Fwd: Where are my circuit breakers? 87FC35
08-20-2006, 21:41
Alan Those lower side ones are on my turn signal. They only come on when
I have the 4 way flashers or turn signal on. Don 89 SP 36' Butler, PA In a message dated 8/21/2006 9:22:46 A.M. Eastern Daylight Time, nodalwakeboarder@... writes: Well, I'm still learning where everything is on my new Bird. This is my latest problem (that I need to get fixed so I can get Texas tags). My side running lights are inop. (Not the ones at the top of the coach, the lower ones) There are two on each side. I think I found the problem. It was a short on one of the lights. I corrected the problem, but they still won't come on. So, here are my questions. 1. Figure 10-2 in my manual (Lower Front Load Center) says that circuit breaker #10, wire #1 is for my "Parking and tail lights". My front and rear tail lights ARE working, but if those side lights aren't that, then I don't know what they are called. Any thoughts? 2. And even if that was the circuit breaker, I can't find it. I've taken my grill off and taken off both access panels behind the grill. On the drivers side I see only maybe two of the small (maybe 1" square) black boxes that I understand are the circuit breakers. My manual shows there to be 25 of them in the lower front load center. ...So I must not be looking in the right place..?? Thanks!! Alan Johnson New 87FC35 owner [Non-text portions of this message have been removed] |
