E-Bay Wanderlodge
08-21-2006, 15:02
E-Bay Wanderlodge
Came across this Wanderlodge on E-Bay..
Item number 120023609811 looks to have rolled over.... |
08-21-2006, 16:10
E-Bay Wanderlodge
A little more than the 'slide on it's side' in the description. It
also does not look like a 40 footer. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Chris" > > Came across this Wanderlodge on E-Bay.. > > Item number 120023609811 > > looks to have rolled over.... > |
08-21-2006, 17:10
E-Bay Wanderlodge
Chris, DavidB did that while showing JeffM frame effects of negitive
G's. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Chris" wrote: > > Came across this Wanderlodge on E-Bay.. > > Item number 120023609811 > > looks to have rolled over.... > |
08-22-2006, 00:09
E-Bay Wanderlodge
From the description:
"and the prize above all motor homes is the revolutionary method of incinerating sewer waste & converting one weeks waste into a small cup of ash dust that can be safety deposited in any garbage can." Have I missed something? Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "Chris" wrote: > > Came across this Wanderlodge on E-Bay.. > > Item number 120023609811 > > looks to have rolled over.... > |
08-22-2006, 00:16
E-Bay Wanderlodge
that s not neagive Gs its lateral G's come on get it right
Have a great Day Stephen 77fc35 whatever g's you measure --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Chris, DavidB did that while showing JeffM frame effects of negitive > G's. > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Chris" > wrote: > > > > Came across this Wanderlodge on E-Bay.. > > > > Item number 120023609811 > > > > looks to have rolled over.... > > > |
08-22-2006, 00:20
E-Bay Wanderlodge
its called an incinolet one of the worst ever waste disposal systems
installed in any mobile application we had them on Railway Engines and one of the neat things about it was to start it after it was partially full and then leave the cab of the engine. the resultant stench would just about kill the poor engineer Stephen 77fc35 never ever push the button while moving --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > From the description: > > "and the prize above all motor homes is the revolutionary method of > incinerating sewer waste & converting one weeks waste into a small > cup of ash dust that can be safety deposited in any garbage can." > > Have I missed something? > > Scott Forman > 82 FC35RB > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Chris" > wrote: > > > > Came across this Wanderlodge on E-Bay.. > > > > Item number 120023609811 > > > > looks to have rolled over.... > > > |
08-22-2006, 01:14
E-Bay Wanderlodge
Never heard of this on a WL...I assume this was a "customer
modification" rather than something from the factory??? Scott --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > its called an incinolet one of the worst ever waste disposal systems > installed in any mobile application > we had them on Railway Engines and one of the neat things about it was > to start it after it was partially full and then leave the cab of the > engine. the resultant stench would just about kill the poor engineer > Stephen 77fc35 never ever push the button while moving > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > From the description: > > > > "and the prize above all motor homes is the revolutionary method of > > incinerating sewer waste & converting one weeks waste into a small > > cup of ash dust that can be safety deposited in any garbage can." > > > > Have I missed something? > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "Chris" > > wrote: > > > > > > Came across this Wanderlodge on E-Bay.. > > > > > > Item number 120023609811 > > > > > > looks to have rolled over.... > > > > > > |
08-22-2006, 01:48
E-Bay Wanderlodge
It appears that he may have a waste system developed by General
Motors and put on the fitst GMC motorhomes in 1974. It is called a thermosan unit. There is a pump that takes a continuous small amount of waste out of the black tank and inserts it into the exhaust system. The system must be up to operating temperature and the coach driving at I believe 40MPH before it will work. I had one on my 1974 GMC motorhome (I also had a 1976 Palm Beach with it). Tom Warner Vernon Center,NY 1985 PT 40 At 08:09 AM 8/22/2006, you wrote: > From the description: > >"and the prize above all motor homes is the revolutionary method of >incinerating sewer waste & converting one weeks waste into a small >cup of ash dust that can be safety deposited in any garbage can." > >Have I missed something? > >Scott Forman >82 FC35RB >Memphis > >--- In WanderlodgeForum@yahoogroups.com, "Chris" >wrote: > > > > Came across this Wanderlodge on E-Bay.. > > > > Item number 120023609811 > > > > looks to have rolled over.... > > > > > > > > > > >Yahoo! Groups Links > > > > |
08-22-2006, 05:14
E-Bay Wanderlodge
My '81 FC didn't have one but it was listed as an option. I've never talked to
anyone who had one. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 22, 2006 6:14 AM Subject: [WanderlodgeForum] Re: E-Bay Wanderlodge Never heard of this on a WL...I assume this was a "customer modification" rather than something from the factory??? Scott --- In WanderlodgeForum@yahoogroups.com "Stephen Birtles" > > its called an incinolet one of the worst ever waste disposal systems > installed in any mobile application > we had them on Railway Engines and one of the neat things about it was > to start it after it was partially full and then leave the cab of the > engine. the resultant stench would just about kill the poor engineer > Stephen 77fc35 never ever push the button while moving > > --- In WanderlodgeForum@yahoogroups.com "Scott Forman" <sforman@> > wrote: > > > > From the description: > > > > "and the prize above all motor homes is the revolutionary method of > > incinerating sewer waste & converting one weeks waste into a small > > cup of ash dust that can be safety deposited in any garbage can." > > > > Have I missed something? > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com "Chris" > > wrote: > > > > > > Came across this Wanderlodge on E-Bay.. > > > > > > Item number 120023609811 > > > > > > looks to have rolled over.... > > > > > > [Non-text portions of this message have been removed] |
08-22-2006, 06:10
E-Bay Wanderlodge
On my control panel in the kitchen on my 83FC35 it has a switch for "Waste Odor
Control".. Any idea what that does? Is that the same thing? Richard Hayden My '81 FC didn't have one but it was listed as an option. I've never talked to anyone who had one. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 22, 2006 6:14 AM Subject: [WanderlodgeForum] Re: E-Bay Wanderlodge Never heard of this on a WL...I assume this was a "customer modification" rather than something from the factory??? Scott --- In WanderlodgeForum@yahoogroups.com "Stephen Birtles" > > its called an incinolet one of the worst ever waste disposal systems > installed in any mobile application > we had them on Railway Engines and one of the neat things about it was > to start it after it was partially full and then leave the cab of the > engine. the resultant stench would just about kill the poor engineer > Stephen 77fc35 never ever push the button while moving > > --- In WanderlodgeForum@yahoogroups.com "Scott Forman" <sforman@> > wrote: > > > > From the description: > > > > "and the prize above all motor homes is the revolutionary method of > > incinerating sewer waste & converting one weeks waste into a small > > cup of ash dust that can be safety deposited in any garbage can." > > > > Have I missed something? > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com "Chris" > > wrote: > > > > > > Came across this Wanderlodge on E-Bay.. > > > > > > Item number 120023609811 > > > > > > looks to have rolled over.... > > > > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
