> 83 PT40
> Livingston, Montana
08-19-2006, 13:37
No horn
Well, it wasn't operator error after all. The horn works
intermittently. I have a second Bluebird horn button, but that is
not the problem. I checked with an ohm meter and the button works
fine. There is an intermittent connection between (I believe) the
horn button and the dash switch. I noticed when the horn worked the
air horn relay or solenoid clicked when the switch was in that
position, and when the horn fails and I flip the switch, the air
horn relay doesn't work either.
Where does the horn wire exit the stering column? Does the
circuit have a slip ring or other method of transfering the
connection from the rotating steering column?
Gardner
78FC33 (no beep)
> Gardner
> 78FC33
> > dthollis@ writes:
pedigree)
> > > Springfield,IL
She
> still
> > looks great!!
> > Ernie Ekberg
> > 83 PT40
> > Livingston, Montana
