Fwd: Where are my circuit breakers? 87FC35
08-20-2006, 21:41
Alan Those lower side ones are on my turn signal. They only come on when
I have the 4 way flashers or turn signal on.
Don
89 SP 36'
Butler, PA
In a message dated 8/21/2006 9:22:46 A.M. Eastern Daylight Time,
nodalwakeboarder@... writes:
Well, I'm still learning where everything is on my new Bird. This
is my latest problem (that I need to get fixed so I can get Texas
tags).
My side running lights are inop. (Not the ones at the top of the
coach, the lower ones) There are two on each side. I think I found
the problem. It was a short on one of the lights. I corrected the
problem, but they still won't come on. So, here are my questions.
1. Figure 10-2 in my manual (Lower Front Load Center) says that
circuit breaker #10, wire #1 is for my "Parking and tail lights".
My front and rear tail lights ARE working, but if those side lights
aren't that, then I don't know what they are called. Any thoughts?
2. And even if that was the circuit breaker, I can't find it. I've
taken my grill off and taken off both access panels behind the
grill. On the drivers side I see only maybe two of the small (maybe
1" square) black boxes that I understand are the circuit breakers.
My manual shows there to be 25 of them in the lower front load
center. ...So I must not be looking in the right place..??
Thanks!!
Alan Johnson
New 87FC35 owner
Loading...
